Welcome to the North American Subaru Impreza Owners Club Monday August 29, 2016
Old 08-17-2004, 09:20 AM   #1
roffle
Member#: 42251
uh oh
trumpet butt
Default Epoxy + Plastic
I'm getting my new grille back fromt he paint shop today, and am going to remove my little "Impreza" badge from the trunk and glue it to the mesh in the grille like all the ricers do with their accords.
I was planning on applying a lot of epoxy to the back of the badge, and have some metal washers or something on the other side of the mesh to hold it in place... anyone know if epoxy is the right adhesive to be using? I've never used it with plastic before. Should I use something different in place of the washers?
Thanks
roffle is offline   Reply With Quote
Old 08-17-2004, 11:54 AM   #2
silveRS2.5
Member#: 55307
2002 FrontinW/ascoop
DirtySilverMetalic
I think you should use a piece of plastic in place of the washers, that way you could use plastic bonding glue( something that will melt the plastic to the mesh) and make sure that it says that on the package. I used some industrial glue the other day that didn't work at all for plastic on plastic.
my .02
silveRS2.5 is offline   Reply With Quote
Old 08-17-2004, 12:58 PM   #3
Pengo
Member#: 41164
there is some epoxy or sealant that is meant for plastic.
most consist of two different gels that must be mixed and then they bond pretty hard.
Pengo is offline   Reply With Quote
Old 08-17-2004, 02:47 PM   #4
Subie Gal
GC84Ever
Super Moderator
Member#: 301
1970 FF-1 & '70 Van
02 WRX/01 RS
i used 3M automotive badge tape on mine.
Jamie
Old 08-17-2004, 05:44 PM   #5
roffle
Member#: 42251
uh oh
trumpet butt
Jamie
Very clean, but I'm a gluestick and ducttape sorta guy
Thanks for the tips.
Old 08-17-2004, 09:13 PM   #6
shadrool
Member#: 59775
09 forester
white
epoxy will work wounders. 3m makes an awesome plastic epoxy. we use a ton of it. (not for broken things, just to use to hold everything). just scrap both sides of the plastic for the epoxy to hold onto. if possible use somesorta tape. i prefer painters blue tape. to hold the emblem in place. wait about 10-15 min and remove tape. WHALA! "needs to be broken, to be removed"
shadrool is offline   Reply With Quote
Epoxy to affix front badge onto Grillcraft grill - will it hold? Orson Newbies & FAQs 6 01-06-2006 12:50 PM
Check out my new epoxied floor! (and what's sitting on it!)(LONG) Blugin Texas Impreza Club Forum -- TXIC 56 12-12-2005 12:28 AM
two-ton epoxy for teh win :banana: alacrity024 Off-Topic 37 10-08-2005 04:01 PM
Is there a liquid epoxy or plastic that hardens to a non-toxic barrier? Gravel-Fun Off-Topic 3 01-05-2005 03:44 PM
Garage Epoxy Paint, Who has done it? Bonefizz General Community 15 08-23-2004 01:53 PM
