Welcome to the North American Subaru Impreza Owners Club Sunday March 1, 2015
Old 08-07-2004, 09:39 PM   #1
seven881
Member#: 8828
01 BRP 2.2T Hybrid
10 VW Grocery Getter
Impreza GC8 Link Plus And TPS Sensor Issue
Well, I've narrowed down the issue to my TPS sensor and the link plus. It looks like when I have the car at WOT and about 18 PSI the TPS signal is jumping around and it's blowing out the spark with fuel when the signal spikes. I haven't replaced the TPS sensor, but when I'm in wastegate boost (about 8 PSI) I can floor it without the TPS sensor freaking out. Any ideas?
seven881 is offline   Reply With Quote
Old 08-07-2004, 10:17 PM   #2
subiekid
Member#: 25516
1995 Legacy TURBO!!!
EJ22T/TEC3 & '12 Civic
Where is the TPS sensor getting its power? fromthe link or still powered from the stock location? I am guessing stock since you are blowing fuses. Does the link wire into the oem harness or is it plug and play?
subiekid is offline   Reply With Quote
Old 08-08-2004, 12:40 PM   #3
seven881
Member#: 8828
01 BRP 2.2T Hybrid
The TPS sensor is getting it's power from the stock location and I have a plug and play harness. I do remember reading about interferance problems with some of the WRX link boards, but I don't know if that's related to this.
Old 08-09-2004, 01:42 AM   #4
subiekid
Member#: 25516
Well I have read that the stock TPS power can fluctuate. I have noticed this while running my TEC 3 when I first start the car closed throttle is .57volts after driving the car for about 15 minutes it jumps up to .61 then I let the car sit and it will drop back down to .57. I plan to switch over to the power for the TPS that the TEC gives, but since you have a plug and play harness you can really change it.
link plus and piggy backs scubydrew Private 'For Sale' Classifieds 2 06-06-2005 03:38 PM
Link Plus and MAP signal (MY00 2.5RS) erice1984 Engine Management & Tuning 3 03-05-2005 04:27 PM
FS Link plus and SAFC II Elliot Private 'For Sale' Classifieds 11 08-26-2004 07:47 PM
link plus air intake sensor White 2.5rs Engine Management & Tuning 1 08-20-2004 04:33 PM
Link plus and A/F ratio gauge? PunKidd Normally Aspirated with bolt-on Forced Induction Powertrain 14 06-20-2002 09:21 PM
