10-26-2000, 11:43 AM | #1 |
Member#: 774
Vehicle:2000 2.5RS Silverthorn |
Silver interior pics posted !!
Here we go... as demanded, I finally took a cheap picture of the dash area and posted it. so here it goes... total time... 3 hrs total cost... $12.00 the cost having that feeling of a kick @ss looking interior ... priceless http://216.242.153.40/MembersList/Vi...16&PicNumber=5 --Reiflex www.reiff.freeservers.com ImprezaRacing
10-26-2000, 11:46 AM | #2 |
Member#: 1931
Vehicle:2000 00 impreza 2.2l wagon |
what did you use to paint it with?
10-26-2000, 01:53 PM | #3 |
Member#: 1904
TXIC
Vehicle:2017 Impreza Sport E36 M3/4/5 |
dude, i did the same thing!! good taste!!
10-26-2000, 03:28 PM | #4 |
Member#: 774
I used..
-Primer -Aluminum color Rust-Oleum indoor/outdor spray paint (VERY close to the Silverthorn color) -Clear protective finish |
10-26-2000, 05:45 PM | #5 |
Member#: 187
South East
Vehicle:2008 Impreza 2.5i NBP |
how about ALL WHITE? hehehe... check mine out!
http://216.242.153.40/MembersList/Vi...02&PicNumber=2 |
10-26-2000, 05:57 PM | #6 |
Member#: 1346
Did you remove the pieces and then spraypaint them or what?
Looks good BTW. |
10-26-2000, 07:42 PM | #7 |
Member#: 678
How did you remove the pieces of the dash?
10-27-2000, 02:36 AM | #8 |
Member#: 2205
Vehicle:1998 Legacy L Wagon Deep Sapphire Blue |
Did you structure the pieces at all with sandpaper or anything like that beforehand?
10-27-2000, 04:34 AM | #9 |
Member#: 320
Vehicle:1999 Impreza 2.5 Silverthorn |
Sanders,
Did you repaint your whole car? U always have to like when models are hanging around at picture time. Rick http://roads.to/ricksrides |
10-27-2000, 06:58 AM | #10 |
Member#: 1209
sanders you better watch out, Subie Gal might get some ideas and do her interior in yellow!!
10-27-2000, 09:29 AM | #11 |
Member#: 774
I'll post detailed instuction of how to take apart all the dash parts that I painted later today, it's gona be long (sort-of)..
Center console (incl shifter area) Center Vent Main Side vents Small top dash vents Door Handle/tweeter Bezel Window button/Door lock bezel Instrument Panel (shroud & guage) man, I should have taken picture of it so i could just post it on my web site....Hey, anyone in the Seattle area with a digital camera who want to do this, I'll help & we could take picture of this? --Reiflex www.reiff.freeservers.com ImprezaRacing [This message has been edited by Reiflex (edited October 27, 2000).] |
10-27-2000, 10:22 AM | #12 |
Member#: 439
E. Canada
Vehicle:www |
Hi Reiflex, can you take a close-up picture?
etam |
10-27-2000, 01:21 PM | #13 |
Member#: 476
Vehicle:2003 GPW s2000 Former WRX owner |
here's mine
10-27-2000, 03:02 PM | #14 |
Member#: 774
forget the interior, I want that DVD player!!
droolllll. |
10-27-2000, 03:08 PM | #15 |
Member#: 774
(long)
I did remove the painted pieces from the dash, didn't have to take the dash off. And it wasn't too difficult. It took me about 2 hours to remove the dash to figure out that I didn't need to remove the dash.. doahh. Doing it properly (without taking apart the dash) should only take 10 mins or less. I was able to put everything back in reveres order in 5 mins. Most everything pops out, the other parts screw out. Here how I took then off... Center console (incl shifter area): open the arm rest , pop off the screw caps, take out 2 screws. {every thing else below pretty much snaps out & back in} lift out the e brake bezel (start from back to front) lift out the shifter bezel & unscrew shifter knob (for painting I also removed the shifter bag) pull the radio bezel strait out. Center Vent: The vent and 'sunglass' holder is 1 piece. open the 'sunglass' holder and remove 2 small tabs cover the screws located on the inside front area remove screws. open lid half way and tug the whole thing strait out. (you might have to do a tug & wiggle motions to get it out. Kinda tuff, but it does come out) Main Side vents: (use a small spatula or wide flat head screw driver) It's held in by a curved metal tab at the bottom lip of the vent. insert screw driver up & under the bottom of vent, els around a little for the tab) Compress the tab up and pry the bottom of the vent out. remove vent bezel from directional vent slats, how.... too odd to explain, look at it and you see how it comes apart. ( the bezel clips onto the slats) Small top dash vents: there is a metal tap holding it in place that is facing you. Take your screw driver and insert thought the new opening were the main vent was and pressing the tab with a screw driver. While pressing the tab, take another small screw driver and pry out or push out the vent. (this is way easier that it sounds) Door Handle/Tweeter Bezel: loosen screw in the handle. use screw driver to get under the bezel & pop it out. Window button/Door lock bezel: use screw driver to get under the bezel & pop it out. Separate the buttons from bezel (they're snapped together) Instrument Panel: shroud bezel.. unscrew & remove 2 screws at the top of the shroud Hold both sides of the bottom area of the shroud (area just behind blinker and washer levers) and firmly tug out to bottom. Spring like tab are holding them in. (no need to press in the tabs when you pull) Instrument Gauge.. take out all the screws (3 I think) and remove whatever part of the instrument gauge you want to paint. This is a good time to swap out that high speed STi speedo gauge if you have it. Done. --Reiflex www.reiff.freeservers.com ImprezaRacing [This message has been edited by Reiflex (edited October 27, 2000).] |
10-27-2000, 03:11 PM | #16 |
Member#: 187
South East
hey everyone...
