Old 08-14-2004, 12:03 AM   #1
ExecNav
Member#: 30554
08 LGT Spec.B
01 Impreza RS-T
Default Oil Pan Questions
First, I have this black plastic or rubber ring about the size of a quarter I found in the oil pan. I guess it fell off of something, just not sure where. I guess it could either go one of two places; on the oil pickup in between the flange and the motor where it fits perfectly, or somewhere around that dipstick pipe. My money is on the pickup.
Also, I had to remove my oil pan again ( ) because it was leaking from the back over the crossmember. Anyone have any recommendations for preparing the oil pan before reinstalling? I thought I did a good enough job the first time getting the old gasket off but I guess you really need to remove EVERY mm of that stuff.
I'm using High Temp Red RTV 650. Is this good enough for the job? Any advice would be greatly appreshicated.
-Brett
ExecNav is offline   Reply With Quote
Old 08-14-2004, 12:42 AM   #2
Da Sola Setter
Member#: 38433
2015 FXT
that RTV is what I used on my WRX pan. Just get every last speck of gasket off there use a rasor blade if you have to sometimes a gasket scraper isn't enough. Wipe it down with brake parts cleaner a couple times and you should be good.
I am not sure about the rubber ring tho... not sure the brakeout drawings would show it either.
Todd
Da Sola Setter is offline   Reply With Quote
Old 08-14-2004, 01:12 AM   #3
Aphex
Member#: 146
'16 WRX Limited
yep, goes on the pickup.
Aphex is offline   Reply With Quote
Old 08-14-2004, 02:27 AM   #4
HndaTch627
Member#: 6551
'01 GC8 Dinged STM
'09 Concours 14 ABS Black
you need to get Hondabond or Subaru 3 bond, RTV suck arse in the world of engine sealants, also pull your flywheel off and make sure it's nott he oil/vapor seperator that's not leaking.
Old 08-14-2004, 02:46 AM   #5
ExecNav
Member#: 30554
08 LGT Spec.B
01 Impreza RS-T
It's definitely my oil pan. I just took it off and reinstalled it a week ago and did a pretty half-assed job because I was tired and frustrated. I didn't clean the gasket off the motor and left some on the pan.... so yeah I pretty much deserve this.
Of course if by some chance it is the separater behind the flywheel, you can pretty much bet I'm taking it to a dealer because I just did my clutch and I've decided I'm done with tranny work for now.
Also, I like how casually you say just pull my flywheel to make sure the separator is ok. You must have an awesome garage.
-Brett
Old 08-14-2004, 02:59 AM   #6
White 2.5rs
Member#: 39936
99RS TWE&SCAT EJ257
Hydra+HMist+PPG+35R=DEATH
i watched trucks! today, they tapped an oil pan w/ no boss to it w/ it on the car and just screwed the fitting in....
if only we had that luck
Old 08-14-2004, 03:08 AM   #7
ExecNav
Member#: 30554
08 LGT Spec.B
01 Impreza RS-T
My first attempt worked okay. Of course, I only had it on for a week, but no leaks. I used an aluminum 1/2" NPT to 1/2" pipe fitting and some RTV all held on with JB weld.
If I notice any leaks, I'm just gonna break down and by a WRX oil pan and have a 45 degree 1/2" pipe welded into it. Right now I just need my car to drive.
-Brett
Simple oil pan question MS WRX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 10 03-07-2008 06:16 PM
oil pan question bluice Subaru Conversions 2 11-15-2005 04:38 PM
Oil pan question I drive a WRX wagon Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 03-18-2004 01:45 PM
Help! Oil pan question scrmnsmn Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 09-30-2002 11:04 PM
oil pan question imprezaboi Normally Aspirated Powertrain 1 02-12-2002 02:29 AM
