Old 08-10-2004, 02:36 PM   #1
1sti2nv
Member#: 55902
Default 04 STI - SAFC Install question
Ok,.. new to the board,.. so hello everyone.
I installed my SAFC II last night on my car,.. everything seemed to go well,.. car started,.. check the SAFC and the only problem I'm seeing is :
RPM displays "0". I connected the RPM wire from the SAFC to the Engine Speed Output: Connector:B134 Terminal:23
My knock sensor only diplays "0" I connected it to : Connector: B136 Terminal: 25
Do these seem like the right connections? Everything else works great except for these 2.
Thanks for your help.
1sti2nv is offline   Reply With Quote
Old 08-10-2004, 03:03 PM   #2
happasaiyan
Member#: 37731
1) take off the safc
2) choose a different EM
3) install other EM
happasaiyan is offline   Reply With Quote
Old 08-10-2004, 03:28 PM   #3
1sti2nv
Member#: 55902
Wow.. thanks,.. I would never of thought of that... j/k
I assume you didn't like the SAFC.. I've heard good and bad things.. figured I would give it a try.
But really anyone have a clue here?
Old 08-10-2004, 04:05 PM   #4
happasaiyan
Member#: 37731
well...ive never used a SAFC.
the ecu will learn around the safc, and you will be back where you started...or worse, you will blow up your engine. so a search on popped ej257s before the ecutek, cobb or utec EM solutions came out. they were usually running e-manage which is a glorified safc. so if the emanage is better than the safc, what are the odds you will have good luck?
is your engine worth saving a few bucks?
Old 08-11-2004, 05:24 PM   #5
1sti2nv
Member#: 55902
Ok,.. took everyones advise,.. I did get the SAFC 2 running, and road tuned with my wideband o2,.. but in the end wasn't really happy with the little amount of control I had,
So I made an appointment for next week to take it to Scottsdale AZ and have the ECUTEK flashed in and dyno tuned....
Side not I have a Brand new installed once for 12 hours or so Apexi SAFC II for sale ... asking $190
Thanks everyone.
Old 08-11-2004, 05:39 PM   #6
happasaiyan
Member#: 37731
haha...good to see your engine will last now.
04 STI cluster installed in my 02 WRX SilverBoosted Electrical & Lighting 403 04-19-2012 05:00 AM
Sti swap 02 wrx -> 04 sti Steering wheel question Bug_i_Sti Subaru Conversions 2 04-22-2010 12:21 AM
04 STi Pink Install How to and Review RoninSTI Brakes, Steering & Suspension 47 10-05-2004 11:25 PM
04 STi Fog Install Woes outferno Electrical & Lighting 18 06-02-2004 06:36 AM
looking for guidance: 04 sti alarm install (clifford g5 concept 550) Tobey Car Audio, Video & Security 16 05-15-2004 11:02 PM
