Old 08-13-2004, 12:34 AM   #1
JustDSM
Member#: 17502
Default 18G/TMIC logs.. What do you see? (High Altitude)
Car:
2003 WRX 2.0L Stock long-block.
Elevation: 6000ft ASL
Stock airbox w/ paper filter
Spearco TMIC w/ Vishnu hoses
Mildly ported stock exhaust manifolds
HKS uppipe (heat wrapped)
FP 18G (7cm)
Generic bellmouth downpipe
Skunk2/Invidia exhaust
JoeP MBC
NGK 7ES plugs @ .28"
UTEC using 3.1 software
Here's two logs for your viewing pleasure. Questions, concerns, and comments are very welcome.
First log:
-3rd gear pull
Code:
     DATA1
    ,     ,    ,   ,Load,Knock,    ,      ,      , Mod,  Mod,      , Mod
 RPM,  MAP, MAF,TPS,Site,Count, AFR, Ign#1, Inj#1, Ign,  Fuel,Boost, MAF
    ,  psia, V , % ,    ,     ,    ,  deg , duty , deg,   %  ,(OL) ,  V
 2360, -4.5,1.8,  4, 00,   00,  14.7,+29.5,   4.0,ECU. , -6.0,ECU.  ,1.7
 2379, -4.5,1.8,  4, 00,   00,  14.7,+29.5,   4.0,ECU. , -6.0,ECU.  ,1.7
 2594, -7.5,2.0, 15, 00,   00,  23.2,+27.9,  65.0,ECU. , -6.0,ECU.  ,2.5
 2618, -7.5,2.0, 15, 00,   00,  23.2,+25.7,   7.0,ECU. , -6.0,ECU.  ,2.5
 2604, -5.3,2.3,102, 10,   00,  13.5,+35.6,  10.0,ECU. , -4.3,ECU.  ,2.3
 2690, -3.0,2.4,102, 10,   00,  12.5,+34.4,  11.0,ECU. , -4.3,ECU.  ,2.3
 2718, -0.8,2.4,102, 10,   00,  12.2,+34.1,  12.0,ECU. , -4.3,ECU.  ,2.4
 2738, +1.2,2.5,102, 10,   00,  rich,+33.4,  12.0,ECU. , -4.3,ECU.  ,2.4
 2757, +1.6,2.5,102, 10,   00,  rich,+33.4,  13.0,ECU. , -3.8,ECU.  ,2.4
 2777, +1.9,2.6,102, 20,   00,  12.0,+33.2,  13.0,ECU. , -4.1,ECU.  ,2.5
 2815, +2.3,2.6,102, 20,   00,  rich,+33.1,  14.0,ECU. , -4.0,ECU.  ,2.5
 2873, +2.8,2.7,103, 20,   00,  rich,+33.0,  15.0,ECU. , -3.9,ECU.  ,2.6
 2926, +3.4,2.7,102, 20,   00,  rich,+31.0,  16.0,ECU. , -3.9,ECU.  ,2.6
 2976, +3.8,2.8,102, 20,   00,  rich,+27.9,  17.0,ECU. , -3.8,ECU.  ,2.7
 3033, +4.3,2.8,102, 30,   00,  rich,+25.2,  19.0,+20.0, -3.7,ECU.  ,2.7
 3083, +4.9,2.9,102, 30,   00,  rich,+23.4,  20.0,+19.6, -3.6,ECU.  ,2.8
 3103, +5.4,2.9,102, 30,   00,  rich,+21.2,  21.0,+19.2, -3.5,ECU.  ,2.8
 3171, +6.2,3.0,102, 40,   00,  rich,+19.7,  23.0,+18.6, -3.9,ECU.  ,2.8
 3252, +6.9,3.0,102, 40,   00,  rich,+18.3,  24.0,+18.2, -3.9,ECU.  ,3.0
 3310, +7.4,3.2,102, 40,   00,  rich,+16.6,  27.0,+17.8, -3.8,ECU.  ,3.0
 3373, +8.2,3.3,102, 50,   00,  rich,+14.0,  32.0,+17.0, -4.0,ECU.  ,3.2
 3450, +9.3,3.3,102, 50,   00,  rich,+12.5,  38.0,+17.0, -4.0,ECU.  ,3.2
 3512,+10.4,3.4,102, 60,   00,  rich, +9.1,  44.0,+15.0, -4.0,ECU.  ,3.3
