Old 08-10-2004, 03:08 PM   #1
linux>windows
Member#: 49517
Default ecu for swap... 2.2 -> h6
I'm getting the necessary parts for the H6 swap, i need to know what ECU would be the best and where I can find maps. thanks
linux>windows is offline   Reply With Quote
Old 08-10-2004, 03:44 PM   #2
klug
Member#: 4133
'01 2.5RS Sedan
'05 LGT Wagon
Post Good question...
As an H-6 swap is one option I was (still am?) looking at, I would say that if you aren't goin to swap the harness and run the stock H-6 ECU, the SDS EFI EM-4 6F is the next best bet from a cost/simplicity point of view. If you have more cash, anders8 commented that he would use a motec.
As for maps, I believe the SDS comes with a rough base map based on the application. As for other brands of EMS, I think you're operating in virgin territory...
klug
klug is offline   Reply With Quote
Old 08-10-2004, 10:06 PM   #3
Jaxx
Member#: 177
The 93 W/EJ20K
Series 10 FRS
yeah the sds is probbaly fine however, the tec 3 6cyl is much more expensive and has many many more features
Old 08-10-2004, 10:43 PM   #4
subiekid
Member#: 25516
1995 Legacy TURBO!!!
EJ22T/TEC3 & '12 Civic
All SDS ecus come with a base map that will alow you to start the car without changing anything. The more info you can give them the better your basemap should be. I almost got an SDS for my car, but Jaxx kinda got me interested in the TEC 3.
I have seen TEC 2s in the 6cyl config go on ebay for fairly cheap.
One thing I didnt like about the SDS is you have to use the little controll box to tune, no lap top. Its kinda nice not to carry a laptop in your car, but that little box woudl be very hard to tune off. THe display is fairly small.
I am not an expert on motors at all, and I have gotten my car to run fairly decent now with my TEC 3, but I did get a base map from a WRX and mod it to work with my EJ22T.
The SDS always runs on closed loop, while with the tec you can change it to run in open loop like at low RPM and then at high RPM.
Does the SDS run off phased or full sequencial?
subiekid is offline   Reply With Quote
ECU for swap vica153 Engine Management & Tuning 0 05-01-2005 10:36 PM
Need help developing PNP HYDRA Nemesis 2.0 ecu for 99-02 2.5RS HydraEMS-NA Other Engine Management 1 02-17-2004 11:40 AM
fs: cobb stage2 ecu for swap.. WRX Jim Mid Atlantic Impreza Club -- MAIC 5 10-12-2003 11:35 PM
Impreza L --> 2.5RS --> EJ20 swaps Clutch784 Subaru Conversions 7 08-26-2003 05:49 PM
Plug and Play ECU for N/A 2.5RS? N/A01RS Normally Aspirated Powertrain 1 08-17-2002 10:00 AM
