Go Back   NASIOC > NASIOC Subaru Models > 'Old School' Subaru Forum
Old 08-09-2004, 10:28 PM   #1
o3burn
Member#: 67864
1985 GL 4dr
white
Question Idle RPM
Could anyone tell me:
A. What RPM should my 85 GL idle at.
B.Where in the heck is the idle adjust screw?
BTW it is a carb. equiped car.
o3burn is offline   Reply With Quote
Old 08-09-2004, 11:58 PM   #2
Flowmastered87GL
WCSS Drunk
Member#: 8914
2005 Baja Sport
Regal Blue Pearl
I think its like 700 manual tranny and 800 automatic. Should say under the hood (on the labels on it)
Its hard to remember how hitachis work... but there may be a screw which more or less pushes the little cam that the throttle cable pulls on so that it doesnt let it close more than a certain amount.
If its idling too low you could always just tighten up the throttle cable afew turns too (not really a cure, but could work as a temporary fix) The car SHOULD be able to idle with no throttle connected up to it at all.
There is an idle mixture screw on the front of the carb. I think mechanics had to drill out part of the body to get to it is a rumor I heard, but all the carbs I had always had it accessable. Its a flathead screw bottom center on the carb.
Flowmastered87GL is offline   Reply With Quote
Help! Needle drop lower than idling RPM?? kalasend Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 7 05-07-2003 09:11 AM
Raising the idle rpm speed PaulRex Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 10-17-2002 08:51 AM
High idle RPMs and throtlle blips when shifting Holograph Service & Maintenance 9 09-19-2002 02:53 AM
Idle RPMs? willguidry Normally Aspirated Powertrain 12 03-28-2002 12:33 AM
('93-'01) Lowering idle RPM? tonytiger Impreza Forum 4 05-14-2001 02:34 PM