 3603,+12.0,3.6,102, 70,   00,  rich, +7.4,  52.0,+14.0, -4.2,ECU.  ,3.4
 3679,+14.3,3.8,102, 80,   00,  rich, +5.8,  59.0,+13.0, -4.6,ECU.  ,3.5
 3800,+16.5,3.8,102, 90,   00,  rich, +6.2,  62.0,+12.0, -5.0,ECU.  ,3.6
 3871,+18.1,3.9,102,100,   00,  rich, +7.0,  62.0,+12.0, -5.3,ECU.  ,3.6
 3944,+19.2,3.9,102,100,   00,  rich, +7.9,  61.0,+12.0, -5.8,ECU.  ,3.6
 4055,+19.8,3.9,101, 90,   00,  rich, +8.9,  63.0,+12.4, -6.3,ECU.  ,3.5
 4110,+19.6,3.8,101, 90,   00,  rich, +8.9,  64.0,+13.2, -6.5,ECU.  ,3.6
 4192,+19.0,3.9,101, 90,   00,  rich, +9.2,  66.0,+13.8, -6.6,ECU.  ,3.6
 4340,+18.9,4.0,101, 90,   00,  rich, +8.8,  68.0,+15.5, -6.7,ECU.  ,3.7
 4462,+19.0,4.0,101, 90,   00,  rich, +9.0,  71.0,+16.7, -6.7,ECU.  ,3.7
 4492,+19.2,4.0,101,100,   00,  rich, +8.3,  74.0,+16.1, -6.4,ECU.  ,3.7
 4585,+19.6,4.0,101,100,   00,  rich, +8.0,  77.0,+16.4, -6.4,ECU.  ,3.8
 4681,+19.8,4.1,102,100,   00,  rich, +8.5,  77.0,+16.5, -6.4,ECU.  ,3.8
 4748,+19.6,4.0,102, 90,   00,  rich, +8.8,  78.0,+18.0, -6.7,ECU.  ,3.8
 4859,+19.4,4.0,101, 90,   00,  rich,+10.1,  78.0,+18.0, -6.7,ECU.  ,3.8
 4930,+19.0,4.1,101, 90,   00,  rich,+11.5,  79.0,+18.0, -6.7,ECU.  ,3.8
 5104,+18.9,4.1,101, 90,   00,  rich,+13.4,  81.0,+18.0, -6.7,ECU.  ,3.8
 5096,+19.2,4.1,102, 90,   00,  rich,+14.7,  82.0,+18.0, -6.7,ECU.  ,3.8
 5282,+19.0,4.2,102, 90,   00,  rich,+15.3,  84.0,+18.0, -6.5,ECU.  ,3.9
 5282,+19.2,4.2,102, 90,   00,  rich,+15.4,  85.0,+18.0, -6.7,ECU.  ,3.9
 5376,+19.2,4.2,101, 90,   00,  rich,+15.7,  86.0,+18.0, -6.5,ECU.  ,3.9
 5420,+19.2,4.2,102, 90,   00,  rich,+15.8,  87.0,+18.0, -6.5,ECU.  ,4.0
 5491,+19.0,4.2,101, 90,   00,  rich,+15.3,  88.0,+18.0, -6.4,ECU.  ,4.0
 5630,+18.3,4.3,102, 90,   00,  rich,+15.9,  89.0,+18.0, -6.4,ECU.  ,3.9
 5787,+18.3,4.3,102, 90,   00,  rich,+16.0,  90.0,+18.0, -6.4,ECU.  ,4.0
 5847,+17.7,4.3,101, 90,   00,  rich,+16.7,  90.0,+18.0, -6.4,ECU.  ,4.0
 5797,+17.6,4.3,101, 80,   00,  rich,+16.9,  88.0,+18.4, -7.0,ECU.  ,3.9
 5868,+18.3,4.2,100, 90,   00,  rich,+16.9,  89.0,+18.5, -6.4,ECU.  ,4.0
 5984,+18.3,4.3,102, 90,   00,  rich,+17.4,  92.0,+18.8, -6.4,ECU.  ,4.0
 6038,+17.9,4.3,102, 80,   00,  rich,+17.8,  91.0,+20.1, -7.0,ECU.  ,4.0
 6060,+18.3,4.3,102, 80,   00,  rich,+18.5,  89.0,+20.3, -6.9,ECU.  ,4.0
 6253,+18.3,4.3,102, 90,   00,  rich,+18.4,  91.0,+19.7, -6.4,ECU.  ,4.0
 6277,+17.7,4.3,101, 90,   00,  rich,+20.9,  92.0,+20.2, -6.4,ECU.  ,4.0
