Old 08-04-2004, 12:49 AM   #1
makofoto
Member#: 25243
2006 Legacy Outback
Default Is this the right valve ? Photo ....
Is this the right type of valve to control the amount of pressure bleed from the waste gate solenoid line ?
I have a Shiv Ecutek dyno tune ... but have recently added a ScoobySport downpipe. I'm getting major boost spiking ... and have heard that I could remove the bleed hole (that I believe Shiv added) in order to control the spiking. Removing the bleed hole (I actually taped over it) however brought my boost too far down.
So I was told that I should add a controllable valve, off of a T connector ... in place of the bleed hole section ... to finely control the pressure bleed.
I know I need a retune ... I just can't get it done in time before this weekends AutoCross ...
makofoto is offline   Reply With Quote
Old 08-04-2004, 12:58 AM   #2
cnk
Member#: 10757
2013 BRZ Limited 6MT
You could just use a MBC for the time being. Obviously, get retuned as soon as you can. You could also do some user tuning if you have DD.
Calvin
cnk is offline   Reply With Quote
Old 08-04-2004, 03:30 AM   #3
Equilibrium Tuning
Member#: 26933
2006 STI
CGM
You can use a small brass needle valve from a hardware store as an MBC. The one pictured will probably not work. But make sure to get re-tuned asap and go easy on the boost in the meanwhile.
-- Ed
Equilibrium Tuning is offline   Reply With Quote
Old 08-05-2004, 01:11 AM   #4
makofoto
Member#: 25243
2006 Legacy Outback
hard to go easy on the boost when you're AutoCrossing ! :-)
is this the right place to post this? NismoSkylineGTR Off-Topic 11 05-25-2008 07:18 PM
FSM, is this the right one? Lordhowe Newbies & FAQs 2 01-28-2004 01:20 AM
Is this the right size for the shift knob? THEMUSH Interior & Exterior Modification 4 10-30-2001 08:48 PM
hey, i'm from KY...is this the right chapter? db97 South East Region Forum 4 07-12-2001 08:29 AM
Help...Is this the right part?? OsakaGangsta Interior & Exterior Modification 1 05-18-2001 08:08 PM
