Old 08-09-2004, 01:17 AM   #1
PAPsti
Member#: 41733
Default How to verify knock ?
I'm using UTEC 4.2 and stock JDM ECU. With 98 RON fuel and WI I'm getting knock ( from CEL ) around 4-5K rpm with 23 deg timing. The engine sounds OK and I use DD to check on advance multiplier, no change, the stock ECU didn't detect any knock. If I am going to trust the stock ECU's sensing on knock, I will run timing until I see a retard in advance multiplier, then drop UTEC's sensitivity. Or should I get a knock link ? I think knock link has sensitivity adjustment too, it might lead me back to square one like UTEC. Give me some idea please.
PAPsti is offline   Reply With Quote
Old 08-09-2004, 01:59 AM   #2
Equilibrium Tuning
Member#: 26933
2006 STI
CGM
it takes quite a bit of knock to cause the IAM to go down. You should log knock correction... where it gets lower is where the ECU has detected knock.
-- Ed
Equilibrium Tuning is offline   Reply With Quote
how to verify OEM sti wheels fit 06-07 MatchesMalone Tire & Wheel 12 06-23-2009 03:27 PM
How to verify Spiider DCCD auto controller works triguy Transmission (AT/MT) & Driveline 2 06-02-2008 01:59 PM
How to verify STi diffs and DCCD are functioning properly? overdose Transmission (AT/MT) & Driveline 2 02-06-2007 10:37 PM
Part number from STI type RA tranny... got the #, but can't find how to verify it JSiwek Transmission (AT/MT) & Driveline 55 07-31-2003 09:11 PM
How to verify STi suspension?? pooper Newbies & FAQs 2 03-25-2003 02:06 AM