 6277,+18.3,4.3,101, 90,   00,  rich,+21.3,  93.0,+20.2, -6.3,ECU.  ,4.0
 6361,+18.3,4.4,102, 90,   00,  rich,+21.0,  94.0,+20.7, -6.3,ECU.  ,4.1
 6447,+17.4,4.3,101, 80,   00,  rich,+21.1,  93.0,+21.6, -6.3,ECU.  ,4.0
 6561,+17.2,4.3,101, 80,   00,  rich,+21.0,  94.0,+22.0, -6.0,ECU.  ,4.1
 6600,+16.8,4.3,101, 80,   00,  rich,+21.2,  93.0,+22.1, -6.0,ECU.  ,4.0
 6640,+17.4,4.3,102, 90,   00,  rich,+21.1,  95.0,+21.2, -5.8,ECU.  ,4.1
 6626,+17.7,4.3,101, 90,   00,  rich,+21.6,  95.0,+21.8, -5.7,ECU.  ,4.1
 6734,+18.1,4.4,101, 80,   00,  rich,+21.5,  94.0,+22.9, -6.0,ECU.  ,4.1
 6775,+17.6,4.3,101, 80,   00,  rich,+21.5,  94.0,+23.0, -6.0,ECU.  ,4.1
 6653,+16.3,3.8, 11, 00,   00,  rich,+41.1,  32.0,ECU. , -6.0,LCM.  ,2.4
Next is a 2step launch and pull:
Code:
     DATA1
  721, -6.2,1.1,  0, 00,   00,  14.7,+13.5,   1.0,ECU. , -6.0,ECU.  ,1.1
  724, -6.2,1.1,  0, 00,   00,  14.7,+13.3,   1.0,ECU. , -6.0,ECU.  ,1.1
 1012, -4.7,1.2,  0, 00,   00,  16.7, +3.7,   1.0,ECU. , -6.0,ECU.  ,1.1
  975, -5.8,1.3,  0, 00,   00,  16.4,+11.0,   1.0,ECU. , -6.0,ECU.  ,1.2
  995, -6.2,1.6,  4, 00,   00,  15.8,+13.4,  13.0,ECU. , -6.0,ECU.  ,1.8
 1460, -4.7,2.0, 21, 00,   00,  12.5,+24.1,   5.0,ECU. , -6.0,ECU.  ,1.9
 2259, -3.0,2.2, 37, 00,   00,  14.9,+34.8,   7.0,ECU. , -6.0,ECU.  ,2.1
 2978, -1.2,2.4, 69, 10,   00,  17.0,+34.7,  11.0,ECU. , -3.5,ECU.  ,2.4
 4001, +0.3,2.7, 71, 10,   00,  13.5,+37.4,  17.0,ECU. , -4.1,ECU.  ,2.7
 5042, +0.8,3.1, 66, 10,   00,  13.3,+34.5, ---.-,ECU. , -5.4,ECU.  ,3.1
 5446, +1.4,3.4,101, 20,   00,  18.4,+31.9,  39.0,ECU. , -5.5,LCM.  ,3.2
 5446, +2.1,3.5,102, 20,   00,  24.0,+29.5,  42.0,ECU. , -5.5,LCM.  ,3.4
 5500, +3.4,3.6,101, 30,   00,  23.7,+28.2,  48.0,+20.0, -5.5,LCM.  ,3.6
 5518, +4.7,3.6,102, 30,   00,  24.0,+27.2,  50.0,+20.0, -5.3,LCM.  ,3.6
 5640, +6.2,3.8,102, 40,   00,  23.7,+26.3,  54.0,+20.2, -6.3,LCM.  ,3.6
 5611, +7.6,3.9,102, 50,   00,  24.0,+25.4,  58.0,+20.0, -7.0,LCM.  ,3.6
 5376, +8.9,3.9,102, 50,   00,  23.7,+22.4,  64.0,+20.0, -7.3,LCM.  ,3.7
 5136,+11.5,4.1,101, 70,   00,  rich,+16.1,  75.0,+19.0, -8.6,ECU.  ,3.7
 5291,+14.4,4.1,101, 90,   00,  rich,+16.4,  81.0,+18.0, -6.7,LCM.  ,3.8
 5232,+17.0,4.1,102, 90,   00,  rich,+15.7,  83.0,+18.0, -6.7,ECU.  ,3.9
 4636,+18.7,4.1,102, 90,   00,  rich, +9.0,  78.0,+17.0, -6.7,ECU.  ,3.8
 4224,+18.9,3.9,102, 90,   00,  rich, +9.7,  65.0,+12.6, -6.4,ECU.  ,3.6
