Go Back   NASIOC > NASIOC Subaru Models > 'Old School' Subaru Forum
Old 08-08-2004, 09:11 PM   #1
o3burn
Member#: 67864
1985 GL 4dr
white
Cool 85 GL Turbo or not????
Someone gave me an 85 GL. It needed a water pump. When I went to replace it the auto partsd store gave me the "wrong" one. The counter guy said what I had was a turbo water pump. Thinking, "tht's strange" I continued to work on this car. Today while cleaning up under the hood, I found a boost sensor, this runs to a module that sets between the carb and the manifold. What is up is it a turbo or not????
-thanks
-btw this one has 125K miles on it, was it worth the $85 I put into it?
o3burn is offline   Reply With Quote
Old 08-09-2004, 12:07 AM   #2
DerFahrer
Member#: 30727
2000 Legacy B4 RSK
*Formerly subyluvr2212*
Is there a snail/hair dryer/compressor looking thing sitting behind the passenger head? If so, that would be your turbo
DerFahrer is offline   Reply With Quote
Old 08-09-2004, 01:45 AM   #3
Flowmastered87GL
WCSS Drunk
Member#: 8914
2005 Baja Sport
Regal Blue Pearl
Other easy way to tell:
If its carbed, there should be a big black air cleaner on top of the engine.
If its turbo there should be a silver intake plenum thing going down into the throttle body... imprinted on this should be TURBO, or 4WD TURBO.
Water pumps actually arent separated by turbo/non turbo
They are defined by AC or non AC. Generally models without AC have one water pump while those with it have the other. Exceptions exist though... my 87 GL has a JDM engine installed (same HP spec though ) and it does not have AC, but I use an AC equipped car water pump...
Basically the easy way to tell is the AC pump (I think its a 110 MM, should have studs)
The non AC pump should use bolts to install the pully and its a 105MM) Or something like that... I think the 110 and 105 are the correct numbers.
Flowmastered87GL is offline   Reply With Quote
Old 08-11-2004, 06:58 AM   #4
o3burn
Member#: 67864
1985 GL 4dr
white
OK
It is not a turbo. What is the boost sensor for?? Do any of you guys know what could be causing a wicked hesitation? It happens when you press the gas quickly if you gradually press the gas it seems to be OK. Cleaning the linkages and other outside components seemed to help some. Any input is apreciated.
---Update------
Th engine stopped on me today. It will crank but won't start.
Old 08-11-2004, 06:00 PM   #5
MilesFox
Member#: 64965
87 87 RX 95 Legacy
duplicolor, aluminum
take off the distributor cap and see if the rotor turns while cranking. if not, you have a broken timing belt. if it is turning, we will go from there
MilesFox is offline   Reply With Quote
Old 08-11-2004, 07:53 PM   #6
o3burn
Member#: 67864
1985 GL 4dr
white
It is the belt. I can get to it, but I need to know how to time it. I am a self taught mechanic so make it simple. If it were a computer fixing it would be no prob. I may have found a pdf of a service manual. Thanks for all of the help so far. I've driven the car about 100 miles so far and it is a FUN car to drive.
Old 08-12-2004, 02:15 AM   #7
Flowmastered87GL
WCSS Drunk
Member#: 8914
2005 Baja Sport
Regal Blue Pearl
Well, you need to do BOTH the belts at the same time. Kinda pointless to just change one of them since the other one probably will break soon.
Now... you have to remove the fans, pullys and belt covers to get to the timing belts
On the flywheel there are 3 little tick marks (NOT the degree timing marks 0-10-20 degrees!!)
Set the pointer in the middle of the 3 marks.
Look at the cam sprocket (drivers side) there should be a little tiny hole in it. Align that straight up (should be a notch in the belt cover back to line it up with) Then start running the belt. Start at the crank, go down to the oil pump over the idler up to the cam and then finally under the tensioner. let the tensioner come up against the belt now. Here is the hard part... torque the belt (kinda like preload it) to 15 ft lbs or so (have to have a torque wrench set on lefty loosy) then tighten the bolts on the tensioner. Crank the engine over with a wrench to make sure it stays on time.
Repeat process on passenger side (less stuff to wrap the belt around on this side though)
Oh one more thing. when timing the passenger side of the engine also start with the flywheel in the middle of the three marks. also have the cam straight up. BUT... when you are doing this the drivers cam should now be pointing DOWN. If its not, rotate the engine 360 degrees and it now should be. You can now install and torque the passenger side belt.
While you are in there consider replacing the cam and crank seal... and water pump and oil pump seals too.
Old 08-13-2004, 09:31 PM   #8
o3burn
Member#: 67864
1985 GL 4dr
white
Thank you !!!!!!!! Thank you !!!!!!!! Thank you !!!!!!!! Thank you !!!!!!!! Thank you !!!!!!!! Thank you !!!!!!!! Thank you !!!!!!!! Thank you !!!!!!!! Thank you !!!!!!!! Thank you !!!!!!!! Thank you !!!!!!!! Thank you !!!!!!!! Thank you !!!!!!!! Thank you !!!!!!!! Thank you !!!!!!!! Thank you !!!!!!!! Thank you !!!!!!!! Thank you !!!!!!!! Thank you !!!!!!!! Thank you !!!!!!!! Thank you !!!!!!!! Thank you !!!!!!!! Thank you !!!!!!!!
It went well. The Soob is back on the road. Flow master You rock. The worst part of the project was getting the thing back together.
Thanks again.
Old 08-14-2004, 01:29 AM   #9
Flowmastered87GL
WCSS Drunk
Member#: 8914
2005 Baja Sport
Regal Blue Pearl
Good my directions made sense... so you understood how to torque (preload) the timing belts?
Turbo or not Turbo that is the question DigitalNOFX Normally Aspirated with bolt-on Forced Induction Powertrain 5 08-15-2001 02:36 PM
To turbo, or Not to turbo? FLUBYUx2 Normally Aspirated Powertrain 14 02-01-2001 12:34 AM
To Turbo or Not To Turbo? llonman Technical Forum Archive 14 10-06-2000 12:45 AM
To turbo or not to turbo Spider-X Legacy Forum 0 08-25-2000 08:02 PM
turbo or not to turbo that is the question joe z New England Impreza Club Forum -- NESIC 10 04-21-2000 07:25 AM
