Old 08-03-2004, 10:50 PM   #1
Hoffman
Member#: 64125
2007 WRX
Urban Grey Metallic
Default Preparations for ej25 bolt-on
I took my 98 Legacy 25GT into the shop today for overheating problems (99% sure from a blown head gasket). Of course it will need the engine pulled to replace the gasket, and down the road i might want to turbo the engine, SO, the question is, besides o-ringing the gaskets, what other preparations should be done. The engine has 130,000 miles on it, so I need to be careful through some prevention. A freind of mine said piston rings should be swapped...
Thanks
Hoffman is offline   Reply With Quote
Old 08-03-2004, 10:54 PM   #2
no-coast-punk
Member#: 49087
1998 RST V8 STi swap
'05 R6 '95 BMW V8 hotness
umm... STi shortblock? $1500 new from subaru.
no-coast-punk is offline   Reply With Quote
Old 08-04-2004, 08:40 AM   #3
ChicksDigWagons
Member#: 20508
1998 Red Wagon
New Turbo Project...
Not a bad idea at all.
ChicksDigWagons is offline   Reply With Quote
Old 08-05-2004, 12:15 AM   #4
Revision
Member#: 242
MY05 PSM GGA !STOCK
MY99 RS-RIP / MY95 MX-5
Yikes, ChicksDigWAgons is still alive!
When are you coming back to MWSOC chat?
back to topic
He said down the road... I'd hate to see how the STi shotblock runs while NA...
As for block prep, unless you want to run more than 10psi, you don't really need to do anything to a 98-99 RS shortblock. I've run the last 40,000 miles turboed at 7-8psi without problems. Stock block and heads. Push more boost or run a lot at or over 6000 rpm.. Well plan on something breaking then.
Revision is offline   Reply With Quote
Old 08-05-2004, 05:05 AM   #5
White 2.5rs
Member#: 39936
99RS TWE&SCAT EJ257
Hydra+HMist+PPG+35R=DEATH
ill be doing it here tomorrow hopefully
Old 08-06-2004, 08:51 AM   #6
ChicksDigWagons
Member#: 20508
1998 Red Wagon
[quote=Revision]Yikes, ChicksDigWAgons is still alive!
[quote]
As soon as I can find a way to come up with the money I owe you
There isn't a day that goes by I don't think about it, and it really bothers me...and I'm ashamed.
Old 08-06-2004, 08:53 AM   #7
ChicksDigWagons
Member#: 20508
1998 Red Wagon
Unsungboxer putzd around on a low compression EJ22 N/A for a while...as I recall he said it wasn't really too bad.
Old 08-06-2004, 12:18 PM   #8
maxiav
Member#: 40413
2001 BRP RS-T EJ257
Link'd - 252WHP 274WTQ
Perfect opportunity... do it!
maxiav is offline   Reply With Quote
Old 08-07-2004, 09:11 PM   #9
Hoffman
Member#: 64125
2007 WRX
Urban Grey Metallic
Damn I would... but funds would be kinda hard to comeby.... This is more of a prep thing for a bolt-on.... So O-ringed head gaskets should be good enough?
HKS 2835 kit for 01Jspec, bolt-on for usdm 03? guru_method Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 04-06-2009 10:08 AM
required torque for sti bolt on bearing bolts? homer09 Brakes, Steering & Suspension 3 03-21-2008 10:28 PM
Torque for 14mm bolts on front calipers... illmatic Brakes, Steering & Suspension 1 12-11-2002 02:37 AM
torque spec for downpipe bolts on the turbo cre Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 09-28-2002 10:04 PM
Anybody have the torque specs for the bolts on the Strut Towers? sherifx Brakes, Steering & Suspension 4 04-07-2002 10:49 AM
