Old 08-16-2004, 06:32 PM   #1
Rick539
Member#: 35997
Default Can an UTEC hold 20psi ?
I was told by a reliable source that the utec would reach but not hold 20 psi. Getting ready to install a VF22 and would like to get a solid 20psi boost curve. I have the mods to do it but will the utec hold it?
Rick539 is offline   Reply With Quote
Old 08-16-2004, 06:36 PM   #2
RiftsWRX
Member#: 6124
2000 NFR AP1 S2000
'07 Honda FIT sport (5MT)
that's dependant on the turbo... no boost controller in the world will get beyond the spring rate holding the door closed on an internally gated turbo.
Jorge (RiftsWRX)
www.ProjectWRX.com
RiftsWRX is offline   Reply With Quote
Old 08-16-2004, 07:05 PM   #3
WRX Jim
Member#: 22321
my vf22 held 22psi till about 5500 rpm
as it dropped off slowly...
WRX Jim is offline   Reply With Quote
Old 08-16-2004, 08:08 PM   #4
Rick539
Member#: 35997
So the utec will manage 20 psi. The limitation then is the wastegate. Does the spring mod help. How about the mbc and abc, will they stand up or will they need to be changed?
Old 08-16-2004, 09:18 PM   #5
Macabre
Member#: 3841
2004 WRX Wagon
UTEC+VF22+WI
http://forums.nasioc.com/forums/show...ight=wastegate
[email protected] is a tall order with this setup. The turbo can do it, especially if you wire the wastegate closed, but it's hard to get the OEM boost control solenoid or even an MBC to do it unless you run a lot more boost in the mid range. The UTEC doesn't have much to do with it.
Macabre is offline   Reply With Quote
Old 08-17-2004, 07:23 AM   #6
ride5000
Member#: 32792
2003 GGA MBP
12.9 / 105+
use the gm solenoid mod. since it is interruption based instead of bleed based, it is much more effective at preventing the wg from opening prematurely.
you eventually reach a point where the spring can't keep the wg closed due to the exhaust gas back pressure on the manifold side pushing it open. that's when you need more wg spring tension.
hth
ken
Old 08-17-2004, 07:47 AM   #7
TheMadScientist
Member#: 23717
2005 Big red
The Utec will handle ANY amount of boost that you want to run. It is the other parts of the boost control system that won't. That is why TXS uses an ABC with the Utec.
Wow I seem to be agreeing with ride5000 alot today. Setup the GM solenoid and then you are mostly limited to the flow/pressure of the turbo without the need for an ABC. Just remember to change the map scaling in the Utec. I set the max scaling pressure at 2-3psi more than what the car will run. That way you have an over boost colum in the maps.
TMS
TheMadScientist is offline   Reply With Quote
Old 08-17-2004, 10:55 AM   #8
SlideWRX
Member#: 3803
07 Mustang GT
Ford Crappy Paint White
Also, if you are using the Stock BOV/bypass valve it may not hold 20 psi. Some do, some don't - a bit of variability from the plant.
But yeah the UTEC can command any boost that the system can hold.
Tom
SlideWRX is offline   Reply With Quote
Old 08-17-2004, 11:09 AM   #9
TheMadScientist
Member#: 23717
2005 Big red
Tom
This
http://forums.nasioc.com/forums/show...hreadid=454965
Will fix the BOV.
TMS
How much power can an '04 2.5RS tranny hold? JEEENKINNNS Transmission (AT/MT) & Driveline 4 01-04-2007 07:15 PM
How much psi can stock BOV hold? wgknestrick Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 3 01-17-2004 01:39 PM
Anyone know how I can get a hold of Gypsum2? de Rookie Texas Impreza Club Forum -- TXIC 3 02-05-2003 08:40 PM
How much HP can stock clutch hold? GregUnd Texas Impreza Club Forum -- TXIC 18 11-27-2002 10:33 AM
