#1 |
Member#: 61940
International
Vehicle:2013 Volvo XC90 |
At first i had the ABC cranked out 2 turns and did a run which resulted in
www.galaxy-pc.com/uteclog/run1.txt No CEL's that I saw... I noticed I really wasnt hitting high boost so i cranked it out another half to 3/4 of a turn and then got this www.galaxy-pc.com/uteclog/run2.txt This time I did notice the CEL light flash when shifting.. Any idea what this was? Can anyone take a look at these numbers and give me an idea of how its going? I'm completely new to the UTEC and tuning it etc. Thanks -Derek
#2 |
Member#: 32792
NESIC
Vehicle:2003 GGA MBP 12.9 / 105+ |
are my eyes failing me or is there no knock there?
![]() ken ps use logger 1, it has more useful information for tuning fuel and ignition. |
#3 |
Member#: 29962
Check this out: http://www.wrxhackers.com/files/UTEC...03_22_2004.pdf
#4 |
Member#: 39235
You are not using open loop fueling. If the 05 is like the 04 it's a must. 12.9psi + 15.1afr + 21deg. =BAD
#5 |
Member#: 21980
NESIC
Vehicle:2002 PSM WRX (Sold) 2009 BMW X5 |
Flashing CEL is knock. If it happened after you shift you need to adjust the 0% fueling a bit.
#6 |
Member#: 61940
International
Im going to turn on open loop fueling tonight and see if that fixes it....
#7 |
Member#: 61940
International
Update::
new run wiht openloop on and in logger1 let me know http://www.galaxy-pc.com/uteclog/openloopon2.xls |
#8 |
Member#: 32792
NESIC
looks ok... are you getting any more knock?
also, did you download v 4.2c? you should, if you haven't, and flash your utec. it helps keep the car smooth @ 100% idc. ken |
#9 |
Member#: 61940
International
yeah I have 4.2C... didnt get any knock when i did that run last night...
hopefully all is well! |
| Thread Tools | |
| Display Modes | |
| just installed utec, made a few pulls, logs -> input? | lancelucas | UTEC | 9 | 10-18-2006 02:33 AM |
| Just installed utec | wrex03 | Factory 2.5L Turbo Powertrain | 8 | 06-11-2004 03:43 PM |
| Just installed utec... More mods! | rexpower | Tri-State Area Forum | 13 | 01-11-2004 12:15 PM |
| 04 Rex just installed UTEC tonight got a lil knock still with turboxs temp fix | kitbar | Engine Management & Tuning | 22 | 11-19-2003 04:10 AM |
| Just installed UTEC...got some questions... | auxiliary | Engine Management & Tuning | 29 | 05-01-2003 07:25 PM |
