Closed Thread
Old 08-04-2004, 02:05 AM   #1
boostaddict
Member#: 35871
2003 WRX Wagon MBP
Spun Bearing @ 176k
Lightbulb stupid noob question...
So I rotated my tires last weekend. WhileI had them off I washed them and cleaned the inside. Anyway, when I put them back on I made sure to put all the Subaru logos facing up. I noticed today they're all out of whack again.
Is there something wrong with my transmissions or gear ratios?
boostaddict is offline
Old 08-04-2004, 03:09 AM   #2
static_rst
Member#: 50155
first, are you serious? it is late and i may have mistaken this for post horing?
second, if you are takng a left and turn, the passenger side tire has to spin faster to keep with the car because it is covering more ground. so unless you just drove in a straight line all the time, the logos will never be all in the same spot, unless by a huge fluke.
static_rst is offline
Old 08-04-2004, 03:11 AM   #3
ProjectL
Top Scoob 018
Member#: 66952
03 Wrx Wagowned
95 L swapped ver1 fmic'd
Default no need to worry
Well i'm quite a new member myself however i'm pretty sure theres nothing wrong with your car. If you think about it when you go around a corner the outside wheel during the corner will be making more revolutions than the wheels on the inside of the corner. This can cause then to not line up when you look at them again after driving. Please correct me if i'm wrong but I'm pretty sure that with a WRX the amount of power ratio to the front wheels is in a perfect 1:1 ratio. There is more power being delivered to the rear so if you chirp the tires off lets say a start then the rear wheels will spin more than the front. I'm not claiming to know anything of this for sure so if someone with greater knowledge could pick apart my post
Tyson
ProjectL is offline
Old 08-04-2004, 03:25 AM   #4
iofdetiger
Member#: 60924
well hes not a new member, hes been here over a year.
iofdetiger is offline
Old 08-04-2004, 03:34 AM   #5
trustWRX
Member#: 40431
2009 Scion XB
Holy Noob question Batman. Tell me you're not serious.
trustWRX is offline
Old 08-04-2004, 09:17 AM   #6
Thumper23
Member#: 11571
ok, I think this goes up for the n00b of the year award
and no, there is nothing wrong, the tire on the outside of the turn has to travel further than tire on the inside, very very very simple
ProjectL: no, the WRX does not have a perfect 50:50 split at all times
Thumper23 is offline
Old 08-04-2004, 09:20 AM   #7
LatentWagen
Member#: 50315
0806 LGTspecB & Saab
9-2xAero5MT DGM & MBP
you need a new transmission. your car is teh broke...
LatentWagen is offline
Old 08-04-2004, 09:24 AM   #8
Unabomber
👌 Big Ron 👌
Member#: 18062
on car parts so PM
me b4 j00 buy
Davenow will probably have a heart attack when he reads this.
Unabomber is offline
Old 08-04-2004, 09:31 AM   #9
volkl23
Member#: 39092
2004 WRX STi
Java Black Pearl
wow.
volkl23 is offline
Old 08-04-2004, 09:34 AM   #10
docrice
Member#: 67445
1996 Nissan 240sx SE
Red
The ONLY time ANY of your wheels would line us is if you were driving an old muscle car (or occasionally a newer drift/drag car) with a locked diff, and even then only the back two would align....kinda pointless....
docrice is offline
Old 08-04-2004, 09:43 AM   #11
powerslide23
Member#: 61956
2008 Tribeca
Pearl White Metallic
It's fine.
Now try that on a 18-wheeler.
powerslide23 is offline
Old 08-04-2004, 09:43 AM   #12
Howl
Member#: 57830
Be careful when rotating your tires yourself. You have to get the logo on the tire and the logo on the rim the right way up. If you have dirt inside your tires on a regular basis maybe your tires are on upside down (i.e. the valve stem is not lined up with the hole on the rim allowing dirt to get in). Dirt inside your tire makes it heavier and may be causing one wheel to turn slower.
Howl is offline
Old 08-04-2004, 12:49 PM   #13
NeedAWD
Member#: 30831
2004 WRX
Java Black Pearl
Check your blinker fluid...
or your muffler bearings.
NeedAWD is offline
Closed Thread
Stupid noob question Sylon Newbies & FAQs 7 10-28-2006 09:00 PM
stupid noob question about boost abosworth Newbies & FAQs 13 03-10-2006 11:48 AM
stupid noob question.... silverboost0303 Newbies & FAQs 7 09-13-2005 04:01 PM
stupid noob question licwyd7755 Newbies & FAQs 6 10-04-2004 03:36 PM
stupid noob question thisisbrock Newbies & FAQs 7 04-29-2003 11:04 PM
