Old 08-08-2004, 10:53 PM   #1
CMJ
Member#: 39235
Default Possible knock? Logs inside.
I've just started exploring the utec and have a few questions. Does the low timing that the ecu wanted to run just after shifting to 2nd indicate it detected knock?
This is a TXS 93oct Stage4 OLF 4.2 map that I have made lots of changes to so it will run on 91oct. I don't have a wide band yet.
Thanks,
Chris
Mods:
vf22
sti inj.
up pipe
down pipe
Walbro
MBC
water injection
2021, +0.4,2.4,102, 10, 00, 14.7,+32.0, 10.3,+32.8, -0.4,250.00,2.3
2178, +0.6,2.5,102, 10, 00, 14.1,+34.6, 11.5,+32.2, -0.5,250.00,2.3
2575, +0.8,2.6,102, 10, 00, 12.1,+34.0, 13.9,+32.0, -0.4,250.00,2.4
2686, +1.2,2.7,103, 10, 00, 12.4,+33.0, 15.6,+32.0, -0.3,250.00,2.6
3041, +1.9,2.9,102, 20, 00, rich,+32.3, 19.4,+30.0, +0.4,250.00,2.7
3356, +2.3,3.0,103, 20, 00, rich,+31.5, 24.2,+29.2, +0.5,250.00,2.9
3599, +3.1,3.2,102, 20, 00, rich,+31.2, 30.3,+27.6, +0.5,250.00,3.0
3954, +4.3,3.3,103, 30, 00, rich,+29.1, 38.3,+25.0, -0.2,250.00,3.1
4363, +5.9,3.6,102, 40, 00, rich,+24.1, 50.4,+23.6, +0.2,250.00,3.5
4701, +8.4,4.0,101, 60, 00, rich,+20.4, 68.8,+17.0, +0.9,250.00,3.8
5333,+11.2,4.2,101, 80, 00, rich,+23.5, 78.9,+19.0, -1.0,250.00,3.9
5747,+14.1,4.3,101, 90, 00, rich,+23.0, 85.1,+19.1, -0.7,250.00,3.9
6265,+15.7,4.3,101, 90, 00, rich,+24.4, 91.5,+20.0, -0.9,250.00,4.0
6613,+17.0,4.4,101, 90, 00, rich,+27.5, 91.8,+21.0, -0.9,250.00,4.0
5995,+13.5,2.4, 0, 00, 00, 13.2,+11.0, 12.2,ECU. , -1.0,ECU. ,2.2
5837, +6.8,2.2, 0, 00, 00, rich,+10.7, 10.4,ECU. , -1.0,ECU. ,2.0
5602, +0.2,2.2, 0, 00, 00, 12.1,+11.1, 9.9,ECU. , -1.0,ECU. ,2.0
5376, -7.1,2.2, 0, 00, 00, rich,+10.7, 9.5,ECU. , -1.0,ECU. ,2.0
5089,-10.4,2.1, 0, 00, 00, rich,+10.8, 9.4,ECU. , -1.0,ECU. ,2.0
4967, -9.2,3.4, 63, 10, 00, 13.9,+21.3, 38.4,+28.0, -0.8,ECU. ,3.1
4050, -5.7,3.5,102, 10, 00, rich,+28.2, 40.2,+31.0, +0.0,250.00,3.2
4130, -1.4,3.5,102, 30, 00, rich, +9.6, 43.9,+25.0, -0.3,250.00,3.2
4151, +4.1,3.6,102, 50, 00, rich, +8.9, 49.4,+17.5, +0.5,250.00,3.4
4203, +8.6,3.8,103, 60, 00, rich,+17.9, 58.3,+16.0, +0.8,250.00,3.6
4306,+11.6,4.0,102, 70, 00, rich,+18.7, 64.2,+16.0, +0.9,250.00,3.7
4444,+14.7,4.0,102, 90, 00, rich,+19.6, 68.5,+16.0, +1.0,250.00,3.7
4597,+16.7,4.0,101,100, 00, rich,+20.7, 72.0,+16.4, +1.0,250.00,3.8
4734,+18.4,4.1,101,100, 00, rich,+22.3, 74.1,+17.1, +0.8,250.00,3.8
4894,+19.6,4.2,102,100, 00, rich,+22.8, 77.0,+17.6, -0.3,250.00,3.8
5120,+19.4,4.2,101,100, 00, rich,+23.1, 76.3,+18.4, -0.5,250.00,3.8
5299,+18.8,4.2,102, 90, 00, rich,+23.3, 83.3,+19.0, -0.9,250.00,3.9
5428,+18.0,4.3,102, 90, 00, rich,+24.0, 82.6,+19.0, -0.9,250.00,3.9
5546,+17.4,4.2,101, 90, 00, rich,+23.1, 86.1,+19.0, -0.8,250.00,3.9
5659,+18.0,4.3,101,100, 00, rich,+23.5, 85.6,+19.0, -0.7,250.00,4.0
5858,+18.0,4.3,102,100, 00, rich,+23.5, 84.6,+19.2, -0.6,250.00,4.0
6082,+17.8,4.3,102, 90, 00, rich,+23.5, 90.3,+19.8, -0.8,250.00,4.0
6127,+18.4,4.4,102, 90, 00, rich,+23.4, 89.1,+20.0, -0.5,250.00,4.0
6172,+18.0,4.4,102,100, 00, rich,+24.1, 91.4,+20.0, -0.8,250.00,4.0
6361,+18.2,4.4,102,100, 00, rich,+26.2, 93.7,+20.3, -0.8,250.00,4.0
6397,+18.4,4.4,101, 90, 00, rich,+27.1, 92.5,+20.8, -0.9,250.00,4.0
6574,+17.8,4.4,102, 90, 00, rich,+27.4, 91.6,+21.0, -0.9,250.00,4.0
CMJ is offline   Reply With Quote
Old 08-09-2004, 01:33 PM   #2
CMJ
Member#: 39235
bump
Old 08-09-2004, 02:27 PM   #3
bikerboy
Member#: 5477
2007 R171.473
2009 SWP Spec B
No knock count in that log, It is the collumn next to the front narrow band AFR readings
bikerboy is offline   Reply With Quote
Old 08-09-2004, 02:39 PM   #4
cdvma
Member#: 21980
2002 PSM WRX (Sold)
2009 BMW X5
If the UTEC doesn't pick up the knock, the stock ECU wont either.
cdvma is offline   Reply With Quote
Old 08-09-2004, 03:36 PM   #5
CMJ
Member#: 39235
Well why did the ecu drop timing from 28deg to 9deg under wot?
