#1 |
Member#: 22879
Hi all, i would like to hear some opinions on what would be a better set up for my car. It's a 96 legacy with a 03 jdm sti engine and full drivetrain swap. I've used a 02 wrx bulkhead harness and added and switched wires for the avcs. Everything is working properly so far.
I would like to mod the car in the near future and have the ability to get it tuned properly. I plan on the usual stuff for performance like intake tbe and other things, but i would like some flexability in tuning. I live about 1200 miles round trip from the near tuner with an awd dyno, so that's a concern. What i'm thinking is a jdm utec (yes, i can get one) and then getting the utec tuner and playing with it. Then once i get my car further modded then take it to a tuner and let them at it. Is there anything else out there that would let me tune it myself for about the same amount of cash as the utec? Anyone think i would be better off with something like a ecu tek? Let's hear some opinions! B
#2 |
Member#: 58647
Vehicle:02 Exedy Carbon clutches SLIP and SUCK $! |
I have a 02 WRX with an 02 STi engine trans swap. I have the 02 STi ECU also with the full functioning AVCS. I am scheduled to have an Ecutek flash tomorrow but, the place Rallispec is only an hour from me. However I have a UTEC with a Rev6b board and from what I have been told it will work with the ECU and not bother the AVCS. I have yet to install it on my car as I have the Ecutek flash comming up and don't want to damage my car and miss my appointment.
The reason I am doing both is I did not know my UTEC would fit so I will just have race maps on my UTEC for the most part. |
#3 |
Member#: 13520
Vehicle:99rs ej207 spec-c its for sale |
wow did a search for ecutek becuase im about to ship my ecu off for it and saw this thread was from today lol.
i just plan on having tbe and intake for my swap nad leaving it alone. Being a twinscroll the turbo upgrade options arnt that feasible, so im just gonna get the ecutek reflash and have a nice solid reliable 93 octane map then work on exterior/interior |
#4 |
Member#: 22879
Yeah, well you also have the sweet RA sti engine in a 2800 pound car. I have the regular (sigh) sti engine in a 3100 pound car! I think i'm going to need a little more out of it.
I also have to deal with oxygenated gas here in the winters and would like to be able to get more out of race gas when i'm willing to put it in. I read somewhere that you could get a dual map with an ecu tek setup, but i don't see how you could unless you have two different ecms. B |
#5 |
Member#: 2258
Vehicle:1999 gc8 ver7 6mt GT35R 504.7whp;) |
You mentioned race gas. Probably better off with the utec. I say definitely go with the utec...and you don't need the jdm one.
#6 |
Member#: 22879
I know you can use the usdm utec with this setup, but you have to hardwire it in. No big deal as my car is mostly custom wire at this point, but the jdm one plugs right in.
One thing i don't know is does the jdm utec control the avcs or not? Does any utec do this? B |
#7 |
Member#: 2258
well if you have a non rev6b utec that's true. Just find a used 6b and it plugs right in. Utec doesn't control avcs.
#8 |
Member#: 22879
So basically a jdm one would only benifit me in the fact that it would plug into the factory harness and that's pretty much it?
I'm pretty new to the utec, so is the revision6b the latest utec or what? Anyone know if i can get a base map for the jdm engine with the twinscroll setup? Thanks Brent |
#9 |
Member#: 2258
No it won't benefit you over the 6b. Yes it's the latest revision and plugs right in. I've run both, there is no difference.
You could use a stg4 basemap and build off that. I believe there is someone from australia who was running a utec map for the twinscroll if you care enough to try and find his thread. I totally forget the name so i can't help you there. With the money saved over a new utec, get a used one and buy a wideband also, you'll be happy you did. |
#10 |
Member#: 22879
I've been thinking about the wide band tuner too. I would like to get it and try it out. I'm not worried about saving a couple hundred bux and would rather get a brand spanking new one with a warranty and some tech support as i know relatively little about them.
So what you're saying is with the newest utec i can order from anyone of the vendors it will plug into a jdm version 8 sti engine right? Thanks Brent |
#11 |
Member#: 22879
Oh yeah, with the utec i won't loose the avcs right? It will still be there with the oem ecm controlling it right?
B |
| Thread Tools | |
| Display Modes | |
| Ecu-tek or AP? | sivonda828 | Engine Management & Tuning | 7 | 04-23-2006 02:12 AM |
| ECU-tek or UTEC Simple question | SjpWrx | Engine Management & Tuning | 4 | 01-03-2004 05:00 PM |
| UTEC or something else? | turca | Engine Management & Tuning | 7 | 11-28-2003 06:51 PM |
| ecu rpm output: voltage or something else? | sick1.8t | Engine Management & Tuning | 2 | 11-19-2003 09:30 PM |
| USDM WRX or STi swap harder than JDM STi swap??? | garface | Normally Aspirated with bolt-on Forced Induction Powertrain | 4 | 01-12-2003 11:37 PM |
