Welcome to the North American Subaru Impreza Owners Club Sunday August 28, 2016
Old 08-05-2004, 08:17 PM   #1
dizzysti
Member#: 61034
2004 STI
Default STI Accessport dyno #'s. Let's see them.
Post dyno numbers for Accessport stage 1 and 2.
Please include the type of dyno.
I am interested in seeing what others are putting down.
304 hp
333 ft/lb torque
On a dynojet. (reads a little high)
93 octane Stage 2 Map with TBE
dizzysti is offline   Reply With Quote
Old 08-07-2004, 01:50 PM   #2
eshtog
Member#: 61938
2006 BMW 330i
yeah I would also like to see dyno numbers
eshtog is offline   Reply With Quote
Old 12-29-2004, 02:52 PM   #3
tubbytreats
Member#: 35104
02 WRX TD0518G 7cm
www.daytonsubies.com
You might want to specify WRX vs. STI AP Stage2 numbers.... The title doesn't differentiate.
I have a friend who just tested his 2004 WRX sedan on AP Stage 2/93 and pulled 255 WHP on a Mustang Dyno in Texas this week. Stock STI pulls 255 WHP and Stock C5 Corvette pulls 285 WHP on this same dyno.
tubbytreats is offline   Reply With Quote
Old 12-29-2004, 08:23 PM   #4
finnRex
A. Moderator
Member#: 21095
RIP KTH & LMFH
'09 Crystal red Tintcoat
STi, stage 1, 93 octane. I got 273 hp/293 ft.-lb. on a Mustang dyno. Done at FIS a few months back, about 85-90 in shop, 60% humidity.
Another guy with a Stage 2, 93 octane made a run. He had an APS 3.5" TBE, and he got 290 hp/308 ft.-lb. on same dyno(same day, same temp).
Mika
finnRex is offline   Reply With Quote
Old 12-29-2004, 08:41 PM   #5
5spdfrk
Member#: 46407
blew
This is a good thread. I am more intersted in the wrx numbers seeing as though I am looking into getting an AP.
The STi numbers are good to see as well though.
5spdfrk is offline   Reply With Quote
Old 12-29-2004, 09:32 PM   #6
Longfury
Member#: 36047
2013 BRZ
Galaxy Blue
AP is a big interest for me as well. For the level of engine mods i wanna do(UP,TBE and maybe a P&P on the turbo) AP is looking like a good option. I also like that its cheap and i can change maps myself.
So you WRX guys get in here and post.
Longfury is offline   Reply With Quote
Old 12-30-2004, 12:13 AM   #7
slickvic
Member#: 29727
2003 Impreza WRX
I second that
slickvic is offline   Reply With Quote
Old 12-30-2004, 12:21 AM   #8
Drews_WRX
Member#: 20354
2005 SRT-4
POS Mopar stage 2
Cobb stage 1 91 octane. Harman Motive dynojet.
191 hp
194 torque
Peak boost was 13 psi...dont know why. Im guessing it should have been ~207hp/220 ft/lbs if I hit "target boost"
Drews_WRX is offline   Reply With Quote
Old 12-30-2004, 09:00 PM   #9
darkstarmoto
Member#: 44681
2011 WRX SWP Hatch
www.48hrs.info group lead
I think I'm reading my dyno chart wrong..maybe. With just a Borla cat-back and otherwise stock (AP not istalled yet) I pulled:
192.38 HP (SAE corrected)
217.81 torque
53F, 29.5 in-Hg, 33% humidity on a DynoJet 424x (I think).
Am I reading this wrong?
darkstarmoto is offline   Reply With Quote
Old 12-30-2004, 09:02 PM   #10
5spdfrk
Member#: 46407
blew
Wow! That is really high, especially the torque. I would say that you are reading it wrong or you have a factory freak.
Scan it if you can and post it up.
Old 12-30-2004, 09:05 PM   #11
04stiblk
Member#: 57265
04 Milano Red STi
more air than EVERRRR
306/311 on a dynojet in pa. sti.
04stiblk is offline   Reply With Quote
Old 12-30-2004, 09:27 PM   #12
yobtah
Member#: 48939
This article describes SAE correction on a DynoJet being invalid when applied to a turbo engine. The article claims SAE correction will result in inaccurately high numbers for a turbo engine. Basically it says SAE correction from DynoJet numbers shouldn't be used for turbo engines.
