Old 08-04-2004, 11:59 AM   #1
Subiemax
Member#: 30691
2013 FRS
RED
Default Bad idle and killing on warm start?
Every time I stop my 04 sti for 20-30min and try to start it again it will hardly run at all. Rpms will barely register on the tack. It vibrates badly and a few times has just killed on me. Now if I start it and rev it everything is fine, but I shouldn't have to do this.
I read an old thread on this but nobody gave a good answere.
Anybody brought this to a dealer? Or come up with a fix on their own?
Really pissed me off when I picked up my date, got in the ride and cranked it up, and it's spittin, sputterin and just died. And she's like
Sucks to be me!
Subiemax is offline   Reply With Quote
Old 08-04-2004, 12:27 PM   #2
DISCOPOPE
Member#: 43339
2oo4 STi
URgt35r w/t3hM3finj3cki0n
stock?
DISCOPOPE is offline   Reply With Quote
Old 08-04-2004, 12:28 PM   #3
Silver-Bolt
Member#: 40189
2004 STi
Silver/Silver
Any mods? Possible vacuum leak or injector issue.
Silver-Bolt is offline   Reply With Quote
Old 08-04-2004, 12:30 PM   #4
Subiemax
Member#: 30691
2013 FRS
RED
Stock! No mods.
Unless you call intake elbow a mod.
But I really don't call that a mod.
Old 08-04-2004, 12:39 PM   #5
DISCOPOPE
Member#: 43339
2oo4 STi
ok.
maybe:
california, (see also bad) gas
leak in intake AFTER the maf, possably when you had the intak apart?
bad plug/s
Front O2 borked
Throttle Body seal?? IC seal??
vacuum leak
Broken MAF, wire, or maybe MAF not seated correctly...
Old 08-04-2004, 12:43 PM   #6
DISCOPOPE
Member#: 43339
2oo4 STi
no misfire cels?
Old 08-04-2004, 12:44 PM   #7
KatukasGTi
Member#: 63200
2005 STi
Originally Posted by Subiemax
Stock! No mods.
Why do you need that intake elbow ? Maybe this in not a reason but maybe engine is getting very hot air when you start it ? Is it from metal ? When you rev it intake cools down and everything starts to work. I would try to put stock part first.
andrius
KatukasGTi is offline   Reply With Quote
Old 08-04-2004, 12:46 PM   #8
Subiemax
Member#: 30691
2013 FRS
RED
happened berfor and after elbow.
Old 08-04-2004, 12:50 PM   #9
Subiemax
Member#: 30691
2013 FRS
RED
No CELs
It just idles very badly.
Reving the engine just makes it not idle.
I'm in LA-Louisiana!
We got 93oct.
Just seems like a hot-start problem.
I've seen others with this problem, but no solutions.
Old 08-04-2004, 12:52 PM   #10
DISCOPOPE
Member#: 43339
2oo4 STi
ah, LA not L.A. ok,
i still vote bad gas, but check all your hoses to make sure they are seated correctly.
iirc some of the first sti's were delivered with leaks in the ic coupling. i sometimes remember things incorrectly, so maybe i'll get admonished here soon.
also the stock air box can be a bitch to get locked down the first few times you try.
make sure thats buckled down tight.
Old 08-04-2004, 12:52 PM   #11
Subiemax
Member#: 30691
2013 FRS
RED
andrius
Intake elbow just deletes the silencer. If anything it give a less restrictive path for fresh, colder air to the intake.
Old 08-04-2004, 12:56 PM   #12
Subiemax
Member#: 30691
2013 FRS
RED
Originally Posted by DISCOPOPE
ah, LA not L.A. ok,
The other LA
Car is about 2 months old.
I had alot of practice with my wrx on the airbox. Definately a learned skill!
Could be bad gas... I'll just keep an eye on it. See if it keeps on.
Old 08-04-2004, 12:57 PM   #13
KatukasGTi
Member#: 63200
2005 STi
It think you can notice this on every car and any model. It's called heatsoap. Maybe one of the sensors is malfunctioning making cars computer more dificult to keep rpms.
Old 08-04-2004, 01:02 PM   #14
Subiemax
Member#: 30691
2013 FRS
RED
HEATSOAP!
Is that good for cleaning rims!
JK
Heatsoak...
Maybe, what i'm trying to find out is if someone else had a bad sensor or something.
Old 08-04-2004, 01:35 PM   #15
wolverine
Member#: 36571
2004 WRX STi
Black & gold
stock -> take to dealer
wolverine is offline   Reply With Quote
Old 08-04-2004, 01:53 PM   #16
Subiemax
Member#: 30691
2013 FRS
RED
Yes, thats good. I just wanted input.
Dealer is an hour drive.
If it keeps on I will.
Old 03-20-2006, 05:16 PM   #17
R4ND0M_AX3
Member#: 67483
2005 WRX STi
Did this get solved? Did it only run poorly for a short time after a hot start or did it always do it during warm idle?
R4ND0M_AX3 is offline   Reply With Quote
Old 03-20-2006, 11:09 PM   #18
my94saleen
Member#: 97791
2006 sti
wr blue
Default idle
do you use syn oil.seen it on sti an turbo legacy's.switched to conv. oil problem went away.even subaru tech training says with no codes try that.sounds stupid but it has happened a few times.
my94saleen is offline   Reply With Quote
Rough Idle, Stalls, P0011, and Noise on cold start Maddroxx Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 27 12-16-2009 04:04 PM
AP protune and problem with warm start titsataki AccessPort 0 07-28-2006 09:47 AM
low/rough idle on warm starts raginbull74 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 7 01-23-2006 06:23 PM
longer craking time on warm starts... r6_pat Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 10-17-2005 02:03 PM
Bad Idle, What's Going On? optionimports Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 10 03-29-2004 12:24 PM
