Old 08-09-2004, 03:26 PM   #1
STi_Drift
Member#: 25759
99 impreza
rally blue
Default Help: Popping noise from the engine bay
I have a hybrid ej22t on 2.5RS SOHC heads with Hydra engine mgmt.
My question is if anyone has ever encountered a popping sound from the engine bay. I am not sure what it is, but the sound is distinct. It happens sometimes on low load when shifting easy from 1st to 2nd and also at WOT (which is even louder and more pronounced and quite violent). The car seems to lose power and studders when it happens until I let off. I know it's not my timing, because I am running fairly conservative on the timing numbers. It almost seems mechanical. I thought it was the BOV, but I have tested that and that is not it.
Thanks for any help/suggestions
STi_Drift is offline   Reply With Quote
Old 08-09-2004, 03:29 PM   #2
cnk
Member#: 10757
2013 BRZ Limited 6MT
That sounds like detonation to me, but I'm not an expert. Hopefully someon else can chime in.
Calvin
cnk is offline   Reply With Quote
Old 08-09-2004, 04:29 PM   #3
STi_Drift
Member#: 25759
99 impreza
rally blue
Well I had a few ppl, including a certified mechaninc who works on modified cars all the time in my car and they said it wasn't det. I was running 94 at the time and AFRs on the FJO wideband were about 11-11.5
Old 08-09-2004, 05:00 PM   #4
MustGoFast
Member#: 33370
2002 Impreza WRX
Blue now w/ 6 fun flavors
blow a hose loose in the IC? that makes one heckuva pop but doesn't really seem like an intermittant problem.
MustGoFast is offline   Reply With Quote
Old 08-09-2004, 05:20 PM   #5
STi_Drift
Member#: 25759
99 impreza
rally blue
I thought it was hose, but that isn't it haha. Thanks tho. I kind of found that the problem doenst happen on a fresh set of plugs for a few hundred clicks, but that may not be the issue. as the plugs are somewhat rich looking brown to black
Old 08-10-2004, 03:30 PM   #6
STi_Drift
Member#: 25759
99 impreza
rally blue
anyone?
Old 08-12-2004, 05:05 PM   #7
Elliot
Member#: 12732
2000 2.5RS-T
Titanium silver
I used to have the same problem with SAFC and WRx injectors!!
Elliot is offline   Reply With Quote
Noises from my engine bay Tr1llee Newbies & FAQs 5 02-04-2010 12:23 AM
Weird noise coming from the engine bay??? jmanSTI Texas Impreza Club Forum -- TXIC 20 03-27-2008 01:03 AM
Wierd Noise coming from the engine bay... ChristopherG Factory 2.0L Turbo Powertrain 25 05-12-2007 02:01 AM
Humming noise from the engine bay??! sizzflair Newbies & FAQs 9 04-21-2006 06:03 PM
Weird on and off whining noise from the engine bay WITH THE CAR OFF. JM530 Car Audio, Video & Security 6 03-21-2006 08:29 AM
Message Board Statistics All times are GMT -4. The time now is 07:13 AM.
