Welcome to the North American Subaru Impreza Owners Club Friday February 12, 2016
Old 08-10-2004, 10:53 AM   #1
zimm
Member#: 44427
Default Setting the STI UTEC for Perrin injector mod?
I have a STI stage II (UTEC/TBE). If I upgrade to Perrin modified injectors and the walbro 255 pump, how do I set up the UTEC for it? I read the manual twice and don't see any mention of it.
My plan is to install the injectors/pump here in Florida, then drive it up to TurboXS to get it tuned (700+ miles of highway) while visiting the folks for the Holidays.
I don't want my engine to blow up on the drive.
zimm is offline   Reply With Quote
Old 08-10-2004, 11:18 AM   #2
carguyx
Member#: 66850
04 green'd STI
11.41 @ 117mph 93 oct.
all you have to do is scale the maf a little. as long as you can get the car to idle and run smooth you'll be ok. Just dont boost it. if I remember correctly I used a scale value of 97 when I did mine.
carguyx is offline   Reply With Quote
Old 08-10-2004, 11:35 AM   #3
bikerboy
Member#: 5477
2007 R171.473
2009 SWP Spec B
AH I think your missing something, SO you scaled your 810 injectors to 97 from the 550 listed in perameters?
Opps reread your post, why change the MAF scaling? is he running a larger DIA. intake? It is a scaling issue.
Scale the injectors to 800 cc in open loop fueling
for safety pull up your boost map and change all you values to 1. this way the car will run only on wastegate preasure.
bikerboy is offline   Reply With Quote
Old 08-10-2004, 11:36 AM   #4
x99percent
Member#: 27108
2004 STi
2004 A4
In the open look fueling parameters, I'm using a value of 810..
x99percent is offline   Reply With Quote
Old 08-11-2004, 03:59 PM   #5
zimm
Member#: 44427
Let me understand this correctly: If I go to 800+cc injectors, I'll have to have my UTEC tuned for open loop vs. my current closed loop? Or is that just to get the car to the dyno?
Maybe I should install them at turboxs out in the parking lot then dyno it... How about running just the fuel pump on the stock injectors for my road trip?
Old 08-12-2004, 03:17 PM   #6
x99percent
Member#: 27108
2004 STi
2004 A4
Don't confuse open vs. closed-loop boost control with the UTEC's open loop fueling.
Install injectors & fuel pump
In the UTEC.. under "parameters", go to "open loop fueling"
Change "injector flow" to "810" (leave "stock injector flow" at 550)
Drive car to TurboXS
FS: '04 STi UTEC and Perrin Catless TBE Ryan Smith NWIC Private Classifieds 15 01-05-2008 02:25 AM
04 sti utec and 820cc injectors drewwrxrogers Private 'Wanted' Classifieds 6 11-06-2007 01:12 AM
Cylinder misfire after Perrin injector mod? zimm Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 3 12-09-2004 08:27 PM
For those of you that want the perrin injector mod..... carguy19 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 1 03-17-2004 09:18 PM
What places do the Perrin injector mod?? carguy19 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 17 01-30-2004 02:04 AM