 4100,+18.9,3.8,101, 90,   00,  rich, +9.7,  62.0,+13.2, -6.5,ECU.  ,3.6
 4741,+19.0,4.0,102,100,   00,  rich,+10.3,  74.0,+17.0, -6.4,ECU.  ,3.8
 5159,+19.0,4.1,102, 90,   00,  rich,+16.9,  79.0,+18.0, -6.7,ECU.  ,3.8
 5777,+19.2,4.2,102, 90,   00,  rich,+16.6,  87.0,+18.0, -6.4,ECU.  ,4.0
 6195,+18.5,4.3,102, 90,   00,  rich,+21.3,  90.0,+20.2, -6.3,ECU.  ,4.0
 6640,+17.9,4.3,102, 80,   00,  rich,+21.5,  94.0,+22.4, -6.0,ECU.  ,4.1
 7032,+17.6,4.3,102, 80,   00,  rich,+21.5,  92.0,+23.0, -6.0,ECU.  ,4.1
 7107,+14.6,2.0,  0, 00,   00,  21.9,+41.0,  93.0,ECU. , -6.0,LCM.  ,2.6
 6105,+12.2,3.8,102, 40,   00,  24.0,+29.4,  55.0,+20.0, -6.3,ECU.  ,3.6
 4084,+11.1,3.7,102, 50,   00,  rich, +9.5,  61.0,+17.9, -6.8,ECU.  ,3.6
 4301,+11.3,4.0,102, 70,   00,  rich, +9.1,  70.0,+17.5, -7.6,ECU.  ,3.7
 4553,+14.3,4.0,102, 90,   12,  rich, +7.2,  75.0, +9.3, -6.7,ECU.  ,3.7
 4830,+17.0,4.1,102, 90,   00,  rich, +7.4,  80.0,+10.0, -6.7,ECU.  ,3.8
 5042,+18.5,4.1,102, 90,   00,  rich,+11.1,  79.0,+10.0, -6.7,ECU.  ,3.8
 5224,+19.6,4.1,102,100,   00,  rich,+13.7,  83.0,+17.0, -6.5,ECU.  ,3.9
 5420,+20.0,4.1,101,100,   00,  rich,+14.0,  86.0,+17.0, -6.4,ECU.  ,3.9
 5611,+20.5,4.2,102,100,   00,  rich,+13.8,  87.0,+17.0, -6.2,ECU.  ,4.0
 5747,+20.3,4.2,102, 90,   00,  rich,+13.7,  89.0,+18.0, -6.4,ECU.  ,4.0
 5878,+19.0,4.3,102, 80,   00,  rich,+15.5,  88.0,+19.0, -7.0,ECU.  ,4.0
 6027,+17.7,4.2,102, 80,   00,  rich,+16.9,  87.0,+20.1, -6.9,ECU.  ,4.0
 6230,+17.0,4.3,102, 80,   00,  rich,+16.6,  91.0,+20.8, -6.1,ECU.  ,4.1
 6397,+17.0,4.3,101, 90,   00,  rich,+18.7,  94.0,+20.4, -6.2,ECU.  ,4.0
 6600,+16.6,4.3,102, 80,   00,  rich,+18.8,  93.0,+22.0, -6.0,ECU.  ,4.1
 6472,+15.7,2.7,  0, 00,   00,  14.1,+11.0,  21.0,ECU. , -6.0,LCM.  ,1.5
 6049,+11.5,3.8,102, 30,   00,  23.7,+30.6,  45.0,+21.8, -5.2,LCM.  ,3.5
 4566, +9.3,3.7,102, 30,   00,  23.2,+11.9,  60.0,+20.0, -5.3,ECU.  ,3.6
 4837, +8.9,4.0,102, 60,   00,  rich, +9.6,  72.0,+20.0, -7.7,ECU.  ,3.7
 4894,+10.4,4.1,102, 80,   00,  rich,+11.2,  76.0,+18.2, -7.1,ECU.  ,3.8
 4930,+15.2,4.1,102, 90,   00,  rich,+10.7,  79.0,+18.0, -6.7,ECU.  ,3.8
 5058,+18.3,4.1,102,100,   00,  rich,+12.0,  81.0,+17.0, -6.5,ECU.  ,3.8
 5159,+19.0,4.1,102, 90,   00,  rich,+12.4,  82.0,+18.0, -6.7,ECU.  ,3.9
 5208,+19.0,4.1,102, 90,   00,  rich,+15.5,  80.0,+18.0, -6.5,ECU.  ,3.8
 5299,+18.5,4.1,102, 90,   00,  rich,+15.0,  83.0,+18.0, -6.7,ECU.  ,3.9
