Welcome to the North American Subaru Impreza Owners Club Saturday September 24, 2016
Old 08-06-2004, 02:57 PM   #1
WRXout
Member#: 52908
2005 WRX STI FTI 20G
ASPEN WHITE
Default EBC with Ecutek bad?
peopel tell me that ecutek is bad with a EBC, im have vf30 with perrin fmic, and i hit 17psi at 4300rpms an di have an automatic
WRXout is offline   Reply With Quote
Old 08-06-2004, 05:38 PM   #2
WRXout
Member#: 52908
ASPEN WHITE
bump
Old 08-06-2004, 05:41 PM   #3
cnk
Member#: 10757
2013 BRZ Limited 6MT
You're not very clear in your post. . .so are you asking about using a EBC or you're stating that you have one? Technically, you don't need to use one as the reflashed ECU handles the boost control.
Calvin
cnk is offline   Reply With Quote
Old 08-06-2004, 05:45 PM   #4
WRXout
Member#: 52908
ASPEN WHITE
Calvin
i have had a greddy e-01 for the 20,000 miles on it and i get a reflash for my vf30, im hitting full boost at 4500rpms think that has to do anything with my ebc?
Old 08-06-2004, 07:02 PM   #5
cnk
Member#: 10757
If you got a reflash, the tuner should have told you what to do. For my Vishnu reflash, Shiv sent me a bleeder valve that I use so that I can hit 17psi. I hit boost around 3300rpm. I would take the EBC off and reconnect the FBC and see if that improves things.
Calvin
Old 08-07-2004, 01:24 AM   #6
WRXout
Member#: 52908
ASPEN WHITE
Calvin
gonna do it tommorow
JDM pink injectors, vf30 with ewg flange welded, 02 03 ecu with ecutek BIGDADDYG Engine/Power/Exhaust 15 10-15-2009 09:44 AM
Advantages of MBC/EBC with vf39/ecutek tune? Blown95ImpalaSS Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 7 06-19-2006 06:20 PM
Is 3/16 mod good or bad idea with ecutek? rtd2 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 10-02-2003 05:57 PM
Running Mbc/ebc With Ecutek RED WORKS(WRX) Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 03-30-2003 03:22 PM
EBC vs Unichip - Bad advice? 143paul Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 04-22-2002 10:19 PM
