Old 08-15-2004, 06:41 PM   #1
buru6
Member#: 53411
Default neutral safety switch code
Ok a couple of month ago I took my 99 rs 2.5 and swaped out the motor and auto transmission to the wrx motor and a manual 5-speed. Everything works perfect except that a check engine light comes up for the neutral safety switch. I'm almost possitive that it is from the transmission swap but how do I fix this?
Thanks
buru6 is offline   Reply With Quote
Old 08-16-2004, 12:16 AM   #2
Axan
Member#: 17569
2011 Impreza WRX STI
ok silly question, but did you get an ecu from manual rs? There is a connector on ecu that sees ground when car is in ground on manual ecus.
Axan is offline   Reply With Quote
Old 08-16-2004, 03:41 PM   #3
buru6
Member#: 53411
yeah, I have the wrx manual ecu
P1590 Neutral Safety Switch code and only 7.3 psi of boost? mwichtendahl Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 10 07-03-2009 08:40 PM
Neutral safety switch...? adam555 Transmission (AT/MT) & Driveline 10 12-05-2005 10:25 AM
Neutral Safety Switch dfgu Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 11-21-2005 01:23 PM
neutral safety switch problems w/MT reveler Car Audio, Video & Security 2 10-24-2002 08:02 PM
MAP sensor dead! Neutral safety switch dead! 1st recorded MAP kill? munkis Normally Aspirated Powertrain 5 07-22-2002 07:09 AM