well, i did basic prep of the parts... complete removal... except for the top dash, didn't want to mess with the airbags. subie gal saw my interior before back then... she was one of the only who supported me when others flamed my decisions with my car... she rocks! rick... yes i did repaint my whole car... dupont blue ice with blue pearl and silver mini flakes... and you know i really like it when the import models are all over my car! =) for some reason they love baby blue!!! =) well... take care everyone! --chad--rs |
10-27-2000, 04:48 PM | #17 |
Member#: 2237
TXIC
Vehicle:2000 GC8 STi 2015 Ford Mustang GT |
Sanders, the hands of those girls should not be on that phat paint job!!! Slap them for touching your car...they should know better, their hands should be all over me instead, silly girls...when will they learn?
-Kevin [This message has been edited by Bankheist (edited October 27, 2000).] |
10-28-2000, 05:51 PM | #18 |
Member#: 2205
impresive: Maybe when you buy a car!
So, will someone explain to me what the basic prep was? Just cleaning the parts off? Scuffing them up? What? |
10-28-2000, 09:03 PM | #19 |
Member#: 678
Hey... I just finished painting everything silver .
I didn't prep anything... just sprayed on the primer, then the silver paint, and then some clearcoat on top of that. It looks really nice but I screwed up a few times while taking care of the vents and the putting the door handle bezel back in... so... watch out while you're putting everything back in. |
10-28-2000, 10:21 PM | #20 |
Member#: 746
South East
well I photoshoped blue in there and it looks alright. but microsoft paint just doesn't capture it very well.
10-29-2000, 12:02 AM | #21 |
Member#: 746
South East
when is somebody gonna paint their dash blue?
10-30-2000, 10:05 AM | #22 |
Member#: 774
If you want to be very anal and to do the BEST quality job possible take the following step in prepping & painting... Sand the surface to be painted -use fine grit sandpaper. You don't want small gouges in the surface, they'll be magnified when painting) Clean the surface of any particles, grease & oils. -use latex gloves to avoid oil from you finger getting on the surface & dry with a painting type tack cloth. Spray on several coats of primer with flex additive mixed into the primer Lightly sand primer smooth with an even finer grit sand paper. Clean surface again -use latex gloves to avoid oil from you finger getting on the surface & dry with a painting type tack cloth. Paint a few very light coats and then paint away with a little flex additive Mix into the paint. Let dry and cure Spray on clear coat or other clear protective type finish (UV protection recommended) --Reiflex www.reiff.freeservers.com ImprezaRacing |
10-30-2000, 01:20 PM | #23 |
Member#: 774
Only from the best!
10-31-2000, 12:29 AM | #24 |
Member#: 1403
TXIC
Vehicle:99 RBP GC8 Impreza |
Reiflex,
You would not have happened to got that idea From a certain 99 Rally Blue Impreza now would you. |
99 Legact GT // Silver w/ black leather interior! PICS! | d1giPhux | Private Vehicle 'For Sale' Classifieds | 12 | 11-28-2005 09:21 PM |
graphite leather interior - repost - good pics posted, sorry 56k | wrxinmn | Private 'For Sale' Classifieds | 1 | 10-18-2004 02:19 PM |
post night interior pics | digidelia | Member's Car Gallery | 1 | 11-13-2001 08:20 PM |
Please post stock 98-00 2.5RS interior pics! | AndrewT | Member's Car Gallery | 4 | 09-26-2001 05:21 PM |
