Old 08-16-2004, 10:36 PM   #1
awdguy
Member#: 59101
2004 wrx
white
Default accessport?
I am wondering if it is nessasary to do a dyno tune if i go to stage 2 or will it be already tuned when i switched to stage 2? Sorry if its a stupid question.
awdguy is offline   Reply With Quote
Old 08-16-2004, 11:40 PM   #2
yellowscooby
Member#: 42545
it will be all rady to rock and roll. some people take it to the dybo to see exactly what they are putting down, but not necessary.
Dave
yellowscooby is offline   Reply With Quote
Old 08-18-2004, 02:29 PM   #3
Irishman
Member#: 29933
2004 STI
Silver/Silver
So with the AP you just plug and play? No tuning need? That would be nice. Very new to EM trying to soak up info before buying.
Irishman is offline   Reply With Quote
Old 08-18-2004, 03:37 PM   #4
WrxTream
Member#: 39207
2008 WRX STi
Dark Gray Metallic
Well the first thing is to flash a base map to the ECU ... A base map is what the ecu will go back to when the ecu is reset. This can be done up to 100 times (If you need to or want to change to a diff. base map) ... meaning if you disconnect your battery and reconnect....your Base map will still be active.... After your base map is flashed it is now PnP.... Cobb calls this Real-time maps... this can be done an unlimited amount of times. For example I have a VF34 Base map and I'm going on a long trip ... so I flash a real-time STI injector economy map for better gas mileage....When I want more fun I pull over and change my real-time map to the VF34 map again ... I can do that an unlimited amount of times.
hope this helps a little
I forgot to answer your ? You do not have to dyno tune. When the Access Tuner comes out you can add mods that Cobb's maps don't support and then get it tuned... At least thatís my understanding
---BUNDY---
WrxTream is offline   Reply With Quote
Old 08-20-2004, 12:12 AM   #5
Irishman
Member#: 29933
2004 STI
Silver/Silver
Thanks for the info that helped alot.
FS : accessport v2 BLACKBUG03 Engine/Power/Exhaust 8 06-06-2010 03:37 PM
FS GA Cobb Accessport V2 red98lude Engine/Power/Exhaust 0 06-02-2010 01:49 PM
WTB or wtt, accessport wrx sti ver.1 4a non-sti accessport 04' Red_Wrx SCIC Private Classifieds 0 12-10-2007 04:14 PM
Cobb Tuning Accessport Version I Cobb Accessport WRX0520 Engine/Power/Exhaust 0 07-18-2007 03:02 AM
looking to sell my 04 accessport or trade for 02 accessport anthonyrb98 Mid Atlantic Impreza Club -- MAIC 3 07-30-2004 11:05 PM
