Old 08-11-2004, 07:01 PM   #1
RiftsWRX
Member#: 6124
2000 NFR AP1 S2000
'07 Honda FIT sport (5MT)
Default Finally did the part break out used to build my water injection kit
http://www.projectwrx.com/modules.ph...howpage&pid=34 <-- This is the kit that I bought from Navy Blue Subaru way back when it was still affordable. It can be found here. Enjoy!
Jorge (RiftsWRX)
www.ProjectWRX.com
RiftsWRX is offline   Reply With Quote
Old 08-12-2004, 11:13 AM   #2
DISCOPOPE
Member#: 43339
2oo4 STi
URgt35r w/t3hM3finj3cki0n
wow.
very cool.
thanks man.
what are your idea's/concerns with winterizing this system?
DISCOPOPE is offline   Reply With Quote
Old 08-12-2004, 11:15 AM   #3
RiftsWRX
Member#: 6124
2000 NFR AP1 S2000
I run blue washer fluid heheh 25% alchy content.
Jorge (RiftsWRX)
www.ProjectWRX.com
Old 08-12-2004, 12:28 PM   #4
TreyS
Member#: 42478
2004 WRX STi
White/Gold
Nice link!!! Can you post some installed pics for reference?
TreyS is offline   Reply With Quote
Old 08-12-2004, 01:13 PM   #5
RiftsWRX
Member#: 6124
2000 NFR AP1 S2000
I'll try and make some time to work on that this weekend, but with the shootout I doubt I'll have time.
Besides.. it's more imagination at this point.
Jorge (RiftsWRX)
www.ProjectWRX.com
Old 08-12-2004, 02:19 PM   #6
pestysti
Member#: 52765
2004 STI
I guess in theroy you could use the Stock STI water spray tank and change out the nozzels and wire it up to the UTEC to control and every thing should work fine Right correct me if i am wrong.
<<<<<< not sure on the factory pump specs..that might have an efect on the out come.
has any one done this yet.
Dustin
pestysti is offline   Reply With Quote
Old 08-12-2004, 02:32 PM   #7
big_adventure
Member#: 40501
2005 Decathalon 21sp
One WheelSeanPower
Jorge, thanks.
I really didn't want to spend any more on the beast just now. I think I actually thought to myself, perhaps 2 days ago, that if I could find all of the WI parts for $200 I'd go for it.
And there it is, just like magic.
I've already ordered all the parts, including 5 and 10 GPH jets.
Race gas all the time! Plus, at $200, I'll make it up in fuel economy.
big_adventure is offline   Reply With Quote
Old 08-12-2004, 02:47 PM   #8
TurboPhoon
Member#: 5946
Does anyone know how exactly you connect the utec to the aquamist system?
TurboPhoon is offline   Reply With Quote
Old 08-12-2004, 03:21 PM   #9
big_adventure
Member#: 40501
One WheelSeanPower
The same way. If you go to the Aquamist site, you can see the schematic for the 2c on its page. There are 2 lead wires into the solenoid.
-Sean
Old 08-12-2004, 03:32 PM   #10
TreyS
Member#: 42478
2004 WRX STi
White/Gold
-Sean
Don't get up, I'll do it.....
Old 08-12-2004, 04:00 PM   #11
big_adventure
Member#: 40501
One WheelSeanPower
They trick you by calling it a "high-speed inline valve". This is English for "solenoid"
-S
Old 08-12-2004, 08:43 PM   #12
TreyS
Member#: 42478
2004 WRX STi
White/Gold
Those sneaky bastiges!!
Old 08-13-2004, 08:31 AM   #13
big_adventure
Member#: 40501
One WheelSeanPower
Jorge,
What do you use for a filter, or do you use one?
-Sean
Old 08-13-2004, 08:37 AM   #14
Pavlo
Member#: 23015
95-> GC8
Black, blue and blue
Actually the high speed valve is just that. It's not just a solenoid as it can operate at 250hz to actually control the flow water. This combined with either a spare mappable channel on an ECU (like those available on a MoTeC for instance) or the MF2, Aquamist's own WI controller, or finally the FIA thing that Aquamist to do link water flow to injector duty cycle.
An ordinary solenoid isn't up to the job of metering, but fine if you are just turning the WI on and off at set operating points.
Paul
Pavlo is offline   Reply With Quote
Old 08-13-2004, 08:40 AM   #15
big_adventure
Member#: 40501
One WheelSeanPower
Paul,
Yeah, I know, I read the good stuff on it. If the kit wasn't so freakin' expensive, I would have considered it or pieces of it.
