Old 08-10-2004, 02:12 PM   #1
feiron
Member#: 62327
2005 WRB STI
[S600BY]
Question noise from front left tire
I have 225/40/18 on
the weird noise only happen when braking to a complete stop or to a very slow roll... the harder I braked the louder the sound was and it faded away as the car slowed down
it sounded like the tire was rubbing the fender...
it sounded from the front tires more like from the front left.
anyone has any idea that it is? I supposed 225 clears the fenders nicely
thanks in advance for the feedbacks
feiron is offline   Reply With Quote
Old 08-10-2004, 03:11 PM   #2
Rojorex
Member#: 19687
'02 WRB WRX
Non-sedan
What size/offset rims are you running?
Rojorex is offline   Reply With Quote
Old 08-10-2004, 04:04 PM   #3
feiron
Member#: 62327
2005 WRB STI
[S600BY]
18x8 ET48 I just notice it just now when I went out to the bank... that sound was gone... sometimes its there sometimes its not... weird huh
Old 08-10-2004, 08:12 PM   #4
reaubideux
Member#: 33666
If the sound comes back I'd consider rotating that tire to the back. If the sound moves then its the tire. If it stays in the front left then its suspension/brakes, or like you suggested - tire rub. Also, did you check the fender for signs of tire rub? If its a prolonged noise like it seems to be from the way you described it then there should be some marks on the fender from the rubbing.
reaubideux is offline   Reply With Quote
Old 08-10-2004, 09:16 PM   #5
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
...or the bearing going bad....
Rotational Knocking Noise from Front Left IHeartE30s Transmission (AT/MT) & Driveline 1 04-12-2010 12:08 AM
Noise from front left fender osizeit Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 04-29-2006 04:07 AM
Noise Coming from rear left tire area tsquare Brakes, Steering & Suspension 2 04-13-2005 11:39 AM
Noise coming from front left wheel area txl146 Brakes, Steering & Suspension 5 11-29-2004 01:09 AM
Weird clunking from front left tire... JGard Brakes, Steering & Suspension 5 03-14-2001 10:59 AM
