10-21-2000, 06:14 PM | #1 |
Member#: 2738
Vehicle:2000 2.5RS Silverthorn Metallic |
Higher wattage fog lamp bulbs
Has anyone ever tried to use higher wattage bulbs with the stock 00MY housing and harness?
Obviously the higher current going through the bulbs and wiring harness, is a concern. I have no desire to burn the car down because the insulator burned off the wire causing a short circuit and fire... Nor do I want the excess heat to destroy the fog lamp itself and all the associated connectors. But I wanted to see if anyone has any experience, since buying 2 $6 100 watt bulbs and swapping them in seems way too easy. Any input is appreciated.
10-21-2000, 06:30 PM | #2 |
Miss You Mom
Oct 1940 - Feb 2008 Super Moderator Member#: 809
NESIC
Vehicle:2000 2.5 RS, '14 For 92 5MT SVX |
Some people will tell you they have no problems with 100Watts, some people say they have brown/burnt/cracked reflectors because of it. Somebody isn't telling the whole truth.... as for me, I get people flashing their highs at me already... I don't want to add fuel to the fire.
Brian http://members.nbci.com/_XMCM/northu...reza/index.htm |
10-21-2000, 09:57 PM | #3 |
Member#: 1110
Vehicle:1999 RS Silver |
Highly inadvisable since the entire foglamp circuit is relayed at that little pink relay on the side of the driver's kick panel fusebox. 20 feet or more of 16 and 18 gauge wire lie between the power and the foglamps. With a heavy-duty locally relayed wiring harness there shouldn't be any problem, though.
04 WRX/STi fog lamp bulb type | spool1536 | Electrical & Lighting | 2 | 07-28-2003 11:22 AM |
can i use higher wattage fog bulbs without hurting anything? | NateDogg | Electrical & Lighting | 6 | 03-07-2003 08:21 PM |
00+ Outback Fog Lamp Bulb replacement How-to | Peaty | Legacy Forum | 0 | 11-30-2002 06:06 PM |
Is there a yellow fog lamp bulb? | metoo | Interior & Exterior Modification | 17 | 08-01-2001 11:09 PM |
('93-'01) PIAA fog lamp bulbs | au112 | Impreza Forum | 8 | 05-31-2001 02:04 AM |
