Old 08-04-2004, 11:22 AM   #1
AZ-wagon
Member#: 44454
2004 WRX wagon
Default Heading to the tuners, ECUTEK Re-flash time
Well, I got my exhaust system: CR-UP, Stromung DP, Stromung hi-flow 3rd Cat and Samco intercooler hose kit. Now time to re-flash the ECU to utilize what I have done.
My ? for all is:
1. Should I put new plugs in (19,000 miles) before I go, if so what type?
2. What should I tell/ask the tuners before I let them work on the car?
Iím still not sure if I should bring it to the local tuners or just send out the ECU for a reflash. The local shop here in Phoenix has a good rep. so I was thinking of using them http://www.dynocomp.com/ . But, If they are just going to reflash the ECU and not really tune the car, I guess it would make no difference from just sending out the ECU.
The shop charges like $595 + Dyno time for the first reflash, pricey in my book. What would you choose? Local shop or just send out the ECU?
AZ-wagon is offline   Reply With Quote
Old 08-04-2004, 11:40 AM   #2
cdvma
Member#: 21980
2002 PSM WRX (Sold)
2009 BMW X5
1. Yes. Put in one range colder plugs.
2. Tell them you have a cat, it may affect the AFR reading if they stick the O2 sensor in the tailpipe.
Local shop, and have them custom tune it, its well worth it.
cdvma is offline   Reply With Quote
Old 08-04-2004, 12:01 PM   #3
jblaine
Member#: 8512
2002 WRX chassis...
stage-infinity.com
I've never bought the colder plugs thing for a 260HP WRX.
I still use the factory spec NGKs with zero problems and great timing at 16.5psi on the stock turbo. When I replaced them at 30,000 miles they looked just fine.
jblaine is offline   Reply With Quote
Old 08-05-2004, 10:24 AM   #4
AZ-wagon
Member#: 44454
2004 WRX wagon
Thanks for the info. I'm going to see if I can talk with them this week and see what I can schedule. I'll ask the about the plugs also, but I think I will wait.
I'm not looking for crazy HP, just want to get a smoother power band and a little more umff without compromising the drivability or anything else.
Thanks again,
Old 08-05-2004, 09:18 PM   #5
cronic
Member#: 9749
Go to Kingpin performance! Mike and Clark(Azscoobie) will hook you up, there reputation speaks for itself.. I have delt with them cross country a bunch of times wheather it was for parts or flying them out to tune cars in NY.. I will be moving to AZ in november, and cant wait to have Clark so close to tune my car when i need it.. You cant go wrong..
I would just PM Mike(kingpin) or Clark(azscoobie) and tell them you goals and what u want out of the car, they will set you up right and not steer you in the wrong direction..
Dave-
cronic is offline   Reply With Quote
Old 08-06-2004, 01:59 PM   #6
AZ-wagon
Member#: 44454
2004 WRX wagon
Thanks,
Will deff. check them out!
Custom EcuTek re-flash and possible issues Chuck H Engine Management & Tuning 1 11-05-2004 10:48 PM
2004 WRX Ecutek Re-flash MISSMYS4 Engine Management & Tuning 1 05-06-2004 09:51 AM
Difference between vendors ECUtek re-flash? Drews_WRX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 04-08-2003 04:37 PM
Ecutek Re-Flash 5150wrx Bay Area Impreza Club Forum -- BAIC 16 02-23-2003 01:10 AM
Ecutek re-flashed my chip WRXzard Southern California Impreza Club Forum -- SCIC 1 10-29-2002 01:53 PM
