Old 08-04-2004, 08:37 PM   #1
pfhlipwrx
Member#: 19319
Have a Nice Day? Misfire, Flashing UTEC cel at idle...
Ok, ever since I installed 18G & all supporting mods, FMIC, Inj, etc, I have had nothing but the ****es with knock & misfire codes out the razoo.
Today however I entered a new chapter.
Before you flame, YES I did a search.
The UTEC decide to flash at me, every second for about 10 secnd's, while I was idle at a stop light, car had just warmed up.
I just had an Inspection done had codes pulled & had misfire codes in all 4 cylinders... Anyways, point being.
After searching, I stumbled on coilpacks. I have 48K...maybe this could be my issue?. I will accept any constructive critiscism here, so please endulge
thanx peeps....
Ohhh, also my idle is VERY eratic 500rpm-2000rpm, until fully warmed up.
All equipment, FMIC, Inj, Fuel pump, etc are only 5K old...Yes plugs gapped right, new too....
pfhlipwrx is offline   Reply With Quote
Old 08-04-2004, 09:01 PM   #2
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
....when was the last time you checked yoru compression...???
Have you checked for an induction leak...I mean REALLY checked ALL the IC piping???
Is your crank angle sensor plugged in all the way?
Is the cam angle sensor also plugged?
Are you very rich/lean at idle?
Is your idle air control solenoid plugged in?
I sent you a PM...
Misfire Flashing CEL NPW482 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 16 05-24-2010 03:53 PM
Flashing CEL at idle, will barely move,follow up to "&*#$ I found metal in my oil" JeffrWRX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 06-26-2007 03:13 PM
cel flashes at idle?? gleesamo Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 5 04-06-2007 12:59 PM
CEL, lumpy idle, low injector control circuit, misfires kimmae Normally Aspirated Powertrain 3 03-16-2005 05:22 PM
Fixed my hesitation, flashing CEL, rough idle! Stickee Normally Aspirated Powertrain 0 11-19-2003 09:20 AM