 5341,+18.1,4.1,101, 90,   00,  rich,+14.8,  84.0,+18.0, -6.5,ECU.  ,3.9
 5420,+18.9,4.2,101,100,   00,  rich,+14.8,  86.0,+17.0, -6.2,ECU.  ,3.9
 5611,+19.2,4.2,102,100,   00,  rich,+14.5,  86.0,+17.0, -6.2,ECU.  ,3.9
 5592,+19.4,4.2,102, 90,   00,  rich,+15.0,  87.0,+18.0, -6.4,ECU.  ,4.0
 5698,+19.6,4.3,102, 90,   00,  rich,+16.0,  89.0,+18.0, -6.4,ECU.  ,4.0
 5757,+19.2,4.2,101, 90,   00,  rich,+16.6,  88.0,+18.0, -6.4,ECU.  ,4.0
 5817,+19.2,4.3,102, 90,   00,  rich,+17.0,  88.0,+18.3, -6.4,ECU.  ,4.0
 5941,+19.8,4.3,102,100,   00,  rich,+17.0,  91.0,+17.7, -6.2,ECU.  ,4.0
 6049,+19.4,4.3,101, 90,   00,  rich,+17.4,  90.0,+19.0, -6.4,ECU.  ,4.0
 6127,+20.0,4.3,101, 90,   00,  rich,+17.6,  91.0,+19.2, -6.4,ECU.  ,4.0
 6127,+19.2,4.3,101, 90,   00,  rich,+18.2,  91.0,+19.5, -6.4,ECU.  ,4.0
 6218,+19.0,4.3,102, 90,   00,  rich,+18.8,  91.0,+19.8, -6.1,ECU.  ,4.0
 6265,+19.0,4.3,102, 90,   00,  rich,+21.2,  92.0,+20.0, -6.4,ECU.  ,4.0
 6385,+17.7,4.3,101, 80,   00,  rich,+21.3,  91.0,+21.2, -6.4,ECU.  ,4.0
 6397,+17.9,4.3,102, 80,   00,  rich,+21.5,  92.0,+21.8, -6.5,ECU.  ,4.0
 6472,+17.6,4.3,102, 90,   00,  rich,+21.2,  95.0,+20.7, -5.8,ECU.  ,4.1
 6485,+17.6,4.3,102, 90,   00,  rich,+21.2,  96.0,+21.0, -5.7,ECU.  ,4.1
 6574,+17.9,4.3,101, 90,   00,  rich,+21.2,  94.0,+21.3, -5.8,ECU.  ,4.0
 6613,+17.2,4.3,102, 80,   00,  rich,+21.6,  93.0,+22.6, -6.0,ECU.  ,4.0
 6734,+15.7,3.1,  0, 00,   00,  rich,+10.7,  15.0,ECU. , -6.0,LCM.  ,1.9
 6265,+11.3,3.5, 66, 40,   00,  21.4,+38.7,  41.0,+22.6, -5.7,LCM.  ,3.5
 4535, +9.3,3.6,102, 30,   00,  23.7,+15.8,  54.0,+19.9, -4.7,ECU.  ,3.6
 4901, +8.5,4.0,102, 50,   00,  rich,+12.6,  71.0,+20.0, -7.4,ECU.  ,3.7
 4844,+10.0,4.1,102, 80,   06,  rich, +8.8,  76.0,+10.8, -6.9,ECU.  ,3.8
 4844,+14.8,4.1,102, 90,   00,  rich, +8.0,  78.0,+10.0, -6.7,ECU.  ,3.8
 4873,+17.9,4.0,101,100,   00,  rich, +8.5,  79.0, +9.0, -6.4,ECU.  ,3.8
 4930,+19.4,4.1,101,100,   00,  rich, +9.0,  80.0,+17.0, -6.4,ECU.  ,3.8
 4952,+20.1,4.1,102,100,   00,  rich, +9.2,  79.0,+17.0, -6.4,ECU.  ,3.8
 5005,+20.3,4.1,102,100,   00,  rich, +9.3,  80.0,+17.0, -6.5,ECU.  ,3.8
 5012,+20.3,4.1,101,100,   00,  rich,+10.3,  80.0,+17.0, -6.5,ECU.  ,3.8
 5081,+20.5,4.1,101,100,   00,  rich,+11.5,  81.0,+17.0, -6.5,ECU.  ,3.8
 5112,+20.3,4.1,101,100,   00,  rich,+11.1,  80.0,+17.0, -6.5,ECU.  ,3.8
 5136,+19.2,4.1,100, 90,   00,  rich,+12.7,  80.0,+18.0, -6.7,ECU.  ,3.8
