Old 08-03-2004, 10:44 PM   #1
S.V.133
Member#: 44166
2003 WRX
Midnightblack
Question AVC-R Help!!
I just installed the AVC-R. Everything went well, no problems. Decided not to hook up the boost solenoid until I felt everything was running right. Hooked up the solenoid today. As soon as I turned the car on CEL went on. Any help w/ this? Why did it go on?
S.V.133
S.V.133 is offline   Reply With Quote
Old 08-04-2004, 09:56 AM   #2
S.V.133
Member#: 44166
2003 WRX
Midnightblack
Anyone?
Old 08-04-2004, 10:56 AM   #3
big_adventure
Member#: 40501
2005 Decathalon 21sp
One WheelSeanPower
Get the code pulled, but it's probably a wastegate solenoid low/high input CEL. Autozone pulls codes for free.
big_adventure is offline   Reply With Quote
Old 08-04-2004, 11:59 AM   #4
S.V.133
Member#: 44166
2003 WRX
Midnightblack
Thanks. If it's the wastegate solenoid input CEL, does that mean the duty % needs to be corrected?
Thanks for the help
Old 08-04-2004, 09:43 PM   #5
S.V.133
Member#: 44166
2003 WRX
Midnightblack
Going to Autozone tomorrow. First atempt there, no good. Only 1 person knows how to use the data logger.
Old 08-05-2004, 04:48 PM   #6
S.V.133
Member#: 44166
2003 WRX
Midnightblack
OK, the CEL code was (Wastgate Solenoid) Right now I have the duty set at 50%.
Old 08-06-2004, 05:14 AM   #7
Big Turkey
Member#: 32118
What did it say about the solenoid? The AVCR has it's own solenoid so it completely bypasses the stock one. you can just unhook it call it a day. I have mine hooked up to my ABC right now and capped off.. only because I'm too lazy to take it completely off, haha.
Big Turkey is offline   Reply With Quote
Old 08-06-2004, 10:21 AM   #8
S.V.133
Member#: 44166
2003 WRX
Midnightblack
So, your saying I can cap off the line on the wastgate solenoid of the turbo? Right now have the line on the inlet pipe tapped off. It "T" to the turbo and than into the factory boost solenoid.
Old 08-06-2004, 10:22 AM   #9
S.V.133
Member#: 44166
2003 WRX
Midnightblack
The code was a P0250, I believe (Wastgate Solenoid) Adjusting the duty right now wont help at all.
Old 08-06-2004, 11:26 AM   #10
cdvma
Member#: 21980
2002 PSM WRX (Sold)
2009 BMW X5
When using the independent solenoid of the AVCR you have to leave the stock one attached to the car, the ECU will freak out if it cant talk to it. Just plug the lines that go to/from it and leave it in the car.
cdvma is offline   Reply With Quote
Old 08-06-2004, 12:19 PM   #11
big_adventure
Member#: 40501
One WheelSeanPower
That's the CEL - it's mad that you disconencted the stock solenoid. You can just plug it, but leave it there!
-Sean
Old 08-06-2004, 09:35 PM   #12
S.V.133
Member#: 44166
2003 WRX
Midnightblack
Thanks everyone. I spoke to a friend who has the AVC-R, he told me to do the same. Now I just have to learn to fine tune it.
Old 08-06-2004, 11:30 PM   #13
S.V.133
Member#: 44166
2003 WRX
Midnightblack
No More CEL!!!!!!!
HR: Need AVC-R help! SupraScooby Mid Atlantic Impreza Club -- MAIC 6 09-10-2005 02:36 PM
AVC-R Help vvRX7 North West Impreza Club Forum -- NWIC 1 01-17-2005 01:59 AM
AVC-R help... raykwok Engine Management & Tuning 0 01-05-2005 12:45 PM
avc-r help requested. kcwrx02 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 5 12-03-2002 07:14 PM
Apex-i AVC-R...Help! fastnoypi Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 6 06-05-2001 08:45 PM
