Welcome to the North American Subaru Impreza Owners Club Sunday May 3, 2015
Go Back   NASIOC > NASIOC Subaru Models > 'Old School' Subaru Forum
Old 08-03-2004, 09:42 PM   #1
red86aw11
Member#: 67210
1988 GL
maroon/red
Default 88 subaru GL auto transmission cooler lines location
changed water pump the other day and went to put the radiator back. For
an automatic tranny equiped cars, the tranny fluid is cooled by running
the tranny lines into the radiator. I got the lines mixed up and do not
know where they are supposed to go back in. From the tranny, there is
one line coming from the front left side and another coming from the
rear left side of the tranny. Both these lines are run into to the
left side of the radiator, one at the bottom and the other at the top.
I need to know which line goes into which part of the radiator.
I got 88 GL 1.8L FI EA82 non-turbo 4-door with an automatic. The Haynes
manuel I have does not seem to have a diagram showing the tranny cooler
lines going into the radiator. I forgot to lable them when I took them
out, creating the problem I have right now.
any help is appreciated
thanx
red86aw11 is offline   Reply With Quote
Old 08-04-2004, 12:31 AM   #2
Flowmastered87GL
WCSS Drunk
Member#: 8914
2005 Baja Sport
Regal Blue Pearl
PLEASE get a second opinion on this, but if I recall correctly on my 92 loyale project car, the fluid came FROM the transmission torque converter area, into the TOP of the radiator, out the bottom of the radiator, then back to a long S shaped metal tube that returned to the ATF pan.
So... trace the hose back to the tranny... if its the torque converter one it goes on top, if it goes to the tube (to oil pan) it goes on the bottom... like I said please get a second opinion, its been afew months since I sold this car.
Flowmastered87GL is offline   Reply With Quote
Old 09-01-2004, 08:01 AM   #3
sixpack subaru
Member#: 64974
1995 WRX,APEXi,HKS,$
Faded, Stonechipped Red
Technically, or not, it doesn't Freakin matter!!
All it is is a coil type cooler that the fluid flows through in the tank of the Radiator.
Anyway, you should only be able to re-connect where they came from as the hoses from memory are different lengths??
Doesn't matter anyway!!!
Cheers
Sixpack Subaru
sixpack subaru is offline   Reply With Quote
Old 09-05-2004, 02:07 AM   #4
TurboneX
Member#: 21676
RX 02Foz,05OB
The bottom fitting on the rad is the inlet, top is outlet(I thought this would be the other way around...gravity). But in the FSM there is nothing showing what line is what from the tranny. The shorter hose, I assume, is for the inlet (bottom). If they werent disconnected from the tranny it should be easy to see which one is long and short.
TurboneX is offline   Reply With Quote
2000 JDM subaru forester AUTO transmission EJ20g davidnyk Drivetrain 2 01-19-2010 03:43 PM
Subaru GL manual transmission ryno50485 Drivetrain 0 08-13-2007 05:47 PM
88 subaru GL crankshaft pulley bolt size red86aw11 'Old School' Subaru Forum 7 07-29-2004 08:10 PM
What kind of Auto Transmission Cooler Should I get? STEALTH-WRX Transmission (AT/MT) & Driveline 11 02-12-2004 12:56 AM
88 subaru wagon GL - Door Panel intelsubu 'Old School' Subaru Forum 2 01-31-2004 07:49 AM
