10-19-2000, 09:02 PM | #1 |
Member#: 2725
Vehicle:98 Subaru Black |
shift light
I just got an autometer shift light for my 98 2.5RS and it says to hook up one of the wires to the negative terminal on the coil. I got the wire to the coil but there is no neg. terminal that I can see and just 3 wires going into the coil... which wire is it. Any help will be appreciated, thanxs
10-20-2000, 09:09 AM | #2 |
Member#: 1477
Vehicle:2003 wrx wagon silver |
Since the coil is pushing big electrical loads, the neagative terminal will have a lead that goes to a soild negative ground-- either the engine block or the negative terminal on the battery. Look which one of the three leads goes to one of those two places?
Someone tell me if I'm off the mark here, but I think this makes good sense. |
10-21-2000, 12:31 AM | #3 |
Member#: 188
Vehicle:2004 Forester XT 24k gold on white |
IIRC, you can simply hook it up to the RPM signal at the ECU. It is easier than hooking it up to the coil. Check your MY98 ECM wiring harness diagram.
nizz |
Ecliptech Shift-I Sequential Shift Light Install and Review. | bushflyr | Electrical & Lighting | 6 | 10-21-2007 10:37 PM |
FS: 'On dash' gear shift indicator display w/shift light | RS WRC | Private 'For Sale' Classifieds | 25 | 03-10-2006 03:37 PM |
'On dash' gear shift indicator display w/shift light | RS WRC | Interior & Exterior Modification | 2 | 09-29-2005 12:19 PM |
kartboy shift knob, stock uppipes, razo shift light | anthonyrb98 | Private 'For Sale' Classifieds | 14 | 09-29-2004 12:57 AM |
Using Instrument Cluster Light as Shift Light/Any Ideas? | jikhead | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 1 | 06-21-2003 09:08 PM |
