Welcome to the North American Subaru Impreza Owners Club Tuesday July 28, 2015
Old 01-10-2001, 02:31 PM   #1
joostin420
Member#: 1046
2007 WRX Wagon
UGM
Question seriously, how hard is it to do the DIY clear corners?
seriously, how hard is it to do the DIY clear corners? i think i am going to rty and find someone who has stock ones laying around, if anyone has any?
thanx,
justin
joostin420 is offline   Reply With Quote
Old 01-10-2001, 02:34 PM   #2
sspriest
Member#: 3109
2000 2.5RS BRP
05 MINI Cooper Chili Red
Post
Just follow the instructions and take your time. That easy.
sspriest is offline   Reply With Quote
Old 01-10-2001, 02:45 PM   #3
joostin420
Member#: 1046
2007 WRX Wagon
UGM
Question
got any tips or extra advice, like what is used to adhere the two peices back together obviously the stuff already existing on them, but anything better? say, taking off the existing goo and replacing it with something better?
also what size bulbs go into the housing after, and do i have to put orange bulbs in them, or can i use something different, i live in Massachusetts?
going to do this on an MY00 RS
thanx,
justin
[This message has been edited by joostin420 (edited January 10, 2001).]
Old 01-10-2001, 03:01 PM   #4
8Complex
Member#: 922
16 WRX (white)
04 FXT (red)
Post
Just get a set of the clears. I think they're around $60 and you've got your spare set still plus you've saved by not buying the other stock set as the backups.
Old 01-10-2001, 03:05 PM   #5
STiShawn
Member#: 2348
2006 WRX TR
Steel Grey Metallic
Post
If you go DIY, use a heat gun,the hair dryer takes forever. Just dont hold it in one place and melt your lense, and use gloves, you can get burned easily. I did it and never cracked either of them. Use the heat gun and a paint scraper to do it. Lineing(sp) them back up at the end is the toughest part.
STiShawn is offline   Reply With Quote
Old 01-10-2001, 03:57 PM   #6
stimpy
Homicidal Maniac
Member#: 1612
2008 STI
Post
I think if you search back into the archives, you should be able to find lots of good info (some of which was mine ). Its been awhile, but lets see here: I used a hair dryer for mine and slowly worked around the edges. I kept it almost too hot to touch and slowly pulled apart with even force. Keep going, they will eventually come apart. Once apart, I just used a dremel with a small bit and then broke off the pieces with a small set of pliers. I went back over the edges where the orange attached to clean it up. Then you just heat up the goo (again almost too hot to touch) and slowly press it back together. Keep heating it until its all together.
As for the bulbs, I went to the local ******* shop and bought some japanese hybrid blue bulbs.
http://216.242.153.40/MembersList/Vi...15&PicNumber=1
I'm completely satisfied with them. No need to spend the money on real OEM clears.
Old 01-10-2001, 05:24 PM   #7
ImprezaL
Member#: 1393
Lightbulb
The only thing I did really differently was instead of "chipping" off the orange part, I softened it with the heat gun and then used an exacto knife to slowly "peel" if off. Just take your time and use some other kind of adhesent besides the stuff that already there, and you're set!
ImprezaL is offline   Reply With Quote
Old 01-10-2001, 06:06 PM   #8
stimpy
Homicidal Maniac
Member#: 1612
2008 STI
Thumbs up
I hadn't thought of that ImprezaL, good show!
Course, the adhesive for the orange stuff wasn't that strong and the orange piece basically snapped right off the attachment point.
Old 01-10-2001, 10:08 PM   #9
Swivel1000
Member#: 1168
2004 Jeep Grand
Cherokee Limited 4x4
Post
I would buy clear corners...It looks MUCH better. After i did my DIY the space where the orange used to be just looks out of place.
matt
Swivel1000 is offline   Reply With Quote
Old 01-10-2001, 11:29 PM   #10
Subaruza
Member#: 980
2000 Impreza RS
Blue Ridge Pearl
Talking
I did mine about a year ago now and didn't use a heat gun or hair dryer. The people were still testing it and I figured heat makes plastic brittle so why risk it. It still worked fine with no cracks or stress marks. I think the real key is... take... your... time. I agree with Swivel though the bought clears look better.