I was just making the answer simple, rather than overly complex. Given that all of that info is on the website in public domain, I didn't see the need to repeat it for someone who didn't want to search. As it turns out, the individual in question has a 1c a-mist kit, and was looking for ideas to add UTEC control to it.
-Sean
Old 08-13-2004, 09:49 AM   #16
RiftsWRX
Member#: 6124
2000 NFR AP1 S2000
Jorge,
-Sean
Nope... just use the nozzles built in screens.
Jorge (RiftsWRX)
www.ProjectWRX.com
Old 08-13-2004, 10:28 AM   #17
big_adventure
Member#: 40501
One WheelSeanPower
Jorge (RiftsWRX)
www.ProjectWRX.com
Thanks - keeping the price well under $200 shipped. Yeah, I know, it sounds stupid after spending $20K on mods in the last 13 months.
-S
Old 08-13-2004, 10:38 AM   #18
RiftsWRX
Member#: 6124
2000 NFR AP1 S2000
-S
20k?!?
that's it? *groan* heh
Jorge (RiftsWRX)
www.ProjectWRX.com
Old 08-13-2004, 10:41 AM   #19
big_adventure
Member#: 40501
One WheelSeanPower
Well, after selling off all the parts I've sold off, I think that's about it. Gross, it's somewhat more, well, gross.
Gross, it's a lot closer to 30 than 20. And don't forget, I replaced motor/tranny/etc BEFORE any of them broke.
-S
Old 08-14-2004, 08:10 AM   #20
turboICE
Member#: 33979
2006 STi,'11 OBS
WRB & Black/Silver
Any electronically controlled valve can be called a solenoid - the key on the HSV is the high speed part. 1ms opening, 1ms closing, 250MHz - I guess a fuel injector should be called a fuel solenoid then. The term HSV is not inaccurate or misleading, leading someone to believe a part meant to be an on or off static valve (i.e. generic solenoid) is the same thing would be inaccurate.
turbophoon, if you search through summer 2003 posts you will see where an Aussie in St. Louis ( < don't recall the screen name but it relates to that) hooked up the HSV to the UTEC boost control. He got a patch from TXS to the software though so that he could map the duty cycles more cleanly for his 2d.
turboICE is offline   Reply With Quote
Old 08-14-2004, 11:45 AM   #21
DarthChicken
Member#: 9073
2006 ariel atom
wrb/bbs gold frame
My experience with the HSV part from Aquamist was not a good one. After about 9 months, it started leaking.... every drop of water it drips, it kicks the pump back on (because the pressure behind it drops). When it started leaking, my pump would kick on for about a half second.... stop for 4 seconds.... drip... on.... drip... on.... drip...
Could I use this solenoid valve to replace my aquamist part? Looks like it works in exactly the same way.
DarthChicken is offline   Reply With Quote
Old 08-14-2004, 02:42 PM   #22
turboICE
Member#: 33979
2006 STi,'11 OBS
WRB & Black/Silver
Yes you can if it will operate at the frequency you require and has a responsive open/close time - if you are using it to meter the rate of water. If you just want an on/off static valve sure almost any solenoid would do. Why haven't you returned the HSV for warranty?
Old 08-15-2004, 12:53 AM   #23
DarthChicken
Member#: 9073
2006 ariel atom
wrb/bbs gold frame
I tried doing warranty return, but it was well past the warranty date when it broke. Its a fairly expensive part, and both Sponaugle and mine broke down at about the same time.
I would just use it for on/off, at a specific duty cycle. I'll probably go ahead and get this, but control it with my Hydra at some point
Old 08-15-2004, 12:13 PM   #24
turboICE
Member#: 33979
2006 STi,'11 OBS
WRB & Black/Silver
Oh, I guess it broke after 9 months of use rather than 9 months from purchase?
Old 08-15-2004, 01:06 PM   #25
DarthChicken
Member#: 9073
2006 ariel atom
wrb/bbs gold frame
Yes, 9 months of use.
Methanol/Water Injection kit from coolmist.com - used $225 obo H.K. Phooey TXIC Private Classifieds 1 12-13-2009 09:23 AM
Methanol/Water Injection kit from coolmist.com - used $225 obo H.K. Phooey Engine/Power/Exhaust 1 12-13-2009 09:23 AM
can I use a fuel pressure gauge for my water injection setup? garie Water/Methanol Injection, Nitrous & Intercooler Cooling 1 11-18-2005 11:51 AM
Finally did the part break out used to build my water injection kit RiftsWRX Water/Methanol Injection, Nitrous & Intercooler Cooling 11 08-12-2004 11:57 AM
what parts would i need to build my own turbo kit? suberstar 2.5 Normally Aspirated Powertrain 1 02-17-2001 07:25 AM
