Old 08-03-2004, 04:01 PM   #1
MAD REX
Member#: 18163
2002 2.5 WRX
MBP
Default Honda Supercharger WI kit, will it work on my WRX?
Kill detonation not performance! Forced induction increases throttle response and power throughout the entire rpm range. Unfortunately, more power equals more heat! Most people simply retard the timing to lower the heat, which results in power loss. Our liquid intercooling water injection system gives you the best of both worlds, with highly advanced timing for horsepower and a mist of water that lowers temperatures up to 100 degrees.
Here are the install instructions
I talked to Jackson Racing who makes / sells it and they didn't know if it would work or not. I know this guy that is selling it for $100
http://www.jacksonracing.com/graphic...ns/989-950.pdf
Any info would be appreciated!
MAD REX is offline   Reply With Quote
Old 08-03-2004, 04:35 PM   #2
bikerboy
Member#: 5477
2007 R171.473
2009 SWP Spec B
http://www.aquamist.co.uk/cp/cp.html
Many people use it. Do a search for w/i
bikerboy is offline   Reply With Quote
Old 08-03-2004, 04:41 PM   #3
MAD REX
Member#: 18163
2002 2.5 WRX
MBP
So it's prolly just a relabled 1S system?
Old 08-03-2004, 05:47 PM   #4
wrx plus
Member#: 42253
2003 RWD WRX
Alcohol injected, WRB
That looks suspiciously like an Aquamist pump. But in answer to your question, yes, it'll work on your wrx. W/I systems are not vehicle specific, I use the Aquamist 2d system myself. One of the Vendors on Nasioc sells a thing-a-ma-gig (can't remember what it's called) that allows you to install the injector nozzle with out tapping your intercooler or butchering your hoses. (I just tapped my APS TMIC)
I wouldn't run without W/I ever again.
Kent
wrx plus is offline   Reply With Quote
Old 08-04-2004, 12:54 PM   #5
MAD REX
Member#: 18163
2002 2.5 WRX
MBP
Cool I'm gonna buy it!
Old 08-04-2004, 04:52 PM   #6
dwx
Member#: 8343
2005 2012 Jeep
2013 DGM BRZ
Yeah that's most definitely an aquamist pump.
Old 08-04-2004, 05:44 PM   #7
wrx plus
Member#: 42253
2003 RWD WRX
Hint when you get your engine tuned and you're happy with it (i tuned mine close to the edge but not in the danger zone) use the .7mm jet or the medium in your kit and set it to come on at 10 psi (Later you can get a N/C switch to activate with your UTEC) and when that baby kicks in it will feel like a second turbo. Some will argue the benefits of W/I but you just won't know until you try it. Note: with Aquamist pumps you can run up to 50% methanol, although for my application 20% is the best.
DO NOT USE ETHANOL!!!!!!!!!!!!!
Kent
Old 08-05-2004, 10:24 AM   #8
MAD REX
Member#: 18163
2002 2.5 WRX
MBP
Pics of the actual kit
Everything appear ok?
Old 08-05-2004, 05:56 PM   #9
wrx plus
Member#: 42253
2003 RWD WRX
The harness, and the pressure switch,and electrical harnesses all look like aquamist products or knock-offs. That kit as an aquamist kit is somewhere around $600, good deal. I don't see any jets?
Kent
Old 08-05-2004, 07:49 PM   #10
dwx
Member#: 8343
2005 2012 Jeep
2013 DGM BRZ
That's an aquamist 1s system with a resevoir bottle thrown in. Notice the relay says Aquamist on it, not to mention ERL is the parent company of Aquamist.
Old 08-06-2004, 06:38 AM   #11
wrx plus
Member#: 42253
2003 RWD WRX
Ha!, you're right I turned up my screen resolution and saw that, good eye. That tank is the $9.99 universal model availible in the auto parts store. I still don't see any injection jets?
sti utec will it work on a wrx noktrnlracer UTEC 2 07-13-2009 09:12 PM
UTEC REV 6, will it work on 05 WRX REDWRX05 UTEC 1 03-13-2009 05:49 PM
i have a mits 20G turbo will it work on my car?? 01G_WRX_02 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 8 07-26-2005 10:49 AM
Vishnu EMI adapter, will it work on a 2004 WRX? wrxon Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 10-06-2003 09:45 PM
ApexI Safc will it work on the wrx? Keith Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 03-22-2001 12:51 AM
