Welcome to the North American Subaru Impreza Owners Club Sunday February 14, 2016
Old 08-06-2004, 11:00 PM   #1
CoastGuardSuby
Member#: 56703
2007 STI Limited
Grey
Default i need a utec map!
need an utec map for
headers
uppipe
tbe
ic pipes
im runnin a stock ic, and i cant get my car to boost at a regular level. i cant tell if its leakin or its just the turbo. i need a map for optimum performance with headers. please help!
CoastGuardSuby is offline   Reply With Quote
Old 08-06-2004, 11:42 PM   #2
pegdrgr
Member#: 25693
2008 18x9" goodness
E85-380ftlbs @ 3100
You should be able to hit normal boost with a stock map from TurboXS. If you are not able to do that, after adjusting the boost map, then you have a mechanical problem. If you are able to build boost but are knocking, then you need a tune.
If you slapped in a standard map and are not building boost try raising the boost map numbers 20-30 at a time, go drive and see what your boost level is. Repeat until you have attained your target boost.
Just sticking in someone elses map is not a good idea. You need to understand what it is that you are putting in there. If you do not understand that you should only work with a TurboXS base map.
pegdrgr is offline   Reply With Quote
Old 08-07-2004, 12:17 AM   #3
cdvma
Member#: 21980
2002 PSM WRX (Sold)
2009 BMW X5
I'd add to pegdrgr's comments that you should also check the installation of your ABC and confirm its properly setup.
cdvma is offline   Reply With Quote
2003 wrx w/ 2.5L, need a UTEC Map WjRgX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 01-12-2005 03:57 PM
need vf22 utec map plus fmic moorebl Engine Management & Tuning 0 11-27-2004 12:39 AM
Need STi Utec Map wrxyboy Engine Management & Tuning 4 07-03-2004 09:44 AM
Need a utec map for 800cc injectors. oldbluwrx Engine Management & Tuning 6 05-15-2004 08:13 PM
I need a utec map for a vf22 please help 2002whitewrx Engine Management & Tuning 5 05-12-2003 04:29 PM
