Old 08-10-2004, 08:03 PM   #1
GTIWRX83
Member#: 17244
Default someone post their zero column
i just got my modded stock injectors in today. I dont have an obd scan tool because they cost too much! Can someone post their zero column fuel trims so i can just have something to work with until i get the scanner??
GTIWRX83 is offline   Reply With Quote
Old 08-10-2004, 11:00 PM   #2
happasaiyan
Member#: 37731
'07 TL-S 6MT
'07 RDX-T
[0]
[0]
[0]
[0]
[0]
[0]
[0]
[0]
[0]
[0]
[0]
[0]
[0]
[0]
[0]
[0]
[0]
[0]
[0]
[0]
happasaiyan is online now   Reply With Quote
Old 08-11-2004, 07:49 AM   #3
F22-Raptor
Member#: 18311
2010 STi SE
^^^ Buahahahaha Seriously if you are using injector scaling they should be pretty dang close to 0 in the 0% column.
F22-Raptor is offline   Reply With Quote
Old 08-11-2004, 12:33 PM   #4
GTIWRX83
Member#: 17244
any other ideas...i cannot get these mofos to run properly and my car is NOT drivable the stupid thing is knocking at several points!
Old 08-11-2004, 12:35 PM   #5
cdvma
Member#: 21980
2002 PSM WRX (Sold)
2009 BMW X5
Scale them to 860, reset the stock ECU.
cdvma is offline   Reply With Quote
Old 08-11-2004, 12:56 PM   #6
big_adventure
Member#: 40501
2005 Decathalon 21sp
One WheelSeanPower
Knocking? In the 0% col? That's just about impossible. It's probably misfiring from a rich or lean condition. If it's rich, you may well have fouled your plugs.
In the days before injector scaling on UTECS (which you should probably use), people had some luck running -14 to -16 in the 0% col. Check the modded stock injector threads for more details.
-Sean
big_adventure is offline   Reply With Quote
Old 08-13-2004, 08:13 AM   #7
wrx plus
Member#: 42253
2003 RWD WRX
Alcohol injected, WRB
Make sure "open loop" fueling is "on". Set your stock size to 550 (txs stage 4 maps are based on pinks) scale to 810. Go +3,+2,+1 progressively in you 0% column until approx. 4500rpms, and keep boost down until fueling is better. That will give you a good start.
Kent
wrx plus is offline   Reply With Quote
can someone post a pic of their trunk tension bars? anthonyrb98 Interior & Exterior Modification 5 12-31-2006 11:36 AM
Can someone post their halogen Bugeye and what kind of light bulb they are using? vicdeng Electrical & Lighting 3 03-24-2006 08:33 AM
FAVOR! Can someone post pics of their HIDs output and their kelving rating? thsiao Interior & Exterior Modification 2 01-18-2006 10:06 PM
Could Someone Post Pics of Their 05 Headlights? shinsain Texas Impreza Club Forum -- TXIC 2 11-06-2004 12:52 AM
can someone post a pic of their tee? philip_g Factory 2.0L Turbo Powertrain 6 04-14-2003 11:42 PM
Message Board Statistics All times are GMT -4. The time now is 04:20 PM.
