Welcome to the North American Subaru Impreza Owners Club Monday February 8, 2016
Go Back   NASIOC > NASIOC Subaru Models > 'Old School' Subaru Forum
Closed Thread
Old 08-10-2004, 07:02 PM   #1
Brian204
Member#: 56528
1989 GL
white
Default Most common oil leak?
My EA82 leaks/burns maybe a quart every 2-3 weeks. The underside of my engine is kind of smeared with oil enough that I can't quite tell exactly where it's coming from. Is it more likely the valve cover gaskets, or dreadedly the head gaskets? It's not a turbo, and hasn't really been abused, either. Has 210k miles.
Brian204 is offline
Old 08-10-2004, 10:49 PM   #2
22BKEEPER
Member#: 15687
08 Tribeca
Bbronz
Brian204 The list is big first cam case orings, then the cam case threebond then the valve covers the cam seals the oil pump kermit the frog gasket the front oil pump seal ( when that leaks it leaks air and causes valve taps ) the pan gasket the seperator plate gasket ,head gasket, You name it it leaks on that engine. Start by resealing the cam cases, thats probably the big leak.
22BKEEPER
22BKEEPER is offline
Old 08-11-2004, 07:22 PM   #3
Tizzle
Member#: 44472
Ver2 Legacy StiRA
88 RX, 87 RX, 07 FXT
Yes cam seals are one of the 1st to go. Maybee try using some gunk cleaner to clean down there, then you would be able to locate the leak better
Tizzle is offline
Old 08-12-2004, 03:18 AM   #4
Flowmastered87GL
WCSS Drunk
Member#: 8914
2005 Baja Sport
Regal Blue Pearl
an 86 I am about to take delivery of has a leaking problem. Turns out the oil seals in the head gaskets (there is an integrated o ring) is dried up. Loses like a quart every 200-300 miles. Solution in my case. Replace the head gaskets.
Total list of things that leak on these cars:
Head gasket O-rings
Cam case O-rings
Valve cover gaskets
PCV hoses (if cracked)
Oil pan gasket
rear main seal
front main seal
cam seals
oil pump seal
oil pump mickey mouse gasket (thats what it called, you will understand if you see it)
and drain plug (when you see one with no crush washer and only finger tight... they leak...)
Most common leaks are the valve covers and oil pan from my experiences. But generally these engines are greasy everywhere.
Flowmastered87GL is offline
Old 08-12-2004, 01:41 PM   #5
DerFahrer
Member#: 30727
2000 Legacy B4 RSK
*Formerly subyluvr2212*
My XT was leaking a half quart every week, until I replaced the cam seals. Now it doesn't leak a DROP!
DerFahrer is offline
Old 08-12-2004, 11:15 PM   #6
Brian204
Member#: 56528
1989 GL
white
Upon closer inspection, it appears to be worst from the cam case, as you guys predicted. Now, am i correct that there is a fluid bond between it and the head? Is there also a gasket seal? Has anyone re-bonded the cam case before?
Brian204 is offline
Old 08-13-2004, 01:05 PM   #7
MilesFox
Member#: 64965
87 87 RX 95 Legacy
duplicolor, aluminum
oil will collect and drip off the lowest part where tha cam tower meets the head, and a leaky valve cover may appear to be a leking cam tower. i am debating that one on my own ride myself. i myself will fix the cam cover gasket and if that wont fix it then i will consider the cam tower o- ring
you can do the work with the motor in the car, but i recommend pulling the motor our for better access, and might as well do other engine seals as well
you will want to use permatex ULTRA GREY or any other anaerobic sealer "for import engines" there is also an 0-ring on the cam tower as well, replace that
http://www.warpthree.com/milesfox/su...ce/service.htm
MilesFox is offline
Old 08-14-2004, 02:34 AM   #8
Flowmastered87GL
WCSS Drunk
Member#: 8914
2005 Baja Sport
Regal Blue Pearl
I agree with Fox, use the grey permatex. When you replace the O ring in the cam tower use a genuine subaru one... they are very well re-inforced. I think better than the original factory one even.
