Old 08-13-2004, 12:53 AM   #1
Hayaboosted
Member#: 60042
2004 WRX STI
Rotated T67 ALLABOUTSPEED
Default Accessport Targeted Boost Level ?
Hey guys and gals Im sorry if this question has had a millions post and replies but I just searced for an answer and couldnt find it. Anyways I would like to know what that targeted boost level is with a stage 2 map when using an accessport?
Hayaboosted is offline   Reply With Quote
Old 08-13-2004, 07:59 AM   #2
Quack
Member#: 57264
2004 18g Wagon - WRB
PDX Tuned - 329whp/315wtq
~15.8 +/-0.5
Quack is offline   Reply With Quote
Old 08-13-2004, 09:10 AM   #3
Hayaboosted
Member#: 60042
2004 WRX STI
Now is that in every gear? or just certain gears?
Old 08-13-2004, 12:28 PM   #4
bluelinescooby
Member#: 48881
2009 1125CR
1996 Neon ACR
Certain gears. You should be able to hit max boost in 3rd and 4th gears. You won't hit it in 1st or 2nd because the ECU doesn't think the car is moving fast enough to get enough air flowing through the intercooler. And boost will usually taper off towards redline. I just flashed to the stage 2 93 octane map, and I'm seeing right at 16psi in 4th gear.
bluelinescooby is offline   Reply With Quote
Old 08-13-2004, 02:23 PM   #5
Quack
Member#: 57264
3rd and up...
i'm seeing 16.4 for a few seconds then settling down to 15.8
Old 08-13-2004, 03:54 PM   #6
Rob420
Member#: 39703
. 2007 GREY STI
02 WRX & 08 STI- RETIRED
Originally Posted by Quack
3rd and up...
Ditto for me. I've had the AP installed for 2 days...
Rob420 is offline   Reply With Quote
Old 08-13-2004, 10:24 PM   #7
rexster
Member#: 22863
2015 WRX Premium CWP
you'll find the answer in this thread:
http://forums.nasioc.com/forums/show...t=target+boost
the target is the same in all gears. you won't see it in the first two because the car isn't under load long enough. i only see 12.5psi in first, but i see 16 around 3k in 3rd and up according to my ap.
rexster is offline   Reply With Quote
Old 08-13-2004, 10:28 PM   #8
rexster
Member#: 22863
Old 08-14-2004, 11:10 AM   #9
brizey
Member#: 36505
2004 Forester XT PSM
2007 Acura RDX w/Tech CBP
I see a hair under 16 psi in 3-5 if I go WOT from less than 4000 rpm. You maynot always see full boost when driving like a drag race because the rpms don't drop much and the engine sees less load in the next gear. For example, when shifting from second to third your rpm may only drop to 4500-5000 rpm, so you may not see full boost in third on level ground (or in warm weather).
When going uphill, you can probably hit full boost in 2-5.
brizey is offline   Reply With Quote
Old 08-15-2004, 10:56 AM   #10
elohdaeh78
Member#: 61395
2005 WRX
CGM
Funny you said that about going up hill, my 1988 toyota supra would only make 8 or so psi in second gear on a flat surface but it could make 10-11 psi going uphill that always puzzled me
elohdaeh78 is offline   Reply With Quote
Old 08-15-2004, 03:16 PM   #11
84SubaruDL
Member#: 42179
SON! F 22's i roll
on 33" 12 fity SON!!!
thats funny, i get 16 at WOT in second and up, and my egt are about 11-12 till red line in second.
84SubaruDL is offline   Reply With Quote
Old 08-16-2004, 03:02 AM   #12
Bishop
Member#: 59993
Ass, grass or cash
no one rides for free!!
is it me or our do our cars hit target boost more on cooler days?
Bishop is offline   Reply With Quote
Old 08-16-2004, 03:05 AM   #13
supermarkus
Member#: 6971
2008 WRX STi
SSM
Hotter temps= less dense intake charge= more difficulty getting to target boost.
supermarkus is offline   Reply With Quote
Old 08-16-2004, 03:25 AM   #14
TastyTurbo
Member#: 38404
Black Like Yo Moms Tooth!
In 4th and 5th gear, I've been hitting 17p.s.i. since I installed my
Stromung 3-inch cat-back.
It's been three weeks, the ecu should've learned by now.
TT
TastyTurbo is offline   Reply With Quote
Old 08-16-2004, 03:34 AM   #15
supermarkus
Member#: 6971
2008 WRX STi
SSM
is that on the AP or on an aftermarket boost gauge?
Old 08-18-2004, 02:30 PM   #16
TastyTurbo
Member#: 38404
On my Omori boost gauge.
Yes, it's accurate.
TT
Old 08-18-2004, 04:24 PM   #17
supermarkus
Member#: 6971
2008 WRX STi
SSM
How does it compare when you measure boost with the AccessPort? I've seen boost gauges differ from MAP by as much as 2 psi depending on where they're tapped. My Trust gauge is roughly 1psi low using MAP as my reference.
Old 08-18-2004, 11:37 PM   #18
jugger
Member#: 64228
what is target boost at 7,000' elevation????because i only see low 13s....and at ~5,000' elevation no more that 14.1 psi...all from the AP (funny enough the OEM gauge is dead on)
jugger is offline   Reply With Quote
Stg1 07 Wrx Not hitting targeted boost level - DELETE WassonA Open Source Reflashes 0 10-25-2009 11:36 AM
Does changing my target boost level affects MAF scaling? savageblitz Open Source Reflashes 3 06-03-2008 08:07 AM
Not hitting target boost levels help! AvengerSTi AccessPort 7 11-15-2006 06:12 PM
What is target boost for my accessport stage 2? essogas Engine Management & Tuning 8 06-19-2005 03:54 PM
Target Boost level at 3000 RPMs, TXS stage 2 rogue Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 02-22-2004 05:51 PM