217.81 torque
yobtah is offline   Reply With Quote
Old 12-30-2004, 09:30 PM   #13
darkstarmoto
Member#: 44681
2011 WRX SWP Hatch
I can e-mail it as a pdf....if someone wants to read it and tell me if I'm mistaken.
Also, should i use any correction (if SAE isn't considered viable)? Even using UNCORRECTED) I have even higher #'s:
198.53 HP
224.95 TQ
Old 12-30-2004, 09:46 PM   #14
yobtah
Member#: 48939
Sure... email it to me if you want. I'm guessing you're reading the dyno plot correctly... I doubt that's the problem. Have you done any modifications? If not, it sounds like the dyno or the shop is trying to approximate crank power numbers.
198.53 HP
224.95 TQ
Old 12-30-2004, 10:01 PM   #15
darkstarmoto
Member#: 44681
2011 WRX SWP Hatch
I need an e-mail addy...I can't attach a pdf to the board e-mail....
Old 12-30-2004, 10:08 PM   #16
yobtah
Member#: 48939
PMed email address to you...
Old 12-30-2004, 10:36 PM   #17
REDrum
Member#: 61536
WRX' 04Road02gravel
www.ToltecRally.com
Default WRX pulls on DD in NE
To chime in, I pulled 159whp on a Dyno Dynamics with only a cat back exhaust. (not bone stock but insignificant in HP gains) A guy right after me pulled 214whp w/ Cobb/AP stage 2 (STi UP, SSDP, Prodrive muffler)
So, there ya have it ~55whp gain w/ stage 2. DD dynos are know for being lower than others, so delta increase in Hp & Tq is all that can be used for statistical reference. FWIW...
N
REDrum is offline   Reply With Quote
Old 12-30-2004, 10:42 PM   #18
ms3p
Member#: 51596
2014 FiST
2006 SV650S blue hotness
Very nice #s
ms3p is offline   Reply With Quote
Old 01-01-2005, 01:20 PM   #19
5spdfrk
Member#: 46407
blew
For those of you w/ a wrx and an AP, are you seeing unusually high egt's?
Old 01-02-2005, 02:28 AM   #20
dogWagon
Member#: 61558
04 wrx wgn silver
04 WRX, pde uppipe, randomtech dp w/2 high flow cats. Stage 1 my egts were in the 1400-1600 range when i got on it, depending on gear and load, if I was going up an hill it would be closer to 1600.
when I went to stage 2 my numbers came down a little still in the 1400-1500 range, egt in the header. Couple inches from the block.
no dyno yet, but i will get in done soon
dogWagon is offline   Reply With Quote
Old 01-02-2005, 11:45 AM   #21
gjhsu
Member#: 12329
2o15 WRX
Ice Silver
02 WRX, stage 1, uppipe, intercooler hoses, catback
224.1 lb-ft
229.5 hp
gjhsu is offline   Reply With Quote
Old 01-02-2005, 12:08 PM   #22
REDrum
Member#: 61536
WRX' 04Road02gravel
www.ToltecRally.com
224.1 lb-ft
229.5 hp
Whats the delta over stock dyno results? What dyno? Unless you are baselining stock ~190 whp, those #'s are hard to accept. They're closer to AP stage II.
Old 01-02-2005, 12:12 PM   #23
gjhsu
Member#: 12329
2o15 WRX
Ice Silver
Mustang dyno that dynos stock STis at 240-250. This was my first time on the dyno. I take what I can
Old 01-02-2005, 06:14 PM   #24
REDrum
Member#: 61536
WRX' 04Road02gravel
www.ToltecRally.com
W/o a baseline/stock pull of your car, this graph is meaningless. Cobb uses a Mustang dyno and baselines ~170 for a stock rex. Yours is the first posting I have ever seeing w/ a presumed delta HP of near 60 w/ stage I and an UP & CB. Good for you if you got it, but it is an anomaly.
Any Nos in there
Old 01-02-2005, 06:21 PM   #25
dogWagon
Member#: 61558
04 wrx wgn silver
Any Nos in there
meaningless to you maybe, how many people actually have dyno runs on there stock car.
his numbers are what they are.
Let's see them Automatics! Drektek Member's Car Gallery 56 11-29-2009 09:44 AM
Let's See them White Wheels... chad1043 Member's Car Gallery 40 03-22-2008 06:28 PM
SO CAL Coupes...Let's see them!! codemunky Southern California Impreza Club Forum -- SCIC 45 09-18-2005 12:43 PM
Wide Body Wagons - Let's See Them wrx182 Interior & Exterior Modification 5 12-14-2001 05:45 PM
