Old 08-15-2004, 10:22 PM   #1
sssp
Member#: 64674
2008 EVO X
2011 ZX10r
Default Wiring TT and keeping engine kill feature
I am trying to wire my Greddy TT and keep my engine kill feature at the same timeon my04 WRX. I know I have to cut 2 wires but one of the wires is what monitors the engine. Therefore when I cut that wire my engine kill feature is gone. I've done a search and found people just proposing ideas of how to fix it but never found out if anyone has successfully done this.
Can someone tell me how to do this or point me in the right direction??
Thanks
sssp is offline   Reply With Quote
Old 08-15-2004, 11:10 PM   #2
netZ
Member#: 5743
2007 Kia Optima
gold brick
engine kill? you mean starter kill? please provide additional information ie. alarm system? factory or aftermarket?
the wire you cut on the subaru security module is used to detect ignition status. it should set the alarm off if someone were to attempt to start the vehicle while armed. this wire is also used to detect the ignition key cycling for the manual alarm disarm.
the subaru security module has a starter kill status output. this is wired to the starter kill relay and isn't affected by the turbo timer. did you wait at least 30 seconds before trying to crank the vehicle after 'arming' the vehicle?
netZ
Thanks
netZ is offline   Reply With Quote
Old 08-15-2004, 11:58 PM   #3
sssp
Member#: 64674
2008 EVO X
2011 ZX10r
Yea i ment starter kill. I have a factory alarm. I actually havent cut any wires yet. What i am trying to do is arm my car while the turbo timer is counting down. Then when the car shuts off the starter kill enables by itself. I did some more searches and found a old thread that helped explain a lot of things but I am still extreamly confused.
Do wire a 12v relay switch from the blue wire off the the TT harness to the Grey wire on the Alarm Module?? Is the Alarm Module the one under the Glove box on 04 models or is that the Keyless entry module?
Here is the thread that I was reading http://forums.nasioc.com/forums/show...=timer+install
Shaved, wire tucked, and custom engine bays? D Money Interior & Exterior Modification 1896 Yesterday 10:56 PM
Apexi TT doesnt keep car running when I cut off xEclipsE RaceRx Electrical & Lighting 2 09-25-2005 12:11 PM
TT Not keeping engine running... most of the time Blue_Diamond Electrical & Lighting 2 07-20-2004 05:26 AM
How to wire driving lights and keep DRLs? ATB Electrical & Lighting 7 12-31-2003 06:34 PM
Making alarm work with TT and starter kill jsmithjr732 Car Audio, Video & Security 0 06-28-2002 01:25 AM
Message Board Statistics All times are GMT -4. The time now is 10:16 AM.
