Welcome to the North American Subaru Impreza Owners Club Sunday February 1, 2015
View Poll Results: Whats your max advance?
20 or less 6 20.00%
21 1 3.33%
22 6 20.00%
23 0 0%
24 4 13.33%
25 6 20.00%
26 or greater 7 23.33%
Voters: 30. You may not vote on this poll
Old 08-06-2004, 10:01 AM   #1
cdvma
Member#: 21980
2002 PSM WRX (Sold)
2009 BMW X5
Default Your max advance?
I'm curious as to what people are running for their maximum timing values and their various setups. I'm most interested in VF22s and 93 pump gas on an EJ205. Please if you vote in this poll also reply and explain briefly the setup, as obviously not all setups are the same. Any comments on the timing is also appreciated. For example
VF22, EJ205, TXSv1 TMIC, one cat, 93 pump, 25* max, 20/21 PSI @ 10.8:1 AFR. I'm thinking of taking out a degree of timing because it knocks occationaly on brisk days in the upper gears.
Since there is confusion from someone, this is my attempt to clarify exactly what I intended to ask about in this thread: please specify the maximum timing advance you use while under full load conditions. So for example what the highest value in the 100 load site if you have a UTEC is (and if you feel like specifying, the RPM value as well).
Thank you.
cdvma is offline   Reply With Quote
Old 08-06-2004, 12:57 PM   #2
Blennophobic
Member#: 25886
2003 WRX Rally Blue
- sold, waiting for 2015s
EJ205, SR-30 @17psi, TBE w/3" cat, 10.2:1 AFR, on 91 pump.
running 22*max at 6500 due to the crappy gas... WI coming next!
Steve.
PS. Chris: this has the makings of a great thread. Can someone with lots of tuning experience tell me if I'd make more power by running leaner with less advance?
Thanks.
Blennophobic is offline   Reply With Quote
Old 08-06-2004, 01:31 PM   #3
happasaiyan
Member#: 37731
19* for me.
EJ257 SR50 @ 19psi
dr500 + TBE
11.1:1 AFR on 93oct.
happasaiyan is offline   Reply With Quote
Old 08-06-2004, 02:25 PM   #4
big_adventure
Member#: 40501
2005 Decathalon 21sp
One WheelSeanPower
Steve.
Thanks.
10.2:1 is way, way rich. Try running around 10.7:1 or maybe 10.8:1 on that gas through the torque peak, leaning out to 11.0:1 up top. You should be able to run even more timing on a TMIC. If you have an FMIC, that's probably as good as it will get pouring YooHoo into the tank.
-Sean
Last edited by big_adventure; 08-06-2004 at 02:36 PM. Reason: I'm a very stupid boy...
big_adventure is offline   Reply With Quote
Old 08-06-2004, 02:28 PM   #5
big_adventure
Member#: 40501
One WheelSeanPower
Oh, and 26.5 points at 8500 on pump, 31.5 on c16.
RA-C, GT30R
Old 08-06-2004, 02:32 PM   #6
happasaiyan
Member#: 37731
Originally Posted by big_adventure
10.2:1 is way, way lean. Try running around 10.7:1 or maybe 10.8:1 on that gas through the torque peak, leaning out to 11.0:1 up top. You should be able to run even more timing on a TMIC. If you have an FMIC, that's probably as good as it will get pouring YooHoo into the tank.
-Sean
im thinking you meant rich?
Old 08-06-2004, 02:37 PM   #7
big_adventure
Member#: 40501
One WheelSeanPower
I don't know how I made such a typogrphical error. Imagine it, I hit four completely wrong letters, and they spelled a real word that just happens to mean the opposite of what I intended. Incredible!
Thanks - I edited my idiocy.
-Sean
Old 08-06-2004, 02:38 PM   #8
Blennophobic
Member#: 25886
2003 WRX Rally Blue
-Sean
Thanks Sean... I don't want to get too far OT for this thread. I'll just say that I'm thinkin I should try different gas because I was knocking at 10.5:1 and 22* of timing so I richened it up... maybe I should have lowered timing first?
Old 08-06-2004, 02:42 PM   #9
big_adventure
Member#: 40501
One WheelSeanPower
Probably, just watch your EGTs. Also, what was the temp?
Old 08-06-2004, 02:43 PM   #10
Macabre
Member#: 3841
2004 WRX Wagon
UTEC+VF22+WI
Picture's worth a thousand words. Anyways, VF22, EJ205, stock TMIC, 100+ degree ambient temps, 91 octane RFG gasohol. Should have WI installed this weekend or next... I run more timing and less fuel than this in my "winter" map, but that is more knock sensitive than I like in the summer.