Just try to scrape all the old permatex outta the groove as best you can and clean all the surfaces before putting the fresh stuff on. It will take a while, but is still faster than chipping off cork chunks from the oil pan gasket
Old 08-23-2004, 11:04 AM   #9
sixpack subaru
Member#: 64974
1995 WRX,APEXi,HKS,$
Faded, Stonechipped Red
G'Day,
I have spent ALOT of years on these, building everything from 'Maude's supermarket runabout', to a Fully Worked 12.5 sec Racer.
If you want to do the Cam Cases/Housings ONCE ONLY. Buy some 1.6mm O ring in lengths, cut it to correct length by laying in the 'Groove' on the housings after THree-Bond removal with stiff wire brish, (not wire-wheel on grinder!), join with 'Superglue'at the top, Use only GENUINE Oil Gallery O Rings, (they are steel backed). Assemble with a MINIMUM if threebond, (Especially around the Oil galleries at the bottom), then Bolt up as normal.
If it leaks when you do this properly, I would be very interested to know,
I have recently serviced one I have done over 250,000kms Ago!!!
Cheers,
Sixpack Subaru
sixpack subaru is offline
Old 03-25-2008, 10:36 PM   #10
jimsaco
Member#: 165784
1998 Legacy Outback
Green
I have a 2.5 4 cammer with a 5 speed manual. I have a leak where the engine and trans meet. What do you gys think is the most likley culprit rear main, trans input seal or that oil seperator thing?
jimsaco is offline
Old 03-26-2008, 02:54 AM   #11
MilesFox
Member#: 64965
87 87 RX 95 Legacy
wow old post. well since i am here might as well update my link(old domain)
http://www.economysuperstar.com/mile...aru/subaru.htm
i am not at all familiar with 2.5, but i can tell you that rear main seals rarely if never at all fail. ther eis an oil separator chember on the back of the motor that is part of the pcv system. its just a plate the bolts onto the back of the engine block behind the flywheel. i guess the o.e. ones are plastic and crack or distort, and a metal replacement one is available as a fix.
like i said i have no experience with 2.5, but with my experience in subars all around i would bet this is your problem
MilesFox is offline
Old 03-26-2008, 03:20 AM   #12
TurboneX
Member#: 21676
RX 02Foz90XT692SVX
You need a new engine
What would any one here in the "Old Gen" forum know about a New Gen 2.5?
I think you posted this in the wrong forum
Btw, you wont know until you seperate the tranny from the engine.
TurboneX is offline
Old 03-27-2008, 07:21 PM   #13
jimsaco
Member#: 165784
1998 Legacy Outback
Green
thanks, sorry I hadn't in my haste to post I didn't see the old school thing. I was leaning towards the oil separator but I hate to pull it apart to see. I am glad to hear that the rear seals are pretty tough. Thanks again!
jimsaco is offline
Old 03-29-2008, 02:05 AM   #14
freasboarder
Member#: 175746
I just bought an 88 with 170k for $350 because it was leaking a lot of oil and the guy didn’t want to pay to get it fixed. When I got under it I could see the oil filter dripping, it was hardly on. With that tight it still leeks a very small amount out of the cam housing. Other than that the car is perfect.
freasboarder is offline
Old 03-29-2008, 03:37 AM   #15
Caboobaroo
Member#: 72335
89's RX/XT6
Blacksssssss
I just did a small reseal on my '87 and here's what I did since I had the motor out...
oil pan gasket
valve cover gaskets WITH grommets
front and rear main seals
then I also did the following
lower radiator hose (had a small pinhole in it)
timing belts with tensioners and idler
clutch
PCV valve
Now my car is much happier and I don't lose any oil. Also noticed the pressure line on the power steering pump was loose as well so I tightened it up while I was at it.
Caboobaroo is offline
Old 04-12-2008, 02:46 PM   #16
thruhike98
Member#: 177297
Hello. First post here. Please excuse any mistakes in protocol - if committed, they were unintentional.
I've been told my 99 Outback needs the camshaft cover gaskets replaced. They tell me there are 4 cams on this version 2.5 engine, and it'll cost about $1,500 to $1,800. This seemes like a lot to me.
