Welcome to the North American Subaru Impreza Owners Club Thursday September 1, 2016
Old 08-11-2004, 07:03 PM   #1
RiftsWRX
Member#: 6124
2000 NFR AP1 S2000
'07 Honda FIT sport (5MT)
Default Finally did the part break out used to build my water injection kit
http://www.projectwrx.com/modules.ph...howpage&pid=34 <-- This is the kit I bought from Navy Blue Subaru when it was still affordable. It can be found here. Enjoy!
Jorge (RiftsWRX)
www.ProjectWRX.com
RiftsWRX is offline   Reply With Quote
Old 08-11-2004, 10:21 PM   #2
hotrod
Member#: 14141
2002 Impreza WRX
Default home built kits
I am using very similar hardware on my home built kit. Unforturnately the shurflo pumps are close to $90 now, including shipping ($11 shipping fee for a single pump) for the 100 psi pump. I chose to go with aeroquip -3 lines for my pressure lines which is much more expensive, but that was my personal preference. Many other lower cost lines are available.
I'm still experimenting with the actual configuration so I do not have a "fixed" setup at this time.
I use a pressure accumulator so the pump does not need to cycle as often and a simple pressure switch trigger for the solenoid. I have an idiot light wired to the solenoid side of the pressure switch so I can see when the pressure switch closes. I also hooked a push button in parallel with the pressure switch so I can manually spray at any pressure for experimental purposes.
Larry
hotrod is offline   Reply With Quote
Old 08-12-2004, 01:43 AM   #3
Macabre
Member#: 3841
2004 WRX Wagon
UTEC+VF22+WI
Is there really anything different between the various 8000-series shurflo pumps, other than the pressure switch? By cranking down the set screw and using an external regulator, I've had my 8009-543-236 well over 100psi on the bench. My setup is very similar to Rifts' but with an FPR and the shurflo's pressure switch locked down.
Macabre is offline   Reply With Quote
Old 08-12-2004, 09:22 AM   #4
tdxflex
Member#: 13634
The amount of flow, but the smallest one flows 1 gpm (3785 cc/min), which is way more than you'll ever use.
tdxflex is offline   Reply With Quote
Old 08-12-2004, 10:21 AM   #5
RiftsWRX
Member#: 6124
2000 NFR AP1 S2000
Larry
-3? man your crazy dude hehehe
But I love ya just the same!
Jorge (RiftsWRX)
www.ProjectWRX.com
Old 08-12-2004, 10:34 AM   #6
vile
Member#: 32371
'02 t-rex wagon
platinum
hey jorge, for the lazy people, can you also list where you sourced your parts?
vile is offline   Reply With Quote
Old 08-12-2004, 10:42 AM   #7
hotrod
Member#: 14141
2002 Impreza WRX
Thanks Jorge
I think there are two differences on the pumps. As you mention I think one difference is the factory setting on the pressure switch shut off. The second I understand is that Shurflo has different pump head assemblies with different seal/diaphram materials so users can select the ideal pump materials for the fluids they are using.
I got the 8000-543-238 pump which has viton seals and santoprene diapharm. That appears to be the normal over the counter configuration, but one of the guys on one of the Buick GN boards mentioned he had called Shurflo and was told he could order different pump heads/seal materials. I have not personally confirmed that info though.
Larry
Old 08-12-2004, 10:51 AM   #8
RiftsWRX
Member#: 6124
2000 NFR AP1 S2000
Click the links on the parts....
Jorge (RiftsWRX)
www.ProjectWRX.com
Old 08-12-2004, 10:56 AM   #9
RiftsWRX
Member#: 6124
2000 NFR AP1 S2000
Thanks Jorge
Larry
I'm going to reference your pump as an alternate on the article.
http://www.yubit.com/shurflo_8000.htm <-- that's one place I found, if you have a place you'd recommend for purchase I'll link it directly.
Jorge (RiftsWRX)
www.ProjectWRX.com
Old 08-12-2004, 11:17 AM   #10
Macabre
Member#: 3841
2004 WRX Wagon
UTEC+VF22+WI
They definitely offer different seal materials, and other various configurations, but I'm more concerned that perhaps running my 236 pump at higher pressure may reduce the reliability of the diaphram.
http://www.shurflo.com/pages/new_ind...ADP_12DVC.html
Optimistically I'll assume that by listing "Pressures up to 150 PSI (10.3 bar) " as a general feature, it means all their pumps can handle that and they only vary the switch (even though that's probably not what it means)
Old 08-12-2004, 11:42 AM   #11
tdxflex
Member#: 13634
Another source for the pump, just a couple dollars cheaper. They also have the 8030-813-239, 150psi pump
http://www.sprayingequipmentsupply.c...ragm-pump.html
Old 08-12-2004, 11:57 AM   #12
hotrod
Member#: 14141
2002 Impreza WRX
Here's some other parts info:
McMaster and Carr nozzles, Catalog page 1898 - 1901
www.mcmaster.com
#'s [email protected] [email protected]
3178K81 0.63 1.0
3178K82 1.26 2.0
3178K83 1.90 3.0
3178K84 2.53 4.0
3178K85 3.16 5.0
3178K86 6.32 10.0
3178K87 9.49 15.0
(probably ought to get the nickle plated nozzles)
Hobbs Pressure Switch Napa Auto Parts $35.00 P/N# 701-1575 This switch IS adjustable! Pop off the rubber cap on one end and adjust away!
-NAPA/Balkamp Adjustable Pressure Switch (NAPA) P/N: 701-1577 high pressure
-NAPA/Balkamp Adjustable Pressure Switch (NAPA) P/N: 701-1575 low pressure
Automotive 12V 30 Amp Relay Radio Shack $5.00 P/N# 275-226
Power Aire Solenoid (Power Aire) P/N: (~$37.00)
32k5DGV-12VDC
http://sprayingequipmentsupply.com/...hragm-pump.html
Shurflo pumps
8000-543-238 (100 psi)
8030-813-239 (150 psi)
Low pressure pumps (~$55.00)
Flowjet Model # LF122202A
35 psi 1.1 GPM
smaller than the shurflo,(about 2/3 the size) works okay for low pressure spray applications like intercooler sprayer etc. (would work fine for NA applications that did not spray against high manifold pressures)
Larry
Methanol/Water Injection kit from coolmist.com - used $225 obo H.K. Phooey TXIC Private Classifieds 1 12-13-2009 09:23 AM
Methanol/Water Injection kit from coolmist.com - used $225 obo H.K. Phooey Engine/Power/Exhaust 1 12-13-2009 09:23 AM
can I use a fuel pressure gauge for my water injection setup? garie Water/Methanol Injection, Nitrous & Intercooler Cooling 1 11-18-2005 11:51 AM
Finally did the part break out used to build my water injection kit RiftsWRX Water/Methanol Injection, Nitrous & Intercooler Cooling 29 08-17-2004 01:35 PM
what parts would i need to build my own turbo kit? suberstar 2.5 Normally Aspirated Powertrain 1 02-17-2001 07:25 AM
