10-25-2000, 11:57 AM | #1 |
Member#: 476
Vehicle:2003 GPW s2000 Former WRX owner |
Hella bulbs
H4, 12v, 60/55w
H4, 12v, 100/80w I know there's a difference in brightness between them...but will the 100/80w work fine without burning out since they are a higher wattage bulb? or will 60/55w be better? Thanks
10-25-2000, 08:03 PM | #2 |
Member#: 1741
Vehicle:1999 Impreza 2.5 RS Rally Blue (Sold) |
With a higher wattage bulb you will probably have to redo the wiring harnesses to be safe. The little reflectors in your headlights will suffer from discoloration as well. A nice shade of golden-brown.
10-25-2000, 11:44 PM | #3 |
Member#: 476
so the higher wattage bulb won't work fine then?
10-26-2000, 07:36 AM | #4 |
GC84Ever
Super Moderator Member#: 301
NWIC
Vehicle:1970 FF-1 & '70 Van 02 WRX/01 RS |
if we can still search in the "old" technical forum - do it!
search for 100W lights... there's like 1000 warnings... "DONT do this without a relay... you'll fry your wiring..." i just got the Hella Xenon's (65W) they are plenty bright... but until i get a relay, no 100W for my car... j. |
10-26-2000, 08:14 AM | #5 |
Member#: 1249
Vehicle:2000 OBS White |
J,
Are those Xenons the "Xenon Replacement Bulbs" (as per Susquehanna MotorSports)or the Optilux Xenons, which cost a bit more but are warrantied? I had a pair of the first type, which were nice, but they burnt out after only 3 months (yes, I kept them clean on install). Been debating on the warrantied ones... |
10-26-2000, 08:28 AM | #6 |
GC84Ever
NWIC
these...
HELLA OPTILUX XENON WHITE REPLACEMENT BULBS from Susquehanna... http://catalog.com/susq/hella/bulbs.htm I really like them so far and would have loved to get the 100W... but too scared of damaging my wiring.... so they will have to wait... j. |
10-26-2000, 09:29 AM | #7 |
Member#: 476
Well I was reading through the old threads and I believe rajah said that the 100W were ok...hrmm lemme see...heres the url about that.... http://www.i-club.com/ubb-files/Foru...ML/001742.html
10-27-2000, 07:02 AM | #8 |
Member#: 1209
I've also run the Optilux 80/100 w/ no problem, but I have the older non-reflector lighting pattern. I don't think the stock wiring will have a problem, as the wiring diagram I saw showed 2 15 Amp fuses, one for each light and 2 separate relays. 15 Amps will handle 15/12= 125 Watts I believe. So that 125 Watts a piece and if the wiring can't handle it, why isn't the fuse set to trip lower???
10-27-2000, 07:09 AM | #9 |
Member#: 1209
my god, I think there are 3 parallel threads running on overwattage bulbs today!
I've run Hella 80Low/100High bulbs w/o problems. a 100 watt bulb will draw 8.3 amps (100 watts/12 volts), and the wiring diagram on my Legacy shows subaru used 2 separate 15 Amp fuses w/ 2 independent relays, one for each light. So I think that's enough of a safety margin, the fuse should blow before the wiring does (um, in principle, that is). As for the stock fogs, there is a single 15Amp fuse and well, that's not good for a whole lot. |
10-27-2000, 08:37 PM | #10 |
Member#: 476
thanks for your input guys...I ended up getting HELLA OPTILUX XENON WHITE REPLACEMENT BULBS H4 60/55W ones
10-27-2000, 09:16 PM | #11 |
Member#: 1110
Vehicle:1999 RS Silver |
Fuses are really just there for damage control in the case of a dead short. The steady-state capacity of the circuit should not be infered from the fuse rating.
It's not as much a problem with the stock headlamp fuses as it is the gauge of the wire and the heat generated by the bulb. 100 watt bulbs, by the way, are usually designed to draw about 8 amps at 13 volts, which is to say that the resistance across the bulb is about 1.56 ohms. If your wiring can only supply 7 amps at 13 volts, then the output wattage decreases to only 1.56*49 = 76 watts. This is one reason you don't want to run high wattage bulbs on marginal wiring. Of course, the wires could get hot enough to burn the insulation off too, and the plugs are likely to melt. Is the $50 it costs for a good wiring harness really too much? |
10-28-2000, 10:06 AM | #12 |
Member#: 2053
i have hella 100w bulbs in my car with no problems plus for an extra bonus there a kick ass yellow color, not like that ricey blue look most cars have no offense
~~PeAcE~~ John |
02/03 Fogs + hella Bulbs | Naarai | Private 'For Sale' Classifieds | 2 | 08-24-2005 02:27 PM |
My new 78321 Hella bulbs look yellow? | Butt Dyno | Electrical & Lighting | 1 | 04-01-2003 10:56 PM |
Hella bulbs | au112 | Interior & Exterior Modification | 4 | 04-02-2001 07:59 AM |
Hella bulbs | au112 | Vancouver Impreza Club Forum -- VIC | 7 | 03-26-2001 12:58 AM |