Old 08-09-2004, 04:35 PM   #6
bikerboy
Member#: 5477
2007 R171.473
2009 SWP Spec B
Utec timing and ecu timing are different that just shows what the ecu would run if it were in charge.
RTFM= "read the f**c*ing manuel" as Turboxs says, guess they like that abreviation.
Dont take that personal it is a TXS term that we all find it funny.
Old 08-09-2004, 05:50 PM   #7
03WRXMA
Member#: 35081
2012 WRX
Pretty much, looks ok to me.
As above, look at the MOD timing value, thats all that matters once over the threshold.
03WRXMA is offline   Reply With Quote
Old 08-12-2004, 01:20 PM   #8
AZScoobie
Member#: 8785
02 [email protected]
netcom.com
Hey Chris.. Looks like a good start.. For Heavens sake... get a WB man.. The Tuner is nice because it outputs to the logs. I use the LM1 myself.
You can certainly look at the ECU advance numbers to get an idea of how happy the ECU is. Keep in mind that the stock ecu is WAY more sensitive to knock then the Utec's default settings are. Your dip in advance happend right after the shift and it happend on spool up around the trq peak of the motor. Bottom line.. The stock ecu had yanked timing there.. Look at the MAF voltage. I have been doing this long enough to know where 3.5 volts is on the ecu's map The best way to do this is to use Delta dash logging.. Look at the ECU's Ignition correction. If you are not getting a good +5 or more advance and or your multiplier has dropped you are probably knocking a bit..
Side note.. make sure you have your Utec set to Gauge mode for the MAP sensor.. If its set to the default setting your Utec log readings could be 2 to 3 psi less reading.. You are running way, way to much boost and if you are in abosolute you are running WAY, WAY, WAY to much boost. On 91 CA gas its best to keep that boost down to 17 psi in gauge mode.. Keep AFR's Nice and rich in the high to mid 10's. total advance will be somewhere around 20-24 degrees.. Things can certainly change depending on your mods. FMIC/water spray/water injectiona and things of that nature can allow more boost.
HTH
Clark
AZScoobie is offline   Reply With Quote
Old 08-12-2004, 04:11 PM   #9
CMJ
Member#: 39235
Thanks Clark,
I had a feeling the ecu was detecting knock. The utec is set to gauge mode and yes the boost was high on that run but I always have the water injection on.
Side note: My Delta Dash only logs 13.8psi with same settings and I'm sure it's right up in the 18psi range.
Old 08-12-2004, 04:18 PM   #10
AZScoobie
Member#: 8785
netcom.com
yeah.. You need to get a WB Chris.. You are probably PUKE rich. Thats my guess. The 4.2 OLF mode factory settings are almost always off. Pay REAL close attention to your AFR corrections 1 2 and 3... Adjust both injector scale settings up and down in the same increment until the AFR corrections are right or close to 0.. You may have to edit the 0 column some. Once those corrections are good you will need to check AFR in open loop and adjust as needed.
On the timing map.... Try this: Run 30 in the 10 column all the way down.. Run 27 in the 20 column all the way down and run 23 in the 30 column.. Fade the map out from there.. I also like to set the OLF Cross over point to 30-33. If you are cruising on the highway you can be stuck in OLF all the time at highspeeds and mileage will suffer.
Cya
Clark
Old 08-12-2004, 04:51 PM   #11
wrex03
Member#: 29963
04 sti
Delta dash will not give an accurrate response on boost when using a utec. I'm not sure why, but someone certainly can chime in on that.
wrex03 is offline   Reply With Quote
Old 08-12-2004, 05:03 PM   #12
RiftsWRX
Member#: 6124
2000 NFR AP1 S2000
'07 Honda FIT sport (5MT)
because the UTEC clamps manifold pressure to around 1 bar. It won't tell the ECU anything above that unless you trigger the hardware fuel cut (20+ PSI at that point).
Jorge (RiftsWRX)
www.ProjectWRX.com
RiftsWRX is offline   Reply With Quote
Old 08-12-2004, 05:07 PM   #13
AZScoobie
Member#: 8785
netcom.com
While thats true it has no bearing on this thread... In this log its clearly under 14 psi where the ECU is producing low advance numbers. I looked at Chris's rom file and noticed that he was at Zero correction at that point.. Must be super rich or lean there... Its def knocking.
Cya
Clark
Engine Knock. Data log inside. whitey615 Engine Management & Tuning 12 05-27-2010 02:36 AM
Bogging/Knock Issues - Logs Inside WRXEcho AccessPort 7 08-07-2008 07:00 PM
Knock due to Ignition Cut? Logs inside. Teh Legacy UTEC 9 12-08-2007 11:10 AM
Help with Knock, logs inside wrx21144 Engine Management & Tuning 11 10-15-2005 10:28 PM
Knock at 3000 to 3800 RPM 4th gear... *log inside* tEkkGOD Engine Management & Tuning 12 12-05-2003 02:12 PM