Macabre is offline   Reply With Quote
Old 08-06-2004, 03:03 PM   #11
Blennophobic
Member#: 25886
2003 WRX Rally Blue
Temp was unseasonably hot for us in PNW (pushing 90*) when I was tuning. Max EGT I get is 800C which is not bad. I should have some room to move now that the ambient has cooled off.
Steve.
Old 08-06-2004, 03:26 PM   #12
gpatmac
Member#: 18446
2002 WRX wagon
psm
For Aeons, my fried Is2Scooby and I were spending so much time with WB kit in order to just see 11.1:1 in the upper RPM band. Cars were pretty much generic TXS UTEC stage 4's except made up of many different brand name parts. We both generally used some sort of Xylene or Toluene mixture to bring octane to between 95 and 96. We were also both boosting to a peak of 20.5 or so with both of our gains being pretty agressive (I know I was hitting 14psi in 1st gear after about 4-5 (?) cycles...a UTEC cycle equating to about 100 crank cycle, if I recall). I used the UTEC to control boost and he was using the JoeP.
Annnnyhow, for probably 6 months, we both slowly whittled our times/traps down from 13.5/99 to 13.0/100 or so. Then, the fateful day came where we were both getting near the end of our patience and so I ramped up my timing map by +2 across the board so that I would peak at 26 DBTDC, and viola! 12.9/104.0, 12.8/104.4, 12.798/104.6. For months, we were leaving the track at the end of the night, twice a weekend, so frustrated at our inability to tune with the UTEC, that we both almost sold them for like $100. Finally, the light seemed to turn on.
As a side note; if you have the techedge like we were using at the time, PM me for our tuning technique in using it. It required 3 people, a laptop, and a videocamera...and a lot of open highway (which is difficult to come by on Oahu.
gpatmac is offline   Reply With Quote
Old 08-06-2004, 03:39 PM   #13
Blennophobic
Member#: 25886
2003 WRX Rally Blue
gpatmac... let me get this straight: you couldn't go any leaner without getting knock but you could add 2 deg timing without causing knock? A function of your net octane rating after additives I guess.
Old 08-06-2004, 04:33 PM   #14
gpatmac
Member#: 18446
2002 WRX wagon
psm
No, we were erring on the side of more fuel/higher timing than less fuel/lower timing. We set 11.5 as the goal as opposed to tuning fuel until we start seeing knock, if that makes any sense.
We were abiding by the philosophy that with a tad little bit more fuel (safety buffer), we could afford to ramp up higher in the higher rpm/higher mlp, especially since we believed that the higher timing value would tend to run a bit cooler up there. Since then, I've even experimented with ramping to 27 and 28...without knock. (I don't do that very often, though.)
Have you had a chance to look at Mick_the_Ginge's UTEC tuning guide? He has it posted for download over at WRXHackers....Here's the link. (right click/save as.)
Here's the page that discusses what I'm referring to.
Old 08-06-2004, 07:35 PM   #15
hippy
Member#: 36528
2002 Impreza Wrx
vf34, muffler silencer(on road) 10.8 to 1 20-21 degrees at 18psi. about 23 without the muff silencer
water injection, 12 to 1 a/f ratio about a 10.5 to 1 air/liquid ratio..27 degrees with muff silencer..... I dunno what without
Old 08-06-2004, 08:08 PM   #16
jblaine
Member#: 8512
2002 WRX chassis...
stage-infinity.com
24 degrees from 6200 onward.
up-pipe
TXS stealthback with cat
IC hoses
Vishnu Stage 1 EcuTek reflash
11:2 AFR
1400 EGTs
16 IAM, 8 to 11 knock correction
jblaine is offline   Reply With Quote
Old 08-06-2004, 11:26 PM   #17
Jon [in CT]
Member#: 2992
02 WRX Sedan
These are all pitifully low values for "maximum ignition advance." I can easily achieve over 40 spark advance running 91 octane without leaving my driveway. That's with a stock turbo but it wouldn't matter if I slapped on the biggest honkin' turbo that anyone's ever bolted onto a WRX. No water/alcohol injection and no knock.
Jon [in CT] is offline   Reply With Quote
Old 08-06-2004, 11:37 PM   #18
pegdrgr
Member#: 25693
2008 18x9" goodness
E85-380ftlbs @ 3100
Man Jon you can be such an ass!
