Welcome to the North American Subaru Impreza Owners Club Saturday October 22, 2016
Old 08-07-2004, 12:42 PM   #1
Member#: 52908
2005 WRX STI FTI 20G
Default to laggy
well its heres my deal i got a ecu flash from kingpin , and map clark a.k.a azscoobie built me. as it hits boost the car start to kick then when it hits 4500rpms it hauls ass..
i have a 4eat, automatic tranny.
my mods:
+Perrin FMIC**
+565cc Sti Injectors
+Walbro 255lph Fuel Pump
+helix upipe
+invidia downpipe
+blitz full racing catback exhaust
+Perrin Lightened Crank Pulley
my ecu tek is sort of a custom map but didnt get to play with it on the dyno, he built one map could falsh the ecu, so i boguht an ecu from kingpin and he flashed it..
i put a star next to perrin fmic cause i was thinknig maybe thats why it lags so bad but has killer topend!
its 100ferenhiet her in houston and 80% humid, is this why? think c02 spray to the intercooler will fix my problem?
WRXout is offline   Reply With Quote
Old 08-07-2004, 01:07 PM   #2
Newbie Subie
Member#: 20214
07 Acura RDX
390WHP no more
I have an almost identicle setup as yours as of yesterday.... but no reflash/manual/TMIC
SR40 now but....
Based on my knowledge that I have had the VF30 combination for over 50000 miles I can say that something is a little messed up my VF 30 kicks in hard at around 2800-3000 RPM. The VF30 should spool much earlier than 4500 RPM even with the FMIC. Do yourself a favor and buy DeltaDash and do some logs. Send them back to Clark and have him adjust it.
With DeltaDash you can load in the new map that he provides you without sending the ECU back.
As far as O2 spray, I doubt it will have any effect on your spool, may run a bit cooler and aide in knock supression.
Newbie Subie is offline   Reply With Quote
Old 08-09-2004, 12:19 AM   #3
Member#: 41252
Twin 2005 600WHP
FormulaD/TimeAttack Sti's
Yeah it still seems a bit laggy to me. Some logs would be great if you have them. Bosst leak is most common cause of lag that we see. Might want to recheck all of your FMIC pipes. Even a small leak can cause considerable lag. The FMIC has some effect but I would exspect it to be on ealrier than it is. Let me know so that we can help sort this out. Thanks.
Kingpin is offline   Reply With Quote
GM to invest $245 million to build a new six-speed transmission AVANTI R5 Non-Subaru News & Rumors 12 06-07-2010 07:25 AM
vf22 is it to laggy wrxracer3 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 07-16-2004 10:40 PM
laggy boost SM DONK Southern California Impreza Club Forum -- SCIC 5 11-20-2002 04:22 PM
question for vf30 and laggy turbo owners datdudedennis Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 6 10-28-2002 03:17 PM
Shifting a high power laggy turbo car... d00f Transmission (AT/MT) & Driveline 3 01-08-2002 08:49 PM
