Welcome to the North American Subaru Impreza Owners Club Monday February 8, 2016
Old 10-18-2004, 11:33 AM   #1
scoobyimprza
Member#: 24956
1997 Impreza WRX
Steel Blue Mica
Default Blue wire mod
What this is, for anyone using the SAFC, is a way to read your O2 sensor voltage.
On the SAFC harness, you have 2 wires for your MAFs, or whatever your input signal is. You have 2 because some cars have 2 MAFS, ie. Skyline TT. So your extra wire gets tapped into the O2 sensor, and on your sensor check on the SAFC you can see the voltage coming from the sensor. The only downside to this is the SAFC puts a load on the sensor and can modify the signal to read up to .06 volts less than what it is.
What I'm wondering is, what should the sensor efficiently be reading? I looked on my ECU pinout and it says .70 volts is rich, but that seems low. Some websites said closer to .98 volts. Am I correct in assuming that the higher voltage means rich?
Also, this isn't quite an accurate tuning tool. It just gives you a general idea, which is better than no idea at all.
Brent
scoobyimprza is offline   Reply With Quote
Old 10-18-2004, 12:16 PM   #2
Portly
Member#: 1197
1997 Impreza Wagon
Mystic Blue Pearl
This link might prove helpful.
http://www.autospeed.com/cms/A_0618/article.html
Conventional oxygen sensors work more like a rich/lean "switch" than as a measuring tool. At anything other than light throttle, they're virtually worthless.
_Jeff
Portly is offline   Reply With Quote
Tuning S-AFC with blue wire mod. powerlabs Normally Aspirated Powertrain 35 06-25-2004 03:12 AM
do i cut the blue wire, or the green wire??? scoobin' Electrical & Lighting 5 02-19-2004 09:22 PM
Power Connect Blue Wire to multiple devices badkid Car Audio, Video & Security 2 09-20-2003 11:18 PM
help..S-AFC Blue wire O2 sensor?? tmaler13 Technical Forum Archive 14 09-11-2000 07:20 AM
SAFC Blue Wire Mod... 98 vs 99 HRE | giulio Technical Forum Archive 3 07-18-2000 02:19 PM