To clarify at low load situations your stock ECU will seek 40 degrees advance. Clearly the scope of this conversation was intended to only cover full boost situations, or high load situations.
Jon once again you have proven your posts can be totally useless. Try working on adding something to a discussion.
pegdrgr is offline   Reply With Quote
Old 08-07-2004, 12:14 AM   #19
cdvma
Member#: 21980
2002 PSM WRX (Sold)
2009 BMW X5
Yep, you nailed it. Sorry, Jon, I should have been more specific with my request. All this info is great guys, thanks for the input and lets keep it coming...
Old 08-07-2004, 09:23 AM   #20
ride5000
Member#: 32792
2003 GGA MBP
12.9 / 105+
jon, it seems counterintuitive, but a larger, more efficient turbo compressor along with a freeer-flowing turbine will end up using LESS advance. this is due to the greater VE and correspondingly denser in-cylinder charge causing a more rapid flame front propigation.
fwiw, i'm running a stocker, map dips to around 1 bar at redline (poor little turbo! ), and i run 29* @ 7k across the whole row.
ken
Old 08-07-2004, 10:54 AM   #21
TheMadScientist
Member#: 23717
2005 Big red
For a TXS stage2 WRX I used to run 29* at 7000 on sunoco 94 when we had it. I really don't know what the A/F was but it was below 11.3:1, that was as low as I could read. Now on the 93 I think the guys have to pull at least 1.5* out of that map some times more.
TMS
TheMadScientist is offline   Reply With Quote
Old 08-07-2004, 05:46 PM   #22
Jon [in CT]
Member#: 2992
02 WRX Sedan
Sorry, but this is nonsense. Advance tables are indexed by load (air ingested) and RPM. Suppose two engines, one with a stock turbo and the other with a larger more efficient turbo, are operating such that each is inducting identical amounts of air (as indicated by the MAF sensor) at, say, 7000 RPM. That means that each is using the same "cell" from an ignition advance table because the cell is indexed by RPM and load. Since, in this case, each cylinder of each engine is ingesting the same amount (mass) of air during its intake phase and since volumetric efficiency is defined as a mass ratio, the two engines are operating with identical volumetric efficiency. And, since density is defined as mass/volume, the density of the intake charges are identical, too.
The point of my post was that it's pointless to compare ignition advance without speicifying both the RPM and the load at which it occurs. My example involved a high-rpm low-load situation. Try it yourself. Put the car in neutral. Gradually rev the engine up to 6800 and try to hold it there without changing throttle position. Once you're able to hold that RPM without adjusting the throttle pedal, observe the ignition advance.
Old 08-07-2004, 05:56 PM   #23
pegdrgr
Member#: 25693
2008 18x9" goodness
E85-380ftlbs @ 3100
Jon the problem is that most of the people on this forum are using the UTEC to control the timing, at least the ones that can change the timing values themselves. So those people are not setting them based on true load, as in mass of air. They are doing it based on the boost pressure that they are running. You are absolutely right to say it is more valuable to discuss the timing that they are running based on MAF voltage, but the rounding that the UTEC does makes that just to coarse.
Why not try to be helpful instead of putting up cryptic nonsense that is probably not going to be recieved well, or as you intend. I am now assuming that your intent was to be helpful in this case....
Old 08-07-2004, 05:59 PM   #24
gpatmac
Member#: 18446
2002 WRX wagon
psm
Jon,
Were you not able to get the gist of the post? Why detract and lead the thread in the wrong direction. You know he was asking about high rpm/high load, or weren't you able to intuit that?
What's your max timing values during high rpm/high load? Answer and hit reply. Simple as that.
Old 08-07-2004, 06:05 PM   #25
Jon [in CT]
Member#: 2992
02 WRX Sedan
Originally Posted by gpatmac
Jon,
There's precision for ya - "high load." Well, then, I run "lots" of advance at high load.
AVCS: Max advance on a built motor research results rlavalle Built Motor Discussion 68 10-24-2013 02:05 PM
Hey '04-'08 Nissan owners, want your timing advanced? SaabaruMike South West Impreza Club Forum -- SWIC 6 01-21-2009 05:30 PM
Wagon owners - post your max neg. camber with stock struts nocturn Brakes, Steering & Suspension 12 07-19-2004 03:53 PM
Whats your max boost, and what mods? chrislehr Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 04-13-2003 12:05 PM
Tell me your Ignition Advance... JenisonWRX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 5 09-26-2001 12:25 PM