 5208,+18.5,4.1,101, 80,   00,  rich,+14.0,  78.0,+18.0, -7.3,ECU.  ,3.8
 5192,+18.7,4.1,101, 90,   00,  rich,+15.0,  81.0,+18.0, -6.7,ECU.  ,3.9
 5224,+18.1,4.1,101, 90,   00,  rich,+14.5,  81.0,+18.0, -6.7,ECU.  ,3.9
 5324,+19.2,4.1,102, 90,   00,  rich,+15.1,  82.0,+18.0, -6.7,ECU.  ,3.8
 5282,+20.1,4.1,102,100,   00,  rich,+15.0,  84.0,+17.0, -6.4,ECU.  ,3.9
 5333,+19.8,4.1,102,100,   00,  rich,+15.0,  83.0,+17.0, -6.5,ECU.  ,3.9
 5402,+20.1,4.2,101, 90,   00,  rich,+14.9,  83.0,+18.0, -6.6,ECU.  ,3.9
 5473,+19.2,4.1,102, 90,   00,  rich,+15.3,  83.0,+18.0, -6.6,ECU.  ,3.9
 5411,+19.2,4.2,102, 90,   00,  rich,+15.5,  83.0,+18.0, -6.6,ECU.  ,3.9
 5527,+19.2,4.2,102,100,   00,  rich,+15.1,  86.0,+17.0, -6.3,ECU.  ,4.0
 5574,+18.9,4.2,101, 90,   00,  rich,+14.9,  85.0,+18.0, -6.4,ECU.  ,3.9
 5491,+19.6,4.2,102, 90,   00,  rich,+14.8,  86.0,+18.0, -6.4,ECU.  ,3.9
 5500,+19.4,4.2,101,100,   00,  rich,+14.6,  87.0,+17.0, -6.2,ECU.  ,3.9
 5537,+18.7,4.2,101, 90,   00,  rich,+15.0,  86.0,+18.0, -6.4,ECU.  ,4.0
 5574,+18.7,4.2,102, 90,   00,  rich,+15.0,  87.0,+18.0, -6.4,ECU.  ,3.9
 5621,+18.9,4.2,102, 90,   00,  rich,+15.8,  88.0,+18.0, -6.4,ECU.  ,4.0
 5698,+18.5,4.2,101, 90,   00,  rich,+16.4,  88.0,+18.0, -6.4,ECU.  ,4.0
 5787,+18.5,4.3,102, 90,   00,  rich,+16.0,  88.0,+18.0, -6.4,ECU.  ,4.0
 5698,+19.0,4.2, 64, 90,   23,  rich,+15.8,  65.0,+10.0, -6.4,ECU.  ,3.8
 5491,+16.5,2.7,  0, 00,   00,  rich,+10.9,  27.0,ECU. , -6.0,ECU.  ,2.0
 5640,+10.6,1.7,  0, 00,   00,  16.4,+11.0,  27.0,ECU. , -6.0,ECU.  ,1.7
 5621, +4.5,1.9,  0, 00,   00,  24.0,+11.1,  27.0,ECU. , -6.0,LCM.  ,1.8
 5420, -2.1,2.0,  0, 00,   00,  24.0,+10.9,  27.0,ECU. , -6.0,LCM.  ,1.8
 5035, -6.4,2.0,  0, 00,   00,  24.2,+11.0,  27.0,ECU. , -6.0,ECU.  ,1.8
 4741, -6.9,1.9,  0, 00,   00,  24.2,+11.1,  27.0,ECU. , -6.0,ECU.  ,1.8
 4420, -7.1,1.9,  0, 00,   00,  24.2,+11.4,  27.0,ECU. , -6.0,ECU.  ,1.3
 3822, -7.1,1.8,  0, 00,   00,  24.0,+11.4,  27.0,ECU. , -6.0,ECU.  ,1.7
 3762, -7.3,1.7,  0, 00,   00,  23.7,+11.5,  27.0,ECU. , -6.0,ECU.  ,1.6
 3753, -7.1,1.7,  0, 00,   00,  24.0,+11.4,  27.0,ECU. , -6.0,ECU.  ,1.5
 3646, -7.1,1.6,  0, 00,   00,  24.2,+11.5,  27.0,ECU. , -6.0,ECU.  ,1.5
This isnt "tuned" by any means, but I am just starting to get it dialed in. Lets here it, good and bad.
JustDSM is offline   Reply With Quote
Old 08-13-2004, 12:44 AM   #2
cronic
Member#: 9749
Code:
Code:
Whats with that?
also
