Old 08-07-2004, 09:36 PM   #1
Capt Crunch
Member#: 10852
Then : JDM Ver 7 STi
Now : E46 M3 / MKVI GTI
Default Quick! What is better? Sti brembos or Stoptechs?
I had stoptechs, but disliked them because of pad knockback. However I am now doing an sti swap that included sti brembos. Because the swap has sti hubs, with beefier bearings, I'm pretty sure the pad knockback would go away with my stoptechs. I have the option of using either set, so which should I use and why?
Also, whichever set I don't use will be up for sale
Thanks
Ben
Capt Crunch is offline   Reply With Quote
Old 08-08-2004, 03:02 AM   #2
RokketRide
Member#: 17984
1967 Barracuda
Do the stoptechs have 2-piece discs? That would save some unsprung & rotational weight.
And you are right, the pad knockback issue is a matter of the hubs/bearings, so either brake setup would be similarly affected.
RokketRide is offline   Reply With Quote
Old 08-08-2004, 09:27 AM   #3
T-WRX
Member#: 2468
08 Audi RS 4
05 AW STi
Are you doing an '04 or '05 STi swap? The '05s are beefier, but you will need new rims in the '05 bolt pattern.
T-WRX is offline   Reply With Quote
Old 08-08-2004, 10:14 PM   #4
FLEMON
Member#: 64806
What the difference between the 04 Brembos and the 05's..?
FLEMON is offline   Reply With Quote
Old 08-08-2004, 10:27 PM   #5
majmun
Member#: 18298
2004 STi
The brakes are the same. The hubs and bearings are larger in the '05 - hence "beefier". You will need new wheels because the stud spacing was increased from 5x100 to 5x114.3.
majmun is offline   Reply With Quote
Old 08-08-2004, 10:31 PM   #6
Leonardo
Consigliere
Super Moderator
Member#: 185
2009 Smart ForTwo
Flemon, please contact iON for the rotors you special ordered from them!
Leonardo is offline   Reply With Quote
What Is Better? Catless Dp Or Catted Dp?? MRSTI28 Newbies & FAQs 41 06-20-2008 07:01 PM
what is better a ea82t or a ea81t? mallion 'Old School' Subaru Forum 16 08-27-2004 06:21 AM
GT3 What is better the race or the replay? elanSTI Off-Topic 7 07-17-2004 02:56 AM
STI brembos or SToptech? azimiut Brakes, Steering & Suspension 8 01-05-2004 10:47 PM
ot: what is better buy modem or lease Amazake New England Impreza Club Forum -- NESIC 19 05-17-2002 07:49 AM
Message Board Statistics All times are GMT -4. The time now is 10:19 PM.
