Go Back   NASIOC > NASIOC Subaru Models > 'Old School' Subaru Forum
Old 08-13-2004, 03:26 PM   #1
subyrally
Member#: 52662
2009 dgm WRX hatch
86 & 87 rx, 1985 brat
Default !!!HELP!!!! methinks i killed the rx
my rx wont start, i thought it was the fuek pump or a relay for the pump. but now i think it is something under the dash or something with the ignition. anyone ever had this problem or know a way to fix it?
subyrally is offline   Reply With Quote
Old 08-13-2004, 04:22 PM   #2
Calebz
Member#: 54398
1980 CB400 Hawk
1996 GrandCherokeeLimited
Have you checked the T-belts?
Last time mine just quit, it was because the ECU decided to let the smoke out
Calebz is offline   Reply With Quote
Old 08-14-2004, 01:32 AM   #3
Flowmastered87GL
WCSS Drunk
Member#: 8914
2005 Baja Sport
Regal Blue Pearl
How did it die out of curiousity?
Did it just not start one morning?
Did it die while you were driving it?
Flowmastered87GL is offline   Reply With Quote
Old 08-14-2004, 01:57 AM   #4
subyrally
Member#: 52662
2009 dgm WRX hatch
i dont know what did it in, i cant really drive it anywhere cause i havent got it registered yet. but i did drive it down my street and baked it into my driveway the day before it died. i then attempted to pull off the steering wheel to get to the headlight dimmer switch, with no success. then i removed the plastic covering the steering column. after all that, i fixed the pull cable for the hood release, it was just hanging by the pedals. i did push part of the harness out of the way so that i could get hte bracket to fit in place. there are so many things that could have gone wrong in the last week or so. i did end up fixing the ground wire for the fuel pump because of this problem, although that wasnt he cause.
Old 08-14-2004, 08:22 AM   #5
subyrally
Member#: 52662
2009 dgm WRX hatch
tested the fusable links, they are good.
Old 08-14-2004, 08:38 AM   #6
Calebz
Member#: 54398
1980 CB400 Hawk
you puulled/tried to pull the steering wheel?
Check the horn fuse..
seriously
Old 08-14-2004, 09:28 PM   #7
subyrally
Member#: 52662
2009 dgm WRX hatch
ive checked all the fuzes under the dash and under the hood. none were blown. the horn still works fine. i still need to check and see if the new coil and wires made a difference.
Help with greasing up the bushings kmper02 Newbies & FAQs 1 06-02-2010 03:52 PM
Will a resonator help kill the sound? shamrock 05 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 13 10-15-2009 12:55 AM
Lil help figuring out what's killed the power Legacy Electrical & Lighting 7 11-19-2007 09:31 AM
Help! my car is killing the FPR Starkiller Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 07-25-2005 05:30 PM
Help fix the RX, get free beer (or coke if you prefer) pleiades South East Region Forum 15 09-07-2002 12:34 AM