Subaruza is offline   Reply With Quote
Old 01-11-2001, 07:39 AM   #11
ImprezedRS
Member#: 2771
2003 BMW Z4
Post
Take your time is all i got to say as i was in a rush and got a small crack in one of mine but you can't see it unless you get upclose.
ImprezedRS is offline   Reply With Quote
Old 01-11-2001, 08:36 AM   #12
mykrrrr
Member#: 733
'13 Focus ST
Arrow
The true clears look much more finished than the DIY. I'm gonna get them once I find the lowest price. Any suggestions???
-myk
mykrrrr is offline   Reply With Quote
Old 01-11-2001, 11:40 AM   #13
22BARU
Member#: 1186
Exclamation
I have a 98 RS and got mine off fine with use of a professional heat gun.
My girlfriend has a 2000 RS. I tried to do hers and no matter what I did, hers would not come free, I actually cracked hers a little. Don't know if they changed for 2000 but the gasket material is sure different.
just be carefull
22BARU is offline   Reply With Quote
Old 01-11-2001, 04:35 PM   #14
White01
Member#: 1913
Post
Go with the OEM clears. It looks much better. Keep your eye on ebay. I just got mine a few weeks ago. I won the auction on Christmas for $48. They fit perfect and look great.
my $.02
White01 is offline   Reply With Quote
Old 01-11-2001, 06:32 PM   #15
JGard
pooptastic
Member#: 1904
2011 BMW X5 35D
01 Miata red
Post
hey, joostin, i live near you. i did it to mine, and i can help you out with yours if you want. It's pretty easy, and you don't need anything extra.
JGard is offline   Reply With Quote
Old 01-12-2001, 12:40 AM   #16
STiShawn
Member#: 2348
2006 WRX TR
Steel Grey Metallic
Post
I used a dremel to remove the oragnge lip and then popped them out. I would by the OEM clears, but I'd rather go fast or turn better....These are free.
Old 01-12-2001, 08:13 AM   #17
rpone605
Member#: 1669
2004 WRX Sport Wagon
Post
You lazy people.
Doing the clears is easy if you take your time and don't pull hard and pay attention to the tabs.
rpone605 is offline   Reply With Quote
Old 01-12-2001, 11:26 AM   #18
M a t t
Guest
Member#:
Post
i suggest a new bulb. it looks like poo w/ the stock one.
Old 01-13-2001, 04:47 PM   #19
vinniezucchini
Member#: 3512
Post
i just did it and it was easy just follow the instuctions
vinniezucchini is offline   Reply With Quote
Old 01-13-2001, 07:21 PM   #20
jimmythagreek
Member#: 2797
01 RSTI / 00OBS
Post
i just did mine tonight. i have a heat gun which makes the job hell of a lot easier. use the heat gun on the orange part until they start to sqeak and bend then pop them out. it took me 45 minutes and no cracks. just remember not to heat the clear part but the backing. it makes that chewing gum/tree sap stuff more workable.
jimmythagreek is offline   Reply With Quote
Old 01-13-2001, 11:58 PM   #21
kkeetha
Member#: 332
Post
Seriously man, just buy a set of the cleared ones. Look much beeter than the DIY ones.
kkeetha is offline   Reply With Quote
full vinyl car wrapping - who has done it? how hard is it to do? any issues removing? mattesonb Interior & Exterior Modification 121 08-07-2013 12:57 AM
how hard is it to do a front bumper swap(sedan to wagon) veightkiller Interior & Exterior Modification 8 02-03-2005 11:30 PM
How hard is it to remove the F/R lips on the OEM body kit? Butt Dyno Interior & Exterior Modification 6 09-11-2003 06:44 PM
How easy is it to do the clear headlights? (taking out the yellow housing) S-WRX Interior & Exterior Modification 16 10-10-2001 11:37 AM
HOw hard is it to do the DIY clear corners? Keith General Forum Archive 3 05-15-2000 07:00 AM
