Old 08-04-2004, 11:07 AM   #1
S.V.133
Member#: 44166
2003 WRX
Midnightblack
Question AVC-R tuning
I set my boost at 1.05 kg/cm2. I set the duty at 50%. Anyone have any tuning tips? Especially about setting the duty.
Thanks
S.V.133
S.V.133 is offline   Reply With Quote
Old 08-05-2004, 11:12 AM   #2
S.V.133
Member#: 44166
2003 WRX
Midnightblack
bump
Old 08-05-2004, 11:56 AM   #3
ataac_flat04
Member#: 19050
2005 Black STi
Happily rowing 6 gears
Default .
You have PM.
ataac_flat04 is offline   Reply With Quote
Old 08-06-2004, 06:17 AM   #4
Big Turkey
Member#: 32118
First, you have to set up everything. Go to NE POINT and set your highest NE point at where you want to shift at. Let's say 7000. Go in 500RPM increments lower. Then you have to go to gear judge and follow the instructions there.
After that, do a 3rd gear pull. If your boost is set at 1.05, and you're hitting alot lower than that.. raise the duty cycle. If it overboosts, let off and lower the DC. If you're around 1.05, then just do a pull and let the AVCR learn itself. Only go by 2-3% at a time.. don't go too much.
Big Turkey is offline   Reply With Quote
Old 08-06-2004, 11:18 AM   #5
S.V.133
Member#: 44166
2003 WRX
Midnightblack
In NE POINT theres 1-8. Start at 8? Im obviously not going to redline at 7500 where it is right now. It's a little confusing. I thought I didnt have to set boost through RPM setting. Gear Judge, should even be more of a pain in the ass. F/B Speed I turned off as well as Learn /Gear.
Help with AVC-R TUNING warui111 Engine Management & Tuning 2 10-15-2005 12:34 AM
AVC-R tuning question ebeck Engine Management & Tuning 3 02-18-2005 02:07 PM
AVC-R Tuning scoobyrex022 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 0 04-19-2004 12:00 AM
avc r tuning toulakid Engine Management & Tuning 0 07-14-2003 05:06 AM
avc-r tuning questions for ya??? maaddog Engine Management & Tuning 1 04-27-2003 01:47 AM