Code:
your running 23.7:1 at 9psi?
cronic is offline   Reply With Quote
Old 08-13-2004, 12:48 AM   #3
JustDSM
Member#: 17502
show me specificly where those lines are in the above logs. That will help me figure out what it is exactly your asking.
Old 08-13-2004, 12:50 AM   #4
cronic
Member#: 9749
well just lopok down your knock site column and look for 12, 23, and 6 counts..
Old 08-13-2004, 12:57 AM   #5
JustDSM
Member#: 17502
The car had less than 1/4 tank of 91 during these runs. Just to keep you informed.
The 12 count:
Knocked immediately after getting back to 100%TPS in 2nd. The motor in this car slams pretty violently when shifting aggressivly. I doubt that's got anything to do with it. I suspect fuel starvation. The ass end of this car really squats..
The 6 count:
Same as above, but this time in 4th.
the 23 count:
Happend just after I let off WOT and the boost had not fallen. 21.8psi.
Old 08-14-2004, 06:23 PM   #6
SmoknWRX
Member#: 44983
2003 impreza wrx
aspen
JustDSM.......................wideband O2? kinda hard to determine exact causes of your pre-ignition without knowing whats actually goin on past 12:1
SmoknWRX is offline   Reply With Quote
Old 08-14-2004, 07:11 PM   #7
cdvma
Member#: 21980
2002 PSM WRX (Sold)
2009 BMW X5
21 lbs on 91? Hrm. Thats also some nasty knock counts...I've never seen ones that high. Were they audible?
cdvma is offline   Reply With Quote
Old 08-14-2004, 07:14 PM   #8
cronic
Member#: 9749
That is what i am saying.. I get some 1 counts during hard shifting some time, but for god sakes a 23count
Old 08-15-2004, 12:24 AM   #9
SmoknWRX
Member#: 44983
2003 impreza wrx
aspen
i hit a 43 count once...........definitely not good, needless to say i fixed the glitch in my fuel map
Old 08-16-2004, 12:27 PM   #10
MAD REX
Member#: 18163
2002 2.5 WRX
MBP
Also your running that turbo too hard at this elevation, especially on 91 oct.
Without knowing what the afr looks like it's hard to tune out that knock.
MAD REX is offline   Reply With Quote
Do you see what I see? DO you hear (see) what I see? PabloEscobar'd Off-Topic 23 10-11-2004 12:36 PM
What do you do when you see someone you know but can't remember??? HalfBaked Off-Topic 20 02-11-2004 06:39 PM
Look at the picture first...what do YOU see?(Are you corrupt?) JMP73 Off-Topic 57 10-18-2003 11:22 PM
What do you see wrong with this pic. White Knight Interior & Exterior Modification 3 06-30-2001 09:34 AM
