Notices
Old 08-09-2004, 03:51 PM   #1
wrx2k4blue
Member#: 59048
2005 Black S60R
w/ 18" Modas & Sport Body
Default Cobb Accessport Stage 1 to Stage 2?
Is that simply getting a turbo-back exhaust? Would it have to be Cobb's turbo-back exhaust? Or a qualified one from a known list? With Stage 1, we obviously wouldn't need another AP right?
What sort of warranty/inspection issues are we looking at when we install an aftermarket turbo-back exhaust?
wrx2k4blue is offline   Reply With Quote
Old 08-09-2004, 04:14 PM   #2
Twisted STi
Member#: 49025
2004 STi
Platinum
Doesn't have to be Cobbs. Good thing too, isn't that thing back-ordered several months? Don't quote me on this one either, but for some reason I was under the impression that all that is required for S2 is a downpipe, although the full TB is recommended.
Twisted STi is offline   Reply With Quote
Old 08-09-2004, 04:47 PM   #3
Jduke
Member#: 29699
2005 Legacy GT Wagon
Red
Yup all you need is a DP that eliminates the two cats after the Turbo and your good to go to S2
Jduke is offline   Reply With Quote
Old 08-10-2004, 02:33 AM   #4
AlanWRX
Member#: 23067
As far as warranty goes, it is a good idea to put your stock downipe back on if you have to take it in. It isn't very hard to swap out the downpipe, takes an hour or two. It really depends on what is wrong with your car when you take it in. Inspection depends on which state you are in. In TX they plug into your car and make sure you aren't throwing any CEL's. Cobb stage 2 gets rid of the cel when you install it. They also do a visual inspection, if they can't see any cats they won't pass you. I showed the guy the cat in the uppipe and he went ahead and passed me...
AlanWRX is offline   Reply With Quote
Old 08-13-2004, 10:14 AM   #5
Scorpion
Member#: 67956
2007 WRX Wagon
Is this true? Can I use my stock exhaust with an upgraded down pipe and go stage 2 without any problems? Can anyone vouch for this?
Scorpion is offline   Reply With Quote
Old 08-13-2004, 10:23 AM   #6
AlanWRX
Member#: 23067
yes, Cobb says that it is better to get a full turboback but it will work fine with just the dp.
Old 08-13-2004, 10:35 AM   #7
Scorpion
Member#: 67956
2007 WRX Wagon
What down pipe would be best, there are so many to choose from.
Old 08-13-2004, 10:41 AM   #8
Marketresearch
Member#: 35738
02 wrx
Almost true, you can just replace just the downpipe(2nd cat) and go to stage 2. The downpipe cat is the key part. Like it's been said the more you replace DP, 3rd cat, resonator, muffler to a free flowing part the better the car will run. (also well matched parts)
I have to say it, I'm a fan of of having least one cat in the house. High flow one
Marketresearch is offline   Reply With Quote
Old 08-13-2004, 11:12 AM   #9
AlanWRX
Member#: 23067
I have the Helix catless pipe. It is a bellmouth design and runs about $285 or so shipped. It is a nice piece.
Old 08-13-2004, 11:58 AM   #10
Scorpion
Member#: 67956
2007 WRX Wagon
I would like to keep the car as quite as I can so I figure the down pipe and the mid pipe cold be changed while retainign the stock muffler.
Also, I plan on reinstalling the stock airbox minus the silencer. Should I get that silencer delete elbow or just run the box as is?
I cant wait for my Accessport!
Old 08-13-2004, 12:19 PM   #11
bluelinescooby
Member#: 48881
2009 1125CR
1996 Neon ACR
You don't have to waste $$$ on a silly plastic elbow. Just hack the bottom of the silencer off and reinstall the top part if you like.
bluelinescooby is offline   Reply With Quote
Old 08-13-2004, 06:18 PM   #12
sdwrx
Member#: 38227
2004 WRX Sedan
Platinum
If you are a woosh addict, just seal your box to the fender and cover the other hole. If you want a little more subdued sound, get the very nice silencer delete elbow. It provides a nice smooth intake for cold air and retains most of Subaru's intake design (which they did their homework on). Hacking the silencer is an option, but then you can't return to stock if you decide you don't like the sound.
sdwrx is offline   Reply With Quote
Old 08-13-2004, 06:33 PM   #13
MO REX
Member#: 52583
2002 WRX sedan
Have any of you guys (with an egt gauge) ran stage 2 with just a dp. I would be leary of this without an egt gauge since the WRX has been known to run high egt's. I'm not saying you will definately run dangerously high egt's but I'm sure you would be running higher temps with just a dp than if you had a full tbe. I have heard of stock WRX's running 1600+ on cylinder 4.
MO REX is offline   Reply With Quote
Old 08-13-2004, 07:56 PM   #14
BOFslime
Member#: 23845
2015 FLAT SIX
the Stock STi runs 1600+ at times, stock. Same with a TBE..
My AP gets here Tuesday, i'm hopeing EGT's go down. Either way, i'll let you guy's know.
BOFslime is offline   Reply With Quote
Cobb access port from stage 1 to stage 2 johnnyyrocket420 Newbies & FAQs 9 03-05-2010 08:24 AM
WTB- Cobb Accessport v.1 or v.2 JOWANKEL MAIC Private Classifieds 5 09-03-2007 03:39 PM
WTB- Cobb Accessport v.1 or v.2 JOWANKEL Private 'Wanted' Classifieds 0 08-29-2007 10:19 PM
Cobb stage 1 to stage 2 today... adoinfl AccessPort 13 07-22-2007 02:57 AM
AccessPort Stage 1 to Stage 2 question... UltimateLurker Engine Management & Tuning 7 07-03-2005 04:48 PM