Does this price sound correct to you?
thruhike98 is offline
Old 04-13-2008, 02:14 AM   #17
nkx
Member#: 96951
2004 wrx sedan
'10 Outback 6mt-wifey's
er, ive never heard the term "camshaft cover", but i would definitely get a second opinion. who gave you that quote?
nkx is offline
Old 04-14-2008, 11:55 AM   #18
thruhike98
Member#: 177297
Thanks for the reply nkx. I may have used the wrong term. Maybe "cam seals" (four of them on a DOHC engine)?
It was an independent service station. I got some quotes from dealers and called them back this am. It's going to be about 1/3 of that price, around $600. They said the amount of oil that had leaked all over the engine made it difficult for him to tell whether there were additional leaks, and he was quoting with that being a possibility. Hummm...
Old 04-14-2008, 02:21 PM   #19
TurboneX
Member#: 21676
RX 02Foz90XT692SVX
Its possible there could be more leaks. Normally when replacing any seal on the front of our engines, its a good idea to do a complete reseal on the front. Cam seals
Crank seal
Water pump
Oil pump seal ( if this engine has them)
Timing belt change
Might even consider if you have high mileage, changing the valve cover gaskets and oil pan gasket.
TurboneX is offline
Old 04-14-2008, 02:56 PM   #20
thruhike98
Member#: 177297
Turbone4x4: This is good to know. They will replace the cam seals and timing belt with this job. I had the water pump, timing belt, and valve cover gasket done last Fall. So I will have at least the majority of these covered. Thanks for the list!
Old 04-15-2008, 03:52 AM   #21
MilesFox
Member#: 64965
87 87 RX 95 Legacy
"camshaft cover" would be referencing the "valve covers"
if you had the timing belts done this would assume the front cam seals(the selas behind the pulleys) have been done. but if the "valve covers" are leaking they can make a mess, and probably werent changed last time around.
its called a cam cover because the cams sit over the valves and rockers, in a 'tower' mounted above the head, and ov course when you take off this cover you see the cams instead of rockers and valves like in typical pushrod engines.
its just modern terminology with the design of motors these days
MilesFox is offline
Old 04-21-2008, 11:56 AM   #22
Keiji22
Member#: 175854
98.5 Volvo V70 XC
Bleached Sphincter
My most common oil leak has been the valve cover gaskets. When I bought the car, I had to replace one. Now the other side has gone.
Keiji22 is offline
Old 01-06-2009, 11:29 PM   #23
eppoh
Member#: 199401
2000 Legacy OB
95 Honda wagon 66 Belanca
Head gasket O-rings
Cam case O-rings
Valve cover gaskets
Oil pan gasket
rear main seal
front main seal
cam seals
oil pump seal
Where are these head gasket O rings located. I have a major oil leak from the lower corner of a head at the gasket. Good compression, no coolant leak.
New on this list. Thanks, oh, it is a 93 Loyale, EA82
eppoh is offline
Old 01-07-2009, 08:33 PM   #24
Flowmastered87GL
WCSS Drunk
Member#: 8914
2005 Baja Sport
Regal Blue Pearl
Uhhh been a while.... I THINK the head gasket o-ring is just like a little neoprene or rubber o-ring thats integrated into the actual head gasket.
Old 06-05-2011, 05:42 PM   #25
porcupine73
Member#: 146199
2000 OBW
green
The cylinder head to block o-ring are usually just part of the head gasket themselves, kind of stamped into place. They can be a weak spot, as in the exhaust blowing into coolant leaks from the EJ25 phase I's. As far as Subaru oil leak common causes, they are usually the cam seals, oil pump crank seal, valve cover gaskets, and sometimes even the engine oil pressure switch can leak.
porcupine73 is offline
Closed Thread
Most Common exhaust leak points STIckySTIfee Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 6 06-19-2008 09:13 PM
Common causes for oil leaks??? Glenn Hough Service & Maintenance 14 04-08-2006 03:30 AM
Most commonly reposted topic/picture Jewbaru Off-Topic 28 11-15-2003 05:55 AM
Common oil leak problem?? Puyo Newbies & FAQs 1 03-14-2003 11:19 PM
