Old 08-17-2004, 11:37 AM   #1
timo
Member#: 43949
2003 WRX
WR Blue
Default Screeching noise at WOT when shifting gears
Hi guys,
Lately I have noticed that my car is making another noise that bothers me a little bit and want to see what you guys think about it. Basically when I am at WOT and shift gears at after 6k rpms I hear this screeching noise for probably less than a second. It happens after I fully press the clutch to shift. It's only for a split second and you have to really listen carefuly to hear it. I am hoping that it's not the turbo or the engine, but am not sure at all. Coult it be that the stock BOV is going bad and starts leeking(I am hoping it's this one as it would be the cheapest to fix), or could it be the wastegate, or could it be the engine(I hope not), or maybe the turbo? I am at Cobb stage 2 and am reaching target boost and everything else seems normal, and my car has only 25k miles on it.
All responses are greatly appreciated
thanks
martin
p.s. I should add that I have had an uppipe leak before and I don't think this is the case right now. The leak that I had was fixed a long time ago and hasn't leaked since.
timo is offline   Reply With Quote
Old 08-17-2004, 11:40 AM   #2
sufx
Member#: 46051
2004 Impreza WRX
Java Black Pearl
is it JUST when you press the clutch in, or does it screetch when you shift?
sufx is offline   Reply With Quote
Old 08-17-2004, 11:43 AM   #3
timo
Member#: 43949
2003 WRX
WR Blue
when the clutch is fully engaged before I shift the shifter
Old 08-17-2004, 11:45 AM   #4
cdvma
Member#: 21980
2002 PSM WRX (Sold)
2009 BMW X5
Are you using an aftermarket BOV? If you are, what you hear may be compressor surge. It kinda sounds like a lazer beam in a sifi movie.
cdvma is offline   Reply With Quote
Old 08-17-2004, 11:46 AM   #5
timo
Member#: 43949
2003 WRX
WR Blue
That's what it sounds like(laser beam in a sci-fi movie), and I am not using an aftermarket bov
Old 08-17-2004, 12:03 PM   #6
timo
Member#: 43949
2003 WRX
WR Blue
I have never heard what a compressor surge sounds like, but for some reason I have the feeling that this is exactly what happends. If it is a compressor surge, how do I go about fixing it? What's causing it? Please guys help, I am worried about my car
thanks
Old 08-17-2004, 12:17 PM   #7
cdvma
Member#: 21980
2002 PSM WRX (Sold)
2009 BMW X5
Got a local buddy with a WRX that you can trade valves with? Try his out to see if thats the issue. I dont know if the stock ones are serviceable but you can also probably pick up a used one for really cheap if thats what it comes down to.
Old 08-17-2004, 12:45 PM   #8
timo
Member#: 43949
2003 WRX
WR Blue
cdvma, I'll try that.
In the meantime is there anything else that I can do to try to pinpoint the porblem?
Old 08-17-2004, 01:54 PM   #9
Alizarin
Member#: 53769
2004 WRX JDM STi v8
IAM = 0 FTL :(
Would a cracked or split return line from the BOV->intake cause a screech from the leak?
Alizarin is offline   Reply With Quote
Old 08-17-2004, 02:33 PM   #10
cdvma
Member#: 21980
2002 PSM WRX (Sold)
2009 BMW X5
That is a possibility as well.
Old 08-17-2004, 03:03 PM   #11
timo
Member#: 43949
2003 WRX
WR Blue
I'll have to check that. Will let you know later on tonight.
Loud Screeching Noise at High RPM?? rm125103 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 11 04-13-2010 03:50 AM
Screeching noise from wheel when driving slow scootersteve Newbies & FAQs 7 10-24-2006 01:52 PM
Please HELP!!!! SZ65 turbo makes screeching noise at idle!!!! sticrazy Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 8 06-05-2006 02:12 PM
rumbling noise when shifting gears on 06 jollib Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 0 12-01-2005 04:24 PM
"Electric zapping/buzzing"-like Noise at WOT, 1st&2nd Gear @ 5000+ RPM, A/T '04 WRX dcwrx2 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 21 09-30-2004 02:13 AM
