10-26-2000, 07:55 PM | #1 |
Member#: 2736
SCIC
Vehicle:2001 Impreza 2.5RS Aspen White |
Need some suggestions for my seat
Hey guys/gals. I'm a measly 4'11" (due to me having back surgery at an early age) and have a bitch of a time seeing over the dash with the use of pillows. Any suggestions as how to raise the seat so I don't have to use pillows? I'm sliding everywhere since having pillows can't help keep my butt down =p. Thanks guys.
10-27-2000, 09:25 AM | #2 |
Member#: 1837
Vehicle:2000 Impreza RS -BRP -90Accord |
i think maybe u should replace your seat wit one thats able to adjust up&down for height or go to a custom shop and see if they would be able to mount the seats higher.
10-27-2000, 11:30 AM | #3 |
Member#: 1777
South East
Vehicle:2005 LGT #92 FZippy |
Check out the Seat Source. They are out there in CA. They make brakets that have 3 hieght adjusting holes, if you put them on the highest setting, you might be in business. They also might be able to make some custom brakets up for you. Check 'em out www.seatsource.com
10-28-2000, 12:15 AM | #4 |
Member#: 2736
SCIC
Thanks for the ideas guys.
10-29-2000, 06:40 AM | #5 |
Member#: 323
Vehicle:1999 Impreza RS Rally Blue |
You might want to look at the drivers seat out of a Forrester. I was in my buddy's the other day and it is a way better seat than in the RS. Adjustable height, and lumbar support. And with a cursory glance with a tape measure in hand it looks to be the exact same size as in the RS. One thing I did notice was that the seat rails are about 3" higher than the RS. Might be just what you need.
Need some suggestions for online investiging forums | jblaze5579 | Off-Topic | 4 | 03-29-2006 10:42 PM |
Deep puddles + STi = HEADGASKET LEAK!! Need some suggestions for stronger motor ;) | 300blueballs | Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) | 11 | 10-08-2004 07:26 PM |
Need some suggestions for aftermarket trailing arm bushings | Kostamojen | Brakes, Steering & Suspension | 22 | 07-30-2004 10:02 AM |
Need some suggestions for good weed | -=C=- | Off-Topic | 7 | 04-28-2004 09:39 AM |
Need some parts for my 03 WRX | streko | Bay Area Impreza Club Forum -- BAIC | 0 | 12-27-2002 04:58 PM |
